3D Airfoil Help
Like Tree1Likes
  • 1 Post By JonathanG
Old   May 27, 2017, 20:11
Default 3D Airfoil Help
JonathanG
JonathanG is on a distinguished road
Hi everyone, I am new to OpenFoam and trying to run a 3D airfoil simulation with PISO LES solvers.
I keep getting the following error when I run pisoFoam, and couldn't find any information on the error.
Any help would be greatly appreciated!
Many Thanks, Jonathan
--------------------------------------CODE----------------------------------------
Selecting incompressible transport model Newtonian
Selecting turbulence model type LES
Selecting LES turbulence model dynamicKEqn
Selecting LES delta type cubeRootVol
bounding k, min: 0 max: 2e-05 average: 0
dynamicKEqnCoeffs
filter simple;
Ce 1.048;
No MRF models present
No finite volume options present
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::LESModels::dynamicKEqn<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::Ck(Foam::GeometricField<Foam::SymmTensor<double >, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#6 Foam::LESModels::dynamicKEqn<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::correctNut(Foam::GeometricField<Foam::SymmTenso r<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#7 Foam::LESModels::dynamicKEqn<Foam::IncompressibleT urbulenceModel<Foam::transportModel> >::correctNut() at ??:?
#8 ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? in "/opt/openfoam4/platforms/linux64GccDPInt32Opt/bin/pisoFoam"
Floating point exception (core dumped)
mukul92 likes this.
JonathanG is offline   Reply With Quote
Old   September 11, 2020, 15:14
Mukul
mukul92 is on a distinguished road
Hello Jonathan, did you ever solve this issue? I am having the same issue with my LES run.
mukul92 is offline   Reply With Quote
SU2 AOA optimization 454514566@qq.com SU2 9 March 7, 2022 17:17
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 13:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 18:27
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
