May 23, 2017, 17:19 |
simple case Study,not working
please help. I'm not figuring out, why this case won't run, even if it's very simple. I'm running an heat transfer case with buoyantSimpleFoam on a rectangular shape channel with OF 4.1. Direction of flow is along the z direction. Looking as for X directions "air" flows from bottom to the top. At the entrance an heat source term of 200W is set up. Case is 2D with a symmetry condition. One inlet, one outlet. Mesh has been generated with Salome, fully hexahedral Code:
Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 5 cells with two non-boundary faces to set twoInternalFacesCells Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box symmetry 320 642 ok (non-closed singly connected) (0 0 0) (0.1 0 3.2) empty 32800 33582 ok (non-closed singly connected) (0 0 0) (0.1 0.7 3.2) fondo 50 102 ok (non-closed singly connected) (0 0 0) (0.1 0.5 0) pareti 320 642 ok (non-closed singly connected) (0 0.5 0) (0.1 0.7 3) top 90 182 ok (non-closed singly connected) (0 0 3) (0.1 0.7 3.2) Checking geometry... Overall domain bounding box (0 0 0) (0.1 0.7 3.2) Mesh has 2 geometric (non-empty/wedge) directions (0 1 1) Mesh has 2 solution (non-empty) directions (0 1 1) All edges aligned with or perpendicular to non-empty directions. Boundary openness (3.4348646e-017 1.5435193e-017 -3.2045384e-018) OK. Max cell openness = 1.3552527e-016 OK. Max aspect ratio = 1 OK. Minimum face area = 0.0001. Maximum face area = 0.001. Face area magnitudes OK. Min volume = 1e-005. Max volume = 1e-005. Total volume = 0.164. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.5326963e-013 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.01 0.1 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 1 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 1 average: 3.9051829 Cell determinant check OK. Concave cell check OK. Face interpolation weight : minimum: 0.5 average: 0.5 Face interpolation weight check OK. Face volume ratio : minimum: 1 average: 1 Face volume ratio check OK. Mesh OK. If I set gravity to -9.81 (z direction), calculation suddenly stops... Can someone explain me what I'm doing wrong? Thanks a lot. Regards Last edited by student666; May 23, 2017 at 18:19. |
May 24, 2017, 10:56 |
Joshua
Rep Power: 10 |
Can you send your log file for when the simulation crashes?
Joshua |
May 24, 2017, 12:12 |
Hi Joshua,
thx for replying. There's not too much in the log.file, as I'm using blue-CFD core and not all errors messagges are still implemented, but you can notice that density has "very strange values". Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 4.x-ed69f631ce88 Exec : C:/BLUECF~1/OpenFOAM-4.x/platforms/mingw_w64GccDPInt32Opt/bin/buoyantSimpleFoam.exe Date : May 24 2017 Time : 16:55:53 Host : "CLT40-MICA" PID : 10548 Case : C:/blueCFD-Core-2016/OpenFOAM-4.x/runBCFD/mio/c3 nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p_rgh tolerance 0.0001 field U tolerance 0.0001 field h tolerance 0.0001 field "(k|epsilon|omega)" tolerance 0.001 Reading thermophysical properties Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type laminar Reading g Reading hRef Calculating field g.h Reading field p_rgh No MRF models present Radiation model not active: radiationProperties not found Selecting radiationModel none Creating finite volume options from "system/fvOptions" Selecting finite volume options model type scalarSemiImplicitSource Source: energySource - selecting cells using cellZone c0 - selected 50 cell(s) with volume 0.0005 Starting time loop Time = 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.01050346, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.012125619, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.008586737, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.99923945, Final residual = 0.0075017272, No Iterations 2 time step continuity errors : sum local = 23.259648, global = 18.384065, cumulative = 18.384065 rho max/min : 1.3018265 0.75605885 ExecutionTime = 0.297 s ClockTime = 1 s Time = 2 DILUPBiCG: Solving for Uy, Initial residual = 0.070874473, Final residual = 0.00014154922, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.11209675, Final residual = 4.8647144e-005, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.62830568, Final residual = 0.0012700515, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.99989501, Final residual = 0.0066348269, No Iterations 4 time step continuity errors : sum local = 7.1847114, global = 4.3435719, cumulative = 22.727637 rho max/min : 38.397472 0.83575775 ExecutionTime = 0.468 s ClockTime = 1 s Time = 3 DILUPBiCG: Solving for Uy, Initial residual = 0.074692508, Final residual = 0.00050290945, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.12177272, Final residual = 0.00038563909, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.23913259, Final residual = 0.00098067645, No Iterations 1 This values for U come from the "top" patch (outlet)...and I can't see a physical meaning for that...certanly there's a numerical error, but where? Furthermore, in this simple case I can solve by setting internal U field, but what a for "real world" problem? Looking forward for any suggestion. Regards |
May 24, 2017, 18:48 |
rho calculation...
I simplified the case more by transforming the shape of the domain into a rectangular one: one inlet, one outlet, one symmetryPlane, one wall.
convertToMeters 1; vertices ( ( 0 0 0) //0 (0.1 0 0) //1 (0.1 0.5 0)//2 (0 0.5 0)//3 (0 0 3)//4 (0.1 0 3)//5 (0.1 0.5 3)//6 (0 0.5 3)//7 (0 0 3.2)//8 (0.1 0 3.2)//9 (0.1 0.5 3.2)//10 (0 0.5 3.2)//11 (0 0.7 3) //12 (0.1 0.7 3)//13 (0.1 0.7 3.2)//14 (0 0.7 3.2)//15 ); edges ( ); blocks ( hex (0 1 2 3 4 5 6 7) (1 50 300) simpleGrading (1 1 1) // hex (4 5 6 7 8 9 10 11) (1 50 20) simpleGrading (1 1 1) // hex (7 6 13 12 11 10 14 15) (1 20 20) simpleGrading (1 1 1) ); boundary ( top { type patch; faces ( (4 5 6 7) // (8 9 10 11) // (11 10 14 15) // (12 15 14 13) ); } symmetry { type symmetryPlane; faces ( (0 1 5 4) // (4 5 9 8) ); } pareti { type wall; faces ( (2 3 7 6) // (7 12 13 6) ); } fondo { type patch; faces ( (3 2 1 0) ); } empty { type empty; faces ( (1 2 6 5) // (5 6 10 9) // (6 13 14 10) (0 4 7 3) // (4 8 11 7) // (7 11 15 12) ); } ); mergePatchPairs ( ); https://www.youtube.com/watch?v=yN58_cevRxE I updated my BC for U and T by replacing zeroGradient with inletOutlet for top BC and fvSchemes as well U Code:
dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { empty { type empty; } symmetry { type symmetryPlane; } top { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } pareti { type fixedValue; value uniform (0 0 0); } fondo { type fixedValue; value uniform (0 0 0.5); } } Code:
dimensions [0 0 0 1 0 0 0]; internalField uniform 293; boundaryField { empty { type empty; } symmetry { type symmetryPlane; } top { type inletOutlet; inletValue $internalField;//uniform 293; value uniform 293; } pareti { type zeroGradient; } fondo { type fixedValue; value uniform 293; } } Code:
ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U);//bounded Gauss limitedLinear 1; div(phi,K) Gauss linearUpwind grad(K);//bounded Gauss limitedLinear 1; div(phi,h) Gauss linearUpwind grad(h);//bounded Gauss limitedLinear 1; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear 1; } laplacianSchemes { default Gauss linear orthogonal; } interpolationSchemes { default linear; } snGradSchemes { default orthogonal; } wallDist { // method meshWave; } It tooks me about 1500 iterations to get to convergence! moving back to origianl "simple case" I had no chance to make it runs, as for rho that reaches unphysical values: so how to manage it? |
December 31, 2017, 15:15 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
I'm really late on this, but here is what I can figure out. First, if I run the case with OpenFOAM 4.x on Linux, I get the following stack trace: Code:
#0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:? #6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #10 Foam::fvMatrix<double>::solve() at ??:? #11 ? at ??:? #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #13 ? at ??:? Floating point exception (core dumped) From the last time step when it crashes, it looks like the problem is when "p_rgh" is solved. My first suspicion is that the settings given in "fvSolution" for this equation: Code:
p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother DICGaussSeidel; } Looking into the OpenFOAM User Guide for OpenFOAM 4, in section "4.5.1.4 Geometric-algebraic multi-grid solvers" you can find more details on how to configure GAMG: https://cfd.direct/openfoam/user-gui...-1490004.5.1.4 The parameter I'm looking for is "nCellsInCoarsestLevel", which is indicated to have a default of 10... so, no, this isn't the reason for the crash. ..... OK, after a lot of attempts to solve this issue, including the use of PCG for solving "p_rgh" and using "fixedFluxPressure" on the top boundary, I have a good reason to believe that one of the problems has to do with how the top boundary is defined in the mesh, because having a boundary with a corner along Z, could be one of the reasons why this is giving serious problems. On the other hand... now I remember why this is having issues... It's because the solver buoyantSimpleFoam assumes that the "p" field is properly defined and accounts for the hydrostatic pressure. If you look into the source code file "$FOAM_SOLVERS/heatTransfer/buoyantSimpleFoam/createFields.H", you will see this line: Code:
// Force p_rgh to be consistent with p p_rgh = p - rho*gh; The solution is to change the code to this: Code:
// Force p_rgh to be consistent with p //p_rgh = p - rho*gh; p = p_rgh + rho*gh; This is actually a known limitation of these solvers... let me see if I can find the bug reports for it... strange, I can only find this one: https://bugs.openfoam.org/view.php?id=2132 I don't remember seeing this fixed in OpenFOAM 5, at least for this solver. Best regards, Bruno
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 16:13 |
A simple tube FSI case can't converge | stickjohnson | OpenFOAM | 1 | June 23, 2014 22:42 |
[blockMesh] Very simple case, weird blockMesh | sharonyue | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2013 05:58 |
Simple test case for k-epilon model | mathletic | Main CFD Forum | 2 | September 28, 2012 04:04 |
Working with compressed case and data files | Darrell Anthony Egarr | FLUENT | 0 | December 15, 2002 08:05 |
