Positive or negative values of Lambda2 for vortex structure visualization?
Like Tree1Likes
  • 1 Post By vidyadhar
Old   May 8, 2017, 10:10
Default Positive or negative values of Lambda2 for vortex structure visualization?
vidyadhar
vidyadhar is on a distinguished road
I want to visualize the vortex structures in the flow through a pipe junction having square cross-section.
If I select negative value of Lambda-2 criterion in paraview, I find structures near the walls. For positive values of Lambda2, the structures are away from the walls.
Also,
I am getting same pattern of vortex structures with positive values of Lambda2 which I do get with positive value of Q criterion.
So,
1) should I select positive values of Lambda2 or negative values?
2)Do Q- and Lambda2- criteria give similar structures?
Thanks in advance!!!
vidyadhar is offline   Reply With Quote
Old   November 27, 2019, 00:12
Jianrui Zeng
calf.Z is on a distinguished road
I am still interested in this topic. Can anyone describe more details about Q- or lambda-2 criterium. Can I just use postProcess -func Lamdba2 to calculate it and visualized it through paraview ?
calf.Z is offline   Reply With Quote
Old   November 27, 2019, 01:45
vidyadhar
Hello Zeng,
You may find other suitable answers also.
Any way you may please look at
1.https://www.researchgate.net/post/Po...confined_flows
2. https://www.researchgate.net/post/Ho...n_Ansys_Fluent
calf.Z likes this.
Old   November 27, 2019, 09:03
Jianrui Zeng
Originally Posted by vidyadhar View Post
Hello Zeng,
Thank you for the valuable information!
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Fluid Structure interface - Negative Volume mohammad.cheikh FLUENT 2 January 23, 2014 15:49
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
positive and negative torque forces Wei-Haur Lam CFX 0 March 19, 2008 08:45
How to enforce positive values Ning Main CFD Forum 10 August 20, 2000 01:10
