SixDoFRigidBodyMotion Solver applied to multiple rotors |
Vineeth Maniyara
Rep Power: 0 ![]() |
Dear Foamers,
Ive recently setup and successfully run a case of a sliding mesh rotor within a simple channel flow using the SixDoFRigidBodyMotion solver defined in the /constants/dynamicMeshDict . I am currently trying to extend this to a multiple rotor case wherein I would have at least 2 rotors run as independent FSI solutions. Is such a functionality pre-existent within the current SixDoFRigidBodyMotion solver? Does there exist an extension I am not aware of? Thanks and Best Regards, Vin |
Rep Power: 9 ![]() |
I am trying to do simulation with two parallel propellers. Did you manage to solve your case? Thank you! |
Can't get data from OpenFoam to external solver using externalCoupled | perry | OpenFOAM Running, Solving & CFD | 4 | May 26, 2014 08:09 |
blockCoupled solver for multiple regions | benk | OpenFOAM | 2 | February 13, 2014 22:35 |
MRF to solidBodyMotionFvMesh with multiple rotors | Toorop | OpenFOAM Pre-Processing | 3 | August 8, 2013 02:27 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 18:06 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
