NO Moving Probes for Moving Mesh in Foam Extend 4.0
Like Tree6Likes
  • 1 Post By alia
  • 3 Post By alia
  • 1 Post By alia
  • 1 Post By alia
Old   April 6, 2017, 14:08
Unhappy NO Moving Probes for Moving Mesh in Foam Extend 4.0
alia's Avatar
Ali Aghaei
alia is on a distinguished road
Dear Foamers,
In OpenFOAM we are able to define probes that are moving with a moving mesh which is very useful for example in pressure probing of moving objects. this capability unfortunately I think is not available in Foam-Extend versions, which is a very big flaw especially for FSI applications.
the following lines which are in probes.H files of OpenFOAM are missing in Foam Extend versions:
//- Fixed locations, default = yes
//  Note: set to false for moving mesh calculations where locations
//        should move with the mesh
//- Interpolation scheme name
//  Note: only possible when fixedLocations_ is true
word interpolationScheme_;       bool fixedLocations_;
anyone knows how to resolve this issue? or can we fix it in probes.H and probes.C files?
Thank you
Ali
Bazinga likes this.
alia is offline   Reply With Quote
Old   September 19, 2017, 05:59
Default Solved
alia's Avatar
Ali Aghaei
I did solve this problem a while ago and I want to share it here.
it is quite simple to have probes moving with mesh. you just need to comment out the following lines from the probes.C file
    if (mesh.moving() || mesh.changing())
        cellList_.clear();
        findCells(mesh);
cheers
pi06jl6, Bazinga and fcl like this.
Old   June 7, 2018, 06:15
Bazinga is on a distinguished road
Is there anything else I need to do? I commented out the part of the code but the probes are still not moving with the mesh although I added "fixedLocations false" in the controlDict.
Bazinga is offline   Reply With Quote
Old   June 7, 2018, 06:36
alia's Avatar
Ali Aghaei
Dear Bazinga, you need to copy the probes directory in your FOAM_USER directory and rename the class to create a new class like myProbe. after compiling it should work. make sure you type the name of the new probe in the probe definition in controlDict.
I just put my adjusted probe code here. I hope it helps.
Cheers
Ali
Bazinga likes this.
Old   June 7, 2018, 07:10
Thanks for the fast reply. I will try it, but I am not too familiar with this. If possible, to make things a bit easier, can you share your code?
edit: Thank you so much
Old   June 7, 2018, 07:23
alia's Avatar
Ali Aghaei
I just edited my last reply and attached the code
Cheers
Bazinga likes this.
Old   June 25, 2018, 10:24
gigliagarf is on a distinguished road
I also am having trouble with this exact issue, I tried your approach with commenting out the section and duplicating the probes folder to make myprobes, however it didn't compile correctly. I also tried just downloading your folder to my $WM_PROJECT_USER_DIR and typing wmake within it, without success. Do you have any suggestions as to what I might be doing wrong? I have fsi foam and waves2foam installed as well, do you think they have broken the functionality or your fix?
gigliagarf is offline   Reply With Quote
fixedlocations, foam extend 4.0, moving mesh, probes
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 14:37
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
