Cannot read decomposeParDict during mpirun
Like Tree2Likes
  • 1 Post By alexeym
  • 1 Post By alexeym
Old   April 3, 2017, 00:33
Default Cannot read decomposeParDict during mpirun
Mike
MikeC is on a distinguished road
I'm trying to setup a local compute cluster (currently just 2 nodes), using ubuntu on master & slave, openmpi, and openfoam 4.1. I've shared a folder on the master '/nfs/TEST/' with the slave and verified that read/write access works. I've setup the environmental variables on the slave to work in non-interactive mode. If I execute
foamJob -s -p rhoCentralFoam
from the slave where hostfile just points to the slave, the job runs fine. Same goes if I execute from the master and have the hostfile only point to the master. However, if I execute from the master and have the host file point to the slave (or visa versa), I get the following error:
[0] --> FOAM FATAL ERROR:
[0] Cannot read "/home/michael/system/decomposeParDict"
My working directory is '/nfs/TEST' though (my username on both nodes is 'michael'), and I had already decomposed the case. If I execute
mpirun -np 16 -hostfile machines rhoCentralFoam -parallel > log
it fails, saying "mpirun was unable to find the specified executable file". What is going on?
MikeC is offline   Reply With Quote
Old   April 3, 2017, 04:10
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
How do you execute that line (mpirun -np 16 ...)? Somehow you working directory becomes $HOME instead of /nfs/TEST (and so solver tries to search for decomposer dictionary in /home/michael/system). I have seen this behaviour in batch systems, do not know if it is your case.
alexeym is offline   Reply With Quote
Old   April 3, 2017, 09:18
Mike
Hi!
I'm just typing it into a standard bash terminal. I haven't setup any special batch system.
Old   April 3, 2017, 16:51
Alexey Matveichev
What if you add -case flags? For example like this:
-case $(pwd)
Or you can put real case path instead of pwd invocation.
Does you setup keep current working directory across nodes? I.e. what is cwd after you ssh on slave?
wht likes this.
Old   April 4, 2017, 00:58
Mike
When I add the case flag to the mpirun command, it errors saying there is a bad input to mpi. If I add it to the foamJob command, I get the same error as before. That is a good idea though - when I ssh into a node it takes me to the home directory, not the common working directory. How do I fix that?
Old   April 4, 2017, 02:56
Alexey Matveichev
It would be easier to diagnose, if you post error using copy-paste. What is the output of
mpirun -np 16 -hostfile machines rhoCentralFoam -parallel -case /nfs/TEST > log
Concerning your last question: https://www.google.com/search?q=ssh+preserve+cwd.
Old   April 4, 2017, 10:01
Mike
The full error message is:
mpirun was unable to find the specified executable file, and therefore
did not launch the job.  This error was first reported for process
rank 0; it may have occurred for other processes as well.
NOTE: A common cause for this error is misspelling a mpirun command
      line parameter option (remember that mpirun interprets the first
      unrecognized command line token as the executable).
Node:       sokar
Executable: rhoCentralFoam
16 total processes failed to start
Regarding preserving the cwd across ssh, I had tried to do that using SendEnv and AcceptEnv (per https://superuser.com/questions/4685...sh/46888#46888) but it didn't seem to work. Wasn't sure what the proper way of doing it is.
Old   April 4, 2017, 11:19
Alexey Matveichev
The error is rather self-explanatory, no? Since mpirun can not find rhoCentralFoam, I guess, there is a problem with environment.
Since AcceptEnv (https://linux.die.net/man/5/sshd_config) and SendEnv (https://linux.die.net/man/5/ssh_config) both accept wildcards, you can use "SendEnv *" and "AcceptEnv *" to transfer all environment. You can use "SendEnv FOAM_* PATH PWD LD_LIBRARY_PATH" (and AcceptEnv), if you would like to limit number of variables transferred. You have to modify sshd_config on slave and ssh_config on master, restart sshd on slave.
olegrog likes this.
Old   April 5, 2017, 01:29
Mike
Yep, that fixed the problem. Thanks for your help!
Old   August 21, 2018, 09:17
Default mpirun was unable to find the executable
Rishab.G.Hombal
Rishab is on a distinguished road
Hi
im new to openfoam we have a cluster with one master node nd a client node with passwordless ssh enabled nd running openfoamv6 on both the machines with the case directories present in both nodes i get the following error when i try to run the case with foamJob
rank 3; it may have occurred for other processes as well.
Node: client1
Executable: /opt/openfoam6/bin/foamJob
so what exactly did you do to set the environments properly?
regards,
Rishab
Rishab is offline   Reply With Quote
Old   June 30, 2022, 15:59
Mateus Grassano Lattari
MateusLatt is on a distinguished road
Hi, I did exactly this but the error remains. I also tried the full paths:
"mpirun -np 24 -hostfile hosts --use-hwthread-cpus -wdir `pwd` -x LD_LIBRARY_PATH=/usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/bin:/usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/lib:/usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/lib/sys-openmpi -x PATH=/usr/lib/x86_64-linux-gnu/openmpi/bin:/home/matt/OpenFOAM/matt-v2112/platforms/linux64GccDPInt32Opt/bin:/usr/lib/openfoam/openfoam2112/site/2112/platforms/linux64GccDPInt32Opt/bin:/usr/lib/openfoam/openfoam2112/platforms/linux64GccDPInt32Opt/bin:/usr/lib/openfoam/openfoam2112/bin:/usr/lib/openfoam/openfoam2112/wmake:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin -x FOAM_RUN=/home/openfoam/rotatingSphere -x HOME=/home/openfoam -x FOAM_SIGFPE=1 -x FOAM_ETC=/usr/lib/openfoam/openfoam2112/etc pimpleFoam"
But when I try this the controlDict is not found
Originally Posted by alexeym View Post
MateusLatt is offline   Reply With Quote
Read in "Mean" values during runTime ChrisWe OpenFOAM Programming & Development 4 March 31, 2018 23:48
[OpenFOAM.org] MPI compiling and version mismatch pki OpenFOAM Installation 7 June 15, 2015 17:21
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 11:52
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 10:46
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 18:51
