Trying to manipulate rough wall function OpenFOAM
Like Tree1Likes
  • 1 Post By hxaxtma
Old   April 2, 2017, 08:22
Default Trying to manipulate rough wall function OpenFOAM
leotsixri's Avatar
Leonidas
leotsixri is on a distinguished road
Hi to all,
I am trying to implement surface roughness in a wall by manipulating the /0/nut file directory but I receive the following error after running simpleFoam:
Starting time loop
Time = 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.005883928, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 7.677366e-109, Final residual = 7.677366e-109, No Iterations 0
smoothSolver:  Solving for Uz, Initial residual = 1.535473e-108, Final residual = 1.535473e-108, No Iterations 0
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:?
#4  Foam::DICSmoother::DICSmoother(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
#5  Foam::lduMatrix::smoother::addsymMatrixConstructorToTable<Foam::DICSmoother>::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&) at ??:?
#6  Foam::lduMatrix::smoother::New(Foam::word const&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::dictionary const&) at ??:?
#7  Foam::GAMGSolver::initVcycle(Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::lduMatrix::smoother>&, Foam::Field<double>&, Foam::Field<double>&) const at ??:?
#8  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#9  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#10  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#11  Foam::fvMatrix<double>::solve() at ??:?
#12  ? at ??:?
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14  ? at ??:?
Floating point exception (core dumped)
Is the error relevant to the p file directory? The case worked perfectly before changing the nut file.
Any help?
Regards, Leonidas
Last edited by wyldckat; April 30, 2017 at 13:19. Reason: Added [CODE][/CODE] markers
leotsixri is offline   Reply With Quote
Old   April 3, 2017, 03:15
hxaxtma is on a distinguished road
Floating Point is mostly caused by wrong setting of BCs. So check them again.
leotsixri likes this.
hxaxtma is offline   Reply With Quote
Old   April 3, 2017, 07:21
leotsixri's Avatar
Leonidas
Thanks for the reply.
This might was due to false z dimension at blockMeshDict but it is running now. I am waiting to see the differences in the results!
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? randomid OpenFOAM Community Contributions 1 August 27, 2010 06:15
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
