Negative torque with PimpleDyMFoam
Like Tree2Likes
  • 2 Post By kmallick
Old   March 28, 2017, 11:12
Default Negative torque with PimpleDyMFoam
Kaushik Mallick
kmallick is on a distinguished road
I am simulating a vertical axis wind turbine (vawt) in OpenFoam using sliding mesh AMI. The turbine is a set of 3 twisted savonius style blades. The axis of rotation is the z axis. The stator domain is 19D x 14D x 14D where D is the turbine diameter. When I run my analysis with stuck rotor using SimpleFoam I get the correct positive torque around the z axis when equilibrium is reached However when I run a dynamic analysis with positive rotation speed around the z axis using PimpleDyMFoam, I consistently get negative torque and negative torque coefficient, even after the analysis has continued past a number of full 360 deg. rotations of the turbine. The only time I get a positive torque is when I run the PimpleDyMFoam analysis at zero or very low rotational speed.
I have checked all my parameters, boundary conditions, mesh quality, fvsolution and fvscheme settings and I just cannot seem to pinpoint what could be causing the negative torque. I have checked the log file and Courant number is always below 1.
I am anxious to seek out some help and suggestions from the forum.
Below are some pictures of my model and the relevant system files.
Here is my dynamicMeshDict:
HTML Code:
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      dynamicMeshDict;
dynamicFvMesh   dynamicMotionSolverFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solver solidBody;
solidBodyCoeffs
    cellZone        rotor;
    solidBodyMotionFunction  rotatingMotion;
    rotatingMotionCoeffs
        origin        (0 0 0);
        axis          (0 0 1);
        omega         7; // rad/s
My controlDict:
HTML Code:
|  \\    /   O peration     | Version:  2.2.2                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pimpleDyMFoam;
startFrom       latestTime;
//startTime       0;
stopAt          endTime;
endTime          20;
deltaT          .0025;
writeControl    adjustableRunTime;
writeInterval   0.01;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  yes
maxCo           1.0;
libs
    "libincompressibleTurbulenceModels.so"
functions
    #includeFunc residuals
    #includeFunc Q
    #include "surfaces"
    #include "forces"
    #include "wallPressure"
My forces file:
HTML Code:
forces
    type          forces;
    libs          ("libforces.so");
    writeControl  timeStep;
    timeInterval  1;
    log           yes;
    patches       ("blades.*");
    rho           rhoInf;     // Indicates incompressible
    log           true;
    rhoInf        1;          // Redundant for incompressible
    CofR          (0 0 0);    // Rotation around centre line of turbine
forceCoeffs
    type forceCoeffs;
    functionObjectLibs ("libforces.so");
    timeInterval  1;
    rho           rhoInf;
    CofR          (0 0 0);
    pitchAxis     (0 0 1);
    dragDir       (1 0 0);
    liftDir       (0 1 0);
    magUInf       7;
    lRef	  1.;
    Aref	  2.44;
My fvSolution:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-8;
        relTol          0.01;
        smoother        GaussSeidel;
        cacheAgglomeration no;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
        maxIter         50;
    pFinal
        $p;
        tolerance       1e-06;
        relTol          0;
    pcorr
        $p
        tolerance       0.02;
        relTol          0;
    "(U|k|omega)"
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-06;
        relTol          0.1;
	maxIter 100;
	minIter 1;
    "(U|k|omega)Final"
        $U;
        tolerance       1e-06;
        relTol          0;
	maxIter 100;
	minIter 1;
    cellDisplacement
        solver          GAMG;
        tolerance       1e-5;
        relTol          0;
PIMPLE
    correctPhi          no; //was no
    nOuterCorrectors    1;  //was 2
    nCorrectors         2;
    nNonOrthogonalCorrectors 0;
    pRefCell            0;
    pRefValue           0;
    turbOnFinalIterOnly on;
    consistent          true;
	residualControl
		"(p|U)"
			tolerance 1e-4;
			relTol 0;
		"(k|omega)"
			tolerance 1e-4;
			relTol 0;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.9;
        k               0.7;
        omega           0.7;
My fvSchemes:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
    //default         CrankNicolson 0.5;
wallDist
	method meshWave;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    //grad(U)         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    default             none;
    //div(phi,U)          Gauss upwind;
    //div(phi,U)              Gauss linearUpwindV grad(U);
    div(phi,U)      Gauss linearUpwind grad(U);
    div(phi,k)      Gauss upwind;
    div(phi,omega)    Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
//    default         Gauss linear corrected;
    default         Gauss linear limited corrected 0.33;
interpolationSchemes
    default         linear;
snGradSchemes
//    default         corrected;
    default         limited corrected 0.33;
fluxRequired
    default         no;
    pcorr           ;
    p               ;
wallDist
    method meshWave;
maasyraf3 and Joe.in like this.
kmallick is offline   Reply With Quote
Old   March 22, 2018, 16:07
Joe
Joe.in is on a distinguished road
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
solver solidBody;
solidBodyCoeffs
    cellZone        rotor;
        origin        (0 0 0);
        axis          (0 0 1);
        omega         7; // rad/s
My controlDict:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
//startTime       0;
stopAt          endTime;
endTime          20;
deltaT          .0025;
writeInterval   0.01;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
timeFormat      general;
timePrecision   6;
adjustTimeStep  yes
maxCo           1.0;
libs
functions
    #includeFunc Q
    #include "surfaces"
    #include "forces"
My forces file:
HTML Code:
forces
    type          forces;
    timeInterval  1;
    log           yes;
    log           true;
forceCoeffs
    type forceCoeffs;
    timeInterval  1;
    rho           rhoInf;
    CofR          (0 0 0);
    pitchAxis     (0 0 1);
    dragDir       (1 0 0);
    liftDir       (0 1 0);
    magUInf       7;
    lRef	  1.;
    Aref	  2.44;
My fvSolution:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-8;
        relTol          0.01;
        mergeLevels     1;
        maxIter         50;
    pFinal
        $p;
        tolerance       1e-06;
        relTol          0;
    pcorr
        $p
        tolerance       0.02;
        relTol          0;
    "(U|k|omega)"
        tolerance       1e-06;
        relTol          0.1;
	maxIter 100;
	minIter 1;
    "(U|k|omega)Final"
        $U;
        tolerance       1e-06;
        relTol          0;
	maxIter 100;
	minIter 1;
    cellDisplacement
        solver          GAMG;
        tolerance       1e-5;
        relTol          0;
PIMPLE
    nCorrectors         2;
    pRefCell            0;
    pRefValue           0;
    consistent          true;
	residualControl
		"(p|U)"
			tolerance 1e-4;
			relTol 0;
		"(k|omega)"
			tolerance 1e-4;
			relTol 0;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.9;
        k               0.7;
        omega           0.7;
My fvSchemes:
HTML Code:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
wallDist
	method meshWave;
gradSchemes
divSchemes
    default             none;
laplacianSchemes
    default         linear;
snGradSchemes
fluxRequired
    default         no;
    pcorr           ;
    p               ;
wallDist
    method meshWave;
I too am encountering the same problem. I've got a similar case (VAWT) and the Moments (torque) in the z axis are negative or fluctuating more on the negative side and hence the turbine doesn't produce any power.
If someone could help with this regard, pls do reply.
Joe
Engineering Undergrad.
Joe.in is offline   Reply With Quote
Old   April 1, 2018, 16:51
Carlos
Thyriel is on a distinguished road
I am facing a similar issue with my VAWT simulation. Sadly I don't have any clarification for you but hopefully you will be able to clarify something for me.
My forces setup resembles your own, i am curious however, if the parameters for the calculation of lift and drag account for the movement of the blades, as in will the lift and drag direction vary for the purposes of the calculation? if not, then how are you obtaining the forces required to compute the torque?
Thyriel is offline   Reply With Quote
Old   April 5, 2018, 12:29
Kaushik Mallick
The forces and moments in my VAWT simulation are computed using OpenFOAm's libforces library. There are many tutorials and examples on the intranet and forums. Hopefully you can resolve your problems soon.
pimpledymfoam, torque, vawt
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
