Simulations are not converging in OpenFOAM for many elements (more than 1 000 000)
Like Tree1Likes
  • 1 Post By tiam
Old   March 27, 2017, 08:15
Post Simulations are not converging in OpenFOAM for many elements (more than 1 000 000)
silvai is on a distinguished road
Hi OpenFOAM people!
I am simulating blood flow in a 3D artery, in OpenFOAM code, and unfortunatly, my simulations are not converging for many elements (more than 1 000 000 like you can see below in the "Boundary" file). And many elements are necessary for mt work. I know this is a problem element, since for a number of elements much lower (5 or 10 times) the simulation converges.
In the "boundary" file, the elements are:
wall-interior
type wall;
nFaces 59205;
startFace 1248069;
inlet_lca
type patch;
nFaces 2625;
startFace 1307274;
outlet_lda
type patch;
nFaces 2130;
startFace 1309899;
outlet_lcx
type patch;
nFaces 2214;
startFace 1312029;
In the "controlDict" file:
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 3.0;
deltaT 0.001;
writeControl timeStep;
writeInterval 10;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
In "svSchemes" file:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) leastSquares;
divSchemes
default none;
div(phi,U) Gauss linear;
laplacianSchemes
default none;
laplacian(nu,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(U) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
In "fvSolution" file:
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-05;
relTol 0;
PISO
nCorrectors 4;
nNonOrthogonalCorrectors 2;
Someone have any sugestion what parameters I should modify for that simulations can converge for so many elements ( and also for running faster)?
I would be very happy and grateful with your answers and sugestions.
Last edited by wyldckat; April 30, 2017 at 13:17. Reason: Added [CODE][/CODE] markers
silvai is offline   Reply With Quote
Old   March 27, 2017, 09:31
Timofey Mukha
tiam is on a distinguished road
What type of simulation is this? Laminar, RANS, LES?
What sticks out directly is that you use linear interpolation of the convective fluxes:
This is not a bounded scheme, so this may very well lead to problems.
Using the multigrid solver for pressure might speed up your computations.
vsb likes this.
tiam is offline   Reply With Quote
Old   March 28, 2017, 10:08
Post
Thank you very much for your answer.
The simulations are laminar and transient. I reduced the time step deltaT to 0,0005 and, now, simulations seems to converge, but take so many time!
I think that your suggestion of using multi-grid solver GAMG insead of PCG is a good suggestion. I will try this in following simulations.
Old   March 28, 2017, 10:30
Post
I will also try a bounded scheme. Thank you very much.
Old   March 31, 2017, 08:19
Post
Hi OpenFoam people!
The simulations are, now, converging much more faster using the multi-grid solver GAMG for Pressure. And, I also used a bounded scheme for div(phi, U). The blood flow simulations using a simple model to define blood rheology and conservative equations implemented in OpenFoam, are, now, running faster (only 1 day!) for more than 1 000 000 elements.
Also, the results are accurate since they are coincident with that obtained through the comercial code ANSYS.
Thank you very much TIAM from Sweden!!
However.... I also implemented a complex blood rheology to define in a more accurate way the blood physical properties. This properties are defined through a constitutive equation, which conservative equations depends on this constitutive equation. So, since OpenFoam is an Open Source Code, I modified the conservative equations and implemented the constitutive equation (defining blood rheology more correctly). This code was already validated in 2D dimension of the artery (with much less elements!).
In this way... My question is....
I want to simulate the previous case, in 3D dimension with more than 1 000 000 elements, faster. The simulations are too low... Since, now, this code is more complex than the first one.
Do you have any suggestion for that simulations can run a lot more faster, for this case, and do not have the risk to diverge?
The "boundary" file with many elements is:
wall-interior
type wall;
nFaces 59205;
startFace 1248069;
inlet_lca
type patch;
nFaces 2625;
startFace 1307274;
outlet_lda
type patch;
nFaces 2130;
startFace 1309899;
outlet_lcx
type patch;
nFaces 2214;
startFace 1312029;
The "controlDict" file than I am using is:
application elasticshearthinFluidFoam;
startTime 0;
stopAt endTime;
endTime 3.0;
deltaT 0.0005;
writeControl adjustableRunTime;
writeInterval 0.01;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
graphFormat raw;
runTimeModifiable yes;
adjustTimeStep on;
maxCo 0.8;
maxDeltaT 0.001;
The "fvSchemes" file is:
ddtSchemes
default Euler;
gradSchemes
grad(p) Gauss linear;
grad(U) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss SFCD;
div(phi,detAfirst) Gauss Minmod;
div(phi,detAsecond) Gauss Minmod;
div(phi,detAthird) Gauss Minmod;
div(phi,detAfourth) Gauss Minmod;
div(phi,taufirst) Gauss Minmod;
div(phi,tausecond) Gauss Minmod;
div(phi,tauthird) Gauss Minmod;
div(phi,taufourth) Gauss Minmod;
div(tau) Gauss linear;
laplacianSchemes
default none;
laplacian(etaPEff,U) Gauss linear corrected;
laplacian(etaPEff+etaS,U) Gauss linear corrected;
default linear;
interpolate(HbyA) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
The "fvSolution" file is:
solvers
p
solver GAMG;
preconditioner
// preconditioner Cholesky;
preconditioner FDIC;
cycle W-cycle;
policy AAMG;
nPreSweeps 0;
nPostSweeps 2;
groupSize 4;
minCoarseEqns 20;
nMaxLevels 100;
scale off;
smoother ILU;
tolerance 1e-05;
relTol 0;
minIter 0;
maxIter 800;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 100;
mergeLevels 1;
smoother GaussSeidel;
U
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
nCellsInCoarsestLevel 4;
mergeLevels 1;
smoother DILUGaussSeidel;
detAfirst
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
detAsecond
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
detAthird
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
detAfourth
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
taufirst
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
tausecond
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
tauthird
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
taufourth
solver BICCG;
preconditioner
tolerance 1e-6;
relTol 0;
minIter 0;
maxIter 1000;
mergeLevels 1;
PISO
nCorrectors 1;
pRefCell 200;
pRefValue 10000;
// nCorrectors 2;
// nNonOrthogonalCorrectors 0;
// pRefCell 0;
// pRefValue 0;
relaxationFactors
p 0.3;
U 0.5;
detAfirst 0.3;
detAsecond 0.3;
detAthird 0.3;
detAfourth 0.3;
taufirst 0.3;
tausecond 0.3;
tauthird 0.3;
taufourth 0.3;
// p 0.3;
// U 0.5;
// tau 0.3;
Apparently, the simulations are converging with this process, but I think that I will wait one week for the results... Do someone suggest to modify any parameter to run faster and with convergence?
I will be greatful! Thank you very much!
Old   April 1, 2017, 06:16
Derek Mitchell
derekm is on a distinguished road
have you looked at this ?
http://www.arek.pajak.info.pl/wp-con...ndtricksOF.pdf
things like changing tolerances, relaxation factors , non-orthogonal correctors
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   April 3, 2017, 09:33
Post
Hi!
I looked the pdf file that you suggested.
In div(phi,U) instead of Gauss SFCD, I am trying Gauss MUSCL. However, it does not speed up the process. It continues very slow!!!
I know that there are so many equations and a very refined 3D mesh.
I also read that reducing the tolerance in pressure (p) for 1e-4 with relTol 1e-2 can speed up.
But it continues too slow!!
Someone know... How can I SPEED UP with CONVERGENCE?
(The original files are above.)
I am thinking on changing the "controlDict" file. I would like to fix a deltaT (equal to 0.0005 for e.g.) instead of using adjustableRunTime. Using the adjustableRunTime, the deltaT becomes around 3e-6, thatīs why I think it becomes too slow!!
Someone know... For these type of simulation (original files above) if I am correct and how to change for a fixed deltaT in this case?
I will be very greatful!
many elements, not convergence, openfoam
Simulations are not converging for many elementes (more than 1 000 000) silvai OpenFOAM Running, Solving & CFD 5 April 20, 2017 08:16
Ansys SIG$ILL error loth ANSYS 3 December 24, 2015 06:31
[Other] can prism elements exist in 2D mesh in openfoam shuoxue OpenFOAM Meshing & Mesh Conversion 2 June 21, 2013 00:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
