p_rgh initial residual no change with different settings
Like Tree1Likes
  • 1 Post By MaryBau
Old   March 15, 2017, 06:18
Default p_rgh initial residual no change with different settings
Manu Chakkingal
manuc is on a distinguished road
Hello All
I am doing a conjugate heat transfer problem with 2 regions:
1. Air
2. plate
The issue I face
The initial pressure residual doesn't change
Region: air Courant Number mean: 0.025093108 max: 0.40052825
Region: plate Diffusion Number mean: 3.7111592e-07 max: 7.8177845e-07
deltaT = 0.0071130688
Time = 5.8941
Solving for fluid region air
DILUPBiCG:  Solving for T, Initial residual = 0.0015977895, Final residual = 7.1757907e-08, No Iterations 2
max(T) [0 0 0 1 0 0 0] 307.07585
GAMG:  Solving for p_rgh, Initial residual = 0.29225662, Final residual = 0.00014979926, No Iterations 5
time step continuity errors : sum local = 5.6147294e-07, global = -3.626898e-21
GAMG:  Solving for p_rgh, Initial residual = 0.29228288, Final residual = 0.0001558772, No Iterations 5
time step continuity errors : sum local = 5.8412794e-07, global = 1.6563367e-21
GAMG:  Solving for p_rgh, Initial residual = 0.29228292, Final residual = 0.0001561875, No Iterations 5
time step continuity errors : sum local = 5.8528492e-07, global = -1.0209638e-20
Solving for solid region plate
DICPCG:  Solving for T, Initial residual = 0.00033675569, Final residual = 1.8134589e-10, No Iterations 1
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77487 max(T) [0 0 0 1 0 0 0] 300.23137
DILUPBiCG:  Solving for T, Initial residual = 0.00086688609, Final residual = 5.8887298e-08, No Iterations 2
max(T) [0 0 0 1 0 0 0] 307.07154
GAMG:  Solving for p_rgh, Initial residual = 0.28837172, Final residual = 0.00025808741, No Iterations 5
time step continuity errors : sum local = 9.6388206e-07, global = -3.7600441e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28839029, Final residual = 0.00026193496, No Iterations 5
time step continuity errors : sum local = 9.7833528e-07, global = 2.6948758e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28839033, Final residual = 0.00026213134, No Iterations 5
time step continuity errors : sum local = 9.7907289e-07, global = -2.6309657e-21
DICPCG:  Solving for T, Initial residual = 7.843695e-07, Final residual = 7.843695e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.7751 max(T) [0 0 0 1 0 0 0] 300.23089
DILUPBiCG:  Solving for T, Initial residual = 0.00047949062, Final residual = 3.5964391e-08, No Iterations 2
max(T) [0 0 0 1 0 0 0] 307.06885
GAMG:  Solving for p_rgh, Initial residual = 0.28572757, Final residual = 0.0002516689, No Iterations 6
time step continuity errors : sum local = 9.4478046e-07, global = -6.5188299e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28574053, Final residual = 0.00025317592, No Iterations 6
time step continuity errors : sum local = 9.5044118e-07, global = 4.7719539e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28574058, Final residual = 0.00025325281, No Iterations 6
time step continuity errors : sum local = 9.5072952e-07, global = 3.728089e-22
DICPCG:  Solving for T, Initial residual = 1.2740441e-06, Final residual = 6.9627797e-13, No Iterations 1
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77523 max(T) [0 0 0 1 0 0 0] 300.23051
DILUPBiCG:  Solving for T, Initial residual = 0.0002695116, Final residual = 2.4592606e-08, No Iterations 2
max(T) [0 0 0 1 0 0 0] 307.06714
GAMG:  Solving for p_rgh, Initial residual = 0.2840107, Final residual = 0.00027359005, No Iterations 6
time step continuity errors : sum local = 1.0255247e-06, global = 1.0332132e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28401878, Final residual = 0.00027452449, No Iterations 6
time step continuity errors : sum local = 1.0290257e-06, global = 7.5413915e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28401879, Final residual = 0.00027457255, No Iterations 6
time step continuity errors : sum local = 1.0292054e-06, global = 1.4401075e-20
DICPCG:  Solving for T, Initial residual = 2.5904077e-07, Final residual = 2.5904077e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77529 max(T) [0 0 0 1 0 0 0] 300.23051
DILUPBiCG:  Solving for T, Initial residual = 0.00014960406, Final residual = 6.311792e-07, No Iterations 1
max(T) [0 0 0 1 0 0 0] 307.06612
GAMG:  Solving for p_rgh, Initial residual = 0.28286788, Final residual = 0.00019960496, No Iterations 7
time step continuity errors : sum local = 7.4439393e-07, global = -5.7732121e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28287327, Final residual = 0.00020010332, No Iterations 7
time step continuity errors : sum local = 7.4626443e-07, global = -2.5670556e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28287328, Final residual = 0.00020013241, No Iterations 7
time step continuity errors : sum local = 7.4637356e-07, global = 5.006291e-21
DICPCG:  Solving for T, Initial residual = 4.0860369e-07, Final residual = 4.0860369e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77533 max(T) [0 0 0 1 0 0 0] 300.2305
DILUPBiCG:  Solving for T, Initial residual = 8.915537e-05, Final residual = 7.1263867e-07, No Iterations 1
max(T) [0 0 0 1 0 0 0] 307.06574
GAMG:  Solving for p_rgh, Initial residual = 0.2821784, Final residual = 0.00020594294, No Iterations 7
time step continuity errors : sum local = 7.6754809e-07, global = 1.5231907e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28218178, Final residual = 0.0002062782, No Iterations 7
time step continuity errors : sum local = 7.6880604e-07, global = 3.6428755e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28218178, Final residual = 0.00020629814, No Iterations 7
time step continuity errors : sum local = 7.6888083e-07, global = 1.3793929e-20
DICPCG:  Solving for T, Initial residual = 4.5828655e-07, Final residual = 4.5828655e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77536 max(T) [0 0 0 1 0 0 0] 300.2306
DILUPBiCG:  Solving for T, Initial residual = 4.7827065e-05, Final residual = 2.2985107e-07, No Iterations 1
max(T) [0 0 0 1 0 0 0] 307.06551
GAMG:  Solving for p_rgh, Initial residual = 0.28171533, Final residual = 0.00020993592, No Iterations 7
time step continuity errors : sum local = 7.8213501e-07, global = -9.3521776e-21
GAMG:  Solving for p_rgh, Initial residual = 0.2817176, Final residual = 0.00021015795, No Iterations 7
time step continuity errors : sum local = 7.8296837e-07, global = -4.0582912e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28171761, Final residual = 0.00021017166, No Iterations 7
time step continuity errors : sum local = 7.830198e-07, global = 3.5363587e-21
DICPCG:  Solving for T, Initial residual = 4.9787724e-07, Final residual = 4.9787724e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77538 max(T) [0 0 0 1 0 0 0] 300.23065
DILUPBiCG:  Solving for T, Initial residual = 2.6090939e-05, Final residual = 1.1814457e-07, No Iterations 1
max(T) [0 0 0 1 0 0 0] 307.06537
GAMG:  Solving for p_rgh, Initial residual = 0.28140271, Final residual = 0.00021239068, No Iterations 7
time step continuity errors : sum local = 7.9111348e-07, global = -2.417932e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28140414, Final residual = 0.00021253976, No Iterations 7
time step continuity errors : sum local = 7.9167325e-07, global = 1.5657974e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28140414, Final residual = 0.00021254929, No Iterations 7
time step continuity errors : sum local = 7.9170899e-07, global = 1.101384e-20
DICPCG:  Solving for T, Initial residual = 5.222418e-07, Final residual = 5.222418e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77539 max(T) [0 0 0 1 0 0 0] 300.23068
DILUPBiCG:  Solving for T, Initial residual = 1.4511823e-05, Final residual = 6.5523126e-08, No Iterations 1
max(T) [0 0 0 1 0 0 0] 307.06528
GAMG:  Solving for p_rgh, Initial residual = 0.28119291, Final residual = 0.00021391702, No Iterations 7
time step continuity errors : sum local = 7.9670066e-07, global = -9.3841326e-21
GAMG:  Solving for p_rgh, Initial residual = 0.28119381, Final residual = 0.00021401911, No Iterations 7
time step continuity errors : sum local = 7.9708407e-07, global = -1.1716851e-22
GAMG:  Solving for p_rgh, Initial residual = 0.28119381, Final residual = 0.00021402582, No Iterations 7
time step continuity errors : sum local = 7.9710924e-07, global = -5.677347e-21
DICPCG:  Solving for T, Initial residual = 5.3730343e-07, Final residual = 5.3730343e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77539 max(T) [0 0 0 1 0 0 0] 300.23069
DILUPBiCG:  Solving for T, Initial residual = 1.8336375e-05, Final residual = 3.3775715e-07, No Iterations 1
max(T) [0 0 0 1 0 0 0] 307.06515
GAMG:  Solving for p_rgh, Initial residual = 0.03702251, Final residual = 3.052687e-05, No Iterations 11
time step continuity errors : sum local = 3.3549545e-07, global = 1.0332132e-21
GAMG:  Solving for p_rgh, Initial residual = 0.036786632, Final residual = 2.849982e-05, No Iterations 11
time step continuity errors : sum local = 3.1319121e-07, global = -4.0582912e-21
GAMG:  Solving for p_rgh, Initial residual = 0.036785243, Final residual = 9.9930364e-08, No Iterations 31
time step continuity errors : sum local = 1.0904319e-09, global = 6.4053853e-21
DICPCG:  Solving for T, Initial residual = 5.5942857e-07, Final residual = 5.5942857e-07, No Iterations 0
Min/max T:min(T) [0 0 0 1 0 0 0] 299.7754 max(T) [0 0 0 1 0 0 0] 300.2307
ExecutionTime = 9340.47 s  ClockTime = 9355 s
Region: air Courant Number mean: 0.025087667 max: 0.40051174
Region: plate Diffusion Number mean: 3.7061104e-07 max: 7.8071489e-07
deltaT = 0.0071039405
Time = 5.9012
What is observed
1. There are 10 outercorrectors (though number of pimple iteration not displayed) and 3 ncorrectors in each loop.
2. No change in p_rgh initial residual found till the last outer loop
3.Sudden jump of p_rgh initial residual from [/b] 0.28[/b] to 0.03 (see code snippet)
Min/max T:min(T) [0 0 0 1 0 0 0] 299.77539 max(T) [0 0 0 1 0 0 0] 300.23069).
I am not able to find why its happening ( Its observed in all time steps)
4. The prgh_initial value never changes in 1 outer iteration (see the specific region below)
What did I try
1. Changing outercorrector and inner corrector numbers (no change observed)
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p_rgh
        solver           GAMG;
        tolerance        1e-7;
        relTol           1e-3;
        smoother         GaussSeidel;
        cacheAgglomeration  true;
        nCellsInCoarsestLevel 10;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    p_rghFinal
        $p_rgh;
        tolerance        1e-7;
        relTol           0;
    "(U|T|k|epsilon|R)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-6;
        relTol          0.0001;
    "(U|T|k|epsilon|R)Final"
        $U;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 10;//tried 20 aswell no change
    nCorrectors    3;
    nNonOrthogonalCorrectors 0;
    pRefPoint (0.5 0.01 0);
    pRefValue       0;
relaxationFactors
    fields
    p_rgh           0.2;
    equations
           U               0.3;
           T               0.5;
        "(k|epsilon|R)" 0.7;
        "(U|T|k|epsilon|R)Final" 1;
2. Tried changing solver for p_rgh to PCG
solvers
    p_rgh
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          1e-3;
    p_rghFinal
        $p_rgh;
        relTol          0;
3. Tried changing fvSchemes from linear to upwind
fvsolution 1
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default Euler; // steadyState; //
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear ;
    div(phi,h)      Gauss linear limited 0.333;
    div(phi,k)      Gauss linear limited 0.333;
    div(phi,T)      Gauss linear limited 0.333;
    div(phi,epsilon) Gauss linear limited 0.333;
    div(phi,R)      Gauss linear;
    div(R)          Gauss linear;
    div((muEff*dev2(grad(U).T()))) Gauss linear;
    div(U,p)        Gauss upwind;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
   div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear uncorrected;
    laplacian(muEff,U) Gauss linear limited 0.333;
    laplacian((rho*(1|A(U))),p_rgh) Gauss linear limited 0.333;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(alphaEff,h) Gauss linear limited 0.333;
    laplacian(DkEff,k) Gauss linear limited 0.333;
    laplacian(DepsilonEff,epsilon) Gauss linear limited 0.333;
    laplacian(DREff,R) Gauss linear limited 0.333;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian(nu,U) Gauss linear corrected;
    laplacian(kappaEff,T) Gauss linear limited 0.333;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited 0.333;
fluxRequired
    default         no;
    p_rgh;
fvsolution 2
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,T)      Gauss upwind;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon) Gauss upwind;
    div(phi,R)      Gauss upwind;
laplacianSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
fluxRequired
    default         no;
    p_rgh;
5 also tried changing northogonal correctors as per the suggestion in a post by Hjasak up to 4.
In all these cases I find no difference in the initial p_rgh residual. The values follow the same trend as above.
It would be great if some suggestions could be provided on how to approach it.
Regards
Manu
manuc is offline   Reply With Quote
Old   June 26, 2018, 16:40
MaryBau is on a distinguished road
Hi Manu,
Did you find a solution? I am having exactly the same problem that you described and I have not been able to find a solution.
I found this post that talks about the same issue, but no solution yet:
How to use PIMPLE properly?
Cheers,
Mary
MaryBau is offline   Reply With Quote
Old   June 26, 2018, 16:43
Manu Chakkingal
Originally Posted by MaryBau View Post
Hi Manu,
Cheers,
Mary
I use piso now with Gamg..in most cases it serves the purpose.
Regards
Manu
Old   June 26, 2018, 16:53
mmm.... I have been using GAMG, but I still have that problem.
This is what I normally use:
"(p|p_rgh)"
      solver          GAMG;
      tolerance      1e-6;
      relTol            0.01;
      smoother      DICGaussSeidel;
      minIter          1;
      maxIter         100;
      nPreSweeps      1;
      nPostSweeps    3;
      nFinestSweeps  3;
      scaleCorrection true;
      directSolveCoarsest     false;
      cacheAgglomeration     on;
      nCellsInCoarsestLevel  50;
      mergeLevels    1;
I have tried modifying some of those values, but 1) I have to admit that I do not understand what all those parameters do, 2) I have not seen a difference in the simulation output.
What parameters do you use for GAMG?
Thanks for your help!
cleitontrindade likes this.
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 05:03
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 13:53
