Nejc
Rep Power: 9 ![]() |
I tried to run a DNS case (i managed to get cell size small enough and geometry is fairly simple) only to find out dnsFoam only solves 'box' geometry.
I guess there's a reason for this? |
Uwe Pilz
Rep Power: 15 ![]() |
dnsFoam uses a spectral method for solving the case. This requires a rectangular mesh, all cell sizes equal and the cell count a power of 2.
You may use paraFoam instead and make the spatial and time resolution as small as the Kolmogorov scale requires. The dissipation rate eps disappears in this case (= gets very small).
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Nejc
Oh I see.
Thanks for the tip - but are you sure you meant paraFoam? Could that be the reason that simpleFoam with k-Epsilon model blows up with very small cell sizes? I'm not really sure what's going on because everything was fine with triangular mesh with slightly bigger cells (just above Kolmogorov scale). Now I used blockMesh with sizes around 0.1x Kolmogorov scale and strange anomalies in pressure and velocity occur in one spot. |
Uwe Pilz
simple Foam is not suited for transient cases. icoFoma doesn't have turbulence at all. pimpleFoam makes large time steps and corrects afterwards.
From the standard incompressible solvers only pisoFoam remains.
Nejc
pisoFoam it is then.
I guess I can't use simpleFoam even though it is a steady-state case (a gap in plain bearings)? Thanks for your help. |
#6 | |
Shantanu S Gulawani
Rep Power: 0 ![]() |
How do you find that it is a spectral code? or that it uses spectral method? I also want to know what is time discretization scheme in this solver? |
#7 | |
Robert
Rep Power: 12 ![]() |
If you liked my answer to your question, please consider leaving a "Like" in return ![]() |
#8 | |
Santiago Lopez Castano
The requirements on the mesh come from the Kmesh class, that is used to generate the K field, which is used to generate a pseudo-random force. |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 15:06 |
Filtering DNS solutions Vs projecting filtered DNS solution | juliom | Main CFD Forum | 5 | May 19, 2016 16:06 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
finding noise of flow by dns simulation | m2montazari | OpenFOAM Running, Solving & CFD | 0 | October 22, 2010 11:54 |
FSI TWO-WAY SIMULATION | Smagmon | CFX | 1 | March 6, 2009 13:24 |
