Error in change of geometry and mesh in cavity case (icoFoam) |
February 21, 2017, 23:39 |
jeanpinto24@hotmail.com
Rep Power: 9 |
When running the simulation of the geometry and mesh created in Salome and then imported into the cavity case, the terminal throws me the following error:
Courant Number mean: 1.89451 max: 43.117 smoothSolver: Solving for Ux, Initial residual = 0.618674, Final residual = 9.04474e-06, No Iterations 80 smoothSolver: Solving for Uy, Initial residual = 0.600398, Final residual = 9.843e-06, No Iterations 71 DICPCG: Solving for p, Initial residual = 0.963709, Final residual = 7.70104e-07, No Iterations 110 time step continuity errors : sum local = 7.77346e-06, global = 1.8948e-17, cumulative = 1.64322e-17 DICPCG: Solving for p, Initial residual = 0.847767, Final residual = 6.34184e-07, No Iterations 109 time step continuity errors : sum local = 1.09063e-05, global = -1.64853e-17, cumulative = -5.30717e-20 ExecutionTime = 0.26 s ClockTime = 0 s Time = 0.025 Courant Number mean: 13.4014 max: 328.638 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 at ??:? #7 at ??:? #8 at ??:? #9 at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 at ??:? Excepción de coma flotante (`core' generado) |
February 22, 2017, 19:06 |
Joshua
Rep Power: 10 |
Icofoam is a transient solver. It appears that your time steps are to large causing your Courant number to explode. Try running smaller time steps and that should fix it. You can also run the simulation as steady using simpleFoam and then you will not have to worry about the Courant number. Joshua |
February 23, 2017, 00:18 |
Rep Power: 9 |
I'm using a different geometry to the cavity case by doing a mesh with Salome and then imported to OpenFoam through the necessary commands. Modified the file "controlDict", but I still get the mentioned error. I attached the file "controlDict" used:
application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.5; deltaT 0.005; writeControl timeStep; writeInterval 20; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Geometry image: https://drive.google.com/open?id=0B8...2ZldkZXeHdRTnc |
February 23, 2017, 04:52 |
Rep Power: 9 |
Modify the nu file of the constant folder to a value of: 0.001, I kept the "movingWall" speed of 1 m / s. The file "controlDict" is as follows:
Application icoFoam; StartFrom startTime; StartTime 0; StopAt endTime; EndTime 2; DeltaT 0.0005; WriteControl timeStep; WriteInterval 20; PurgeWrite 0; WriteFormat ascii; WritePrecision 6; WriteCompression off; General timeFormat; TimePrecision 6; RunTimeModifiable true; Finally I ran the simulation with the mesh made in Salome. Thanks very much. Jean. Last edited by jeanpinto24|; February 23, 2017 at 08:00. |
February 23, 2017, 10:34 |
Joshua
Rep Power: 10 |
What is your latest error output? Is your courant number still blowing up?
Joshua |
February 23, 2017, 11:02 |
Rep Power: 9 |
The simulation ran without any problem, I attach some images when running icoFoam in the terminal:
https://drive.google.com/open?id=0B8...0piQU5TOXVEX0U https://drive.google.com/open?id=0B8...zRuVlpLaXNFdU0 Thanks very much. Jean. |
February 23, 2017, 11:29 |
Simulation error icoFoam
Rep Power: 9 |
When changing the geometry of the cavity (solver icoFoam) case to a box with a cylindrical inlet and outlet like the attached image, I get the following error:
https://drive.google.com/open?id=0B8...1F1U1JkUko1cDQ -> FOAM FATAL ERROR: Continuity error can not be removed by adjusting the outflow. Please check the velocity boundary conditions and / or run potentialFoam to initialise the outflow. Total flux: 0.284255 Specified mass inflow: 1246.79 Specified mass outflow: 0 Adjustable mass outflow: 0 From function adjustPhi (surfaceScalarField &, const volVectorField &, volScalarField &) In file cfdTools / general / adjustPhi / adjustPhi.C at line 118. The entrance is by the lower cylinder. I attach the files 0 / U and 0 / p: FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0 0 1); } exit { type fixedValue; value uniform (0 0 0); } walls { type fixedValue; value uniform (0 0 0); } } FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type zeroGradient; } exit { type zeroGradient; } walls { type zeroGradient; } } |
February 28, 2017, 04:34 |
Rep Power: 12 |
you have no outflow. In an incompressible case, it is not working like that: Code:
Continuity error can not be removed by adjusting the outflow. Code:
0/U: inlet: fixedValue outlet: zeroGradient 0/p: inlet: zeroGradient outlet: fixedValue Kate |
cavity, mesh |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
