Pressure-velocity coupling with SIMPLE/SIMPLEC for incompressible steady-state
Like Tree5Likes
  • 1 Post By Arya_the_Rabbit
  • 4 Post By Artur.Ant
Old   February 12, 2017, 12:15
Default Pressure-velocity coupling with SIMPLE/SIMPLEC for incompressible steady-state
Arya
Arya_the_Rabbit is on a distinguished road
I have problem to set up a pressure-velocity coupling solver in OpenFoam due to discordant opinion I've found online.
I would like to use a coupled solver for an incompressible steady state case in order to improve the convergence speed and the robustness of the solution.
I've found that for solve together the flow equations I need to set "type coupled" in the U solver in fvsolution, but I haven't found anything about the most appropriate linear solver to use (i.e. GAMG, PCG) and the pressure-based algorithm to use (SIMPLE, SIMPLEC, PISO).
So far I tried using:
- GAMG for pressure
- PCiGC for velocity and turbulence quantities
- SIMPLE
- First order and then switch to second order the div U schemes
but the solution is similar to segregated solver. What I would have expected is an earlier convergence with lower residual and a more stable solution.
- Have someone experience in coupling velocity-pressure in OpenFoam? Could I have some advice about numerical schemes and set up of solver?
- I found that SIMPLEC is faster than SIMPLE. Is it true in a pressure-velocity coupling simulation too?
Thanks for your help.
Arya
kishore96 likes this.
Arya_the_Rabbit is offline   Reply With Quote
Old   October 3, 2019, 09:12
Arthur
Artur.Ant is on a distinguished road
In openFoam there is no a coupled pressure-velocity solver.
The coupled solver is only for U, in that case the solver couples the velocity in x,y,z direction and solves it in a single matrix at once.
If you use coupled solver you can gain some stability.
In theory (I verified it in some cases) the converged solution found with a segregated solver is prety close (quasi identical) to the coupled solution and vice versa.
For coupled solution you can use PBiCICG or PBiCCCG linear solvers. The type of solver really depend on the problem.
Artur.Ant is offline   Reply With Quote
The difference between steady state and transient JuPa CFX 36 December 9, 2019 23:50
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
Pressure Velocity coupling problem Sunho park OpenFOAM Running, Solving & CFD 0 August 4, 2010 01:22
velocity pressure coupling Winston Gregorio Main CFD Forum 0 March 25, 2007 17:30
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
