How to cell field values to cells in setFields
Like Tree6Likes
  • 6 Post By floquation
Old   January 23, 2017, 03:22
Default How to cell field values to cells in setFields
Upuli
upuli is on a distinguished road
Dear members
I want to know how to set the field values to cells using setFields. I used cellToCell in setFields. but it gives me errors.
Thanking You
rgds
Upuli
upuli is offline   Reply With Quote
Old   January 23, 2017, 04:55
floquation's Avatar
Kevin van As
floquation will become famous soon enough
I do not understand what you want to achieve / you specify to little information. It always helps to post what exactly you tried to clarify your problem.
This is an example of a setFieldDict that I am using to initiate a spherical bubble in interFoam:
|  \\    /   O peration     | Version:  4.0                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      setFieldsDict;
defaultFieldValues
    volScalarFieldValue alpha.water 1
regions
    sphereToCell
        centre (0.0025 0.0025 0.001);
        radius 0.0005;
        fieldValues
            volScalarFieldValue alpha.water 0
floquation is offline   Reply With Quote
Old   January 23, 2017, 11:04
Upuli
Thank you very much for your prompt reply. I want to define some field values for one cell in my geometry(box). I think cellToCell in setFields will do that. But I do not how to use it(which parameters are required in defining the cell)
Thanks
Old   January 23, 2017, 11:32
floquation's Avatar
Kevin van As
And how do you wish to select that one cell? The answer will depend on that.
Some other ideas:
1) Use boxToCell with a tiny box around the cell you wish to select.
2) Create a set based on the cell indices and then use cellToCell***
3) funkySetFields can use an arbitrary expression to select cells.
***cellToCell says (${FOAM_SRC}/meshTools/sets/cellSources/cellToCell):
 27 Description
 28     A topoSetSource to select the cells from another cellSet.
And needs the dictionary entry "set":
 76     setName_(dict.lookup("set"))
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
Setting patch field values equal to internal field values leroyv OpenFOAM Programming & Development 1 October 21, 2014 16:49
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
