January 19, 2017, 13:12 |
How does Adjustable Time stepping work?
Sheikh Ahmed
Rep Power: 10 |
Dear Foamers
I have a very basic question regarding the adjustable time stepping method. I can have that by turning on the adjustTimeStep and maxCo in the controlDict, which gives a mean and max courant number and time steps for each iteration. Could anyone PLEASE elaborate a little bit of how this adjusting works. The user manual doesnt have much info. Thanks in advance. |
January 19, 2017, 13:27 |
Joshua
Rep Power: 9 |
Sahmed,
By using an adjustable time step, the simulation will be able to change its delta(t). Delta(t) will be determined from the max Co you specify. This will help prevent your simulation from crashing from too large of a time step when running a transient solution. Hope this helps, Joshua |
January 19, 2017, 13:35 |
Sheikh Ahmed
Rep Power: 10 |
Thanks Joshua for your prompt reply. Could you tell me how does it calculate the delt AT EACH ITERATION. I mean what value of delx and u does it take.
January 19, 2017, 13:52 |
Joshua
Rep Power: 9 |
Sahmed,
The full calculations of how it determines the new delta(T) can be seen in the source code. I show the path to it below. OpenFOAM Instulation -> src -> postProcessing -> functionObjects -> solverControl -> adjustableTimeStep.C My C++ is a little rusty but the following appears to be how they define the new delta(t). scalar maxDeltaTFact = targetCo_/(CoNum + SMALL); scalar deltaTFact = min(min(maxDeltaTFact, 1.0 + 0.1*maxDeltaTFact), 1.2); const_cast<Time&>(obr_.time()).setDeltaT ( deltaT_ = min ( deltaTFact*obr_.time().deltaT().value(), maxDeltaT_ ) ); Joshua |
January 19, 2017, 13:55 |
Sheikh Ahmed
Rep Power: 10 |
Thanks a lot
adjusttimestep, controldict, maxco |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Elastic or Plastic Deformations in OpenFOAM | NickolasPl | OpenFOAM Pre-Processing | 36 | September 23, 2023 08:22 |
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
