Interface boundary conditions in chtMultiRegionFoam |
August 6, 2016, 03:55 |
Bibin K.S
Rep Power: 12 |
Hi All,
Is it possible use chtMultiRegionFoam problem for porous media flow??. if so, how to specify interface boundary condition for U, p_rgh etc in porous media??. Presently I created a case file having 3regions with one region assuming to be porous. In region properties I choose porous as a fluid region then I added fvOptions to add porous region properties. Case file is running perfectly but from the results I see that this resistance is not added. could you please tell me why this is not taking?? Regards, Bibin Last edited by bibin.sme; August 9, 2016 at 01:42. |
January 18, 2017, 02:37 |
Bibin K.S
Rep Power: 12 |
Dear all,
I have a case where one region is a porous region and the other is a clear fluid region. The problem i'm facing is the interface boundary conditions . The interface has to satisfy boundary conditions for U, shear stress, T, and heat flux. How do I create these boundary conditions as coupled BC's or is there any other way to get rid of this issue?? please help me.... Regards, Bibin |
January 1, 2018, 20:12 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Although I'm really late here, the solution is simple enough: porous region cannot be a separate region, it must be part of the complete fluid region that is connected to the porous region.
Edit: See the tutorial case "heatTransfer/chtMultiRegionSimpleFoam/heatExchanger"
April 25, 2018, 01:27 |
Bibin K.S
Rep Power: 12 |
Hi Bruno,
The Problem I'm trying to solve is heat pipe using chtMultiRegionFoam. This Problem is having 3 regions (wall, wick & vapour core). The major difficulty I'm facing is the interface b/w the wick & vapour region as its an interface of two fluid regions with phase change. Can u please suggest some solution to this problem. Regards, Bibin |
April 30, 2018, 18:12 |
Bruno Santos
Rep Power: 128 |
Hi Bibin,
Phase change is a whole other type of solver... unfortunately the solvers chtMultiRegionFoam and chtMultiRegionSimpleFoam cannot handle phase change. I'm not familiar with anyone having made public a modified solver of these two that can handle phase changes as well. What is more important to simulate for your problem:
Bruno
May 4, 2018, 05:37 |
Bibin K.S
Rep Power: 12 |
Thanks Bruno,
Let me try the links what you send first. Regards, Bibin |
August 6, 2018, 09:43 |
#7 | |
Alejandro
Rep Power: 12 |
Why a porous region can not be a separate region?. If you consider a solid porous and a fluid passing trought it. You need to solve different equations for each one and heat transfer between them. Am I missing something? Regards |
August 17, 2018, 17:21 |
#8 | |
Bruno Santos
Rep Power: 128 |
Quick answer: Study the tutorial case "heatTransfer/chtMultiRegionFoam/heatExchanger" in OpenFOAM 6 or "heatTransfer/chtMultiRegionSimpleFoam/heatExchanger" in OF 5 and older. I haven't studied this tutorial case myself and the porous part is indeed in a separate region. However, even if your porous region is made of a solid fabric/material, the problem is that you still need fluid crossing it. This means that you need the non-porous fluid region to transfer fluid back and forth through the porous region. And if not done correctly, you get two separate regions that do not exchange fluid, only heat.
April 27, 2020, 11:12 |
#9 |
James
Rep Power: 12 |
Hi Bruno,
I need to set up a condition on the interface (using internal patch or somehow) but I couldn't figure out how is this possible. Could you please advise. I need a source term for my momentum equation which is obtained by solving the the Maxwell's equation for elctric potential. The BC needed to solve this equation {as shown} should satisfy on top of metal surface. If there was only metal phase, I wouldnot have problem to set up this BC. But now I have metal phase & Gas phase (interfoam based two-phase solver) and I can't apply this condition on the top surface (of gas) anymore. How do I apply this condition on the interface boundary? I only need to solve for this equation once outside the time loop. The generated source term for momentum equation after solving this equation will remain constant for simplicity. I have attached a graphics of the domain for easier understanding. Thanks! Last edited by Madeinspace; April 27, 2020 at 11:27. Reason: picture didn't appear |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 22:25 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
