deltaT is getting very small on using interFoam solver
Like Tree2Likes
  • 2 Post By pbachant
Old   January 14, 2017, 12:17
Default deltaT is getting very small on using interFoam solver
Dhinesh_Bala
dhineshcecfd is on a distinguished road
Dear Foamers,
I am simulating a simple 3D geometry using interFoam. While running interFoam, deltaT is going upto 1e-7 but my actual deltaT is 0.01 and simulation runs for some days : ( Could anyone help me to fix this issue.? I have attached here the snap shot of mesh, U, p_rgh, alpha.water files:
alpha.water:
| \\ / O peration | Version: 2.3.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
INLET
type inletOutlet;
inletValue uniform 1;
value uniform 1;
OUTLET
type inletOutlet;
inletValue uniform 0;
value uniform 0;
FACES
type inletOutlet;
value uniform 0;
OBSTACLES
type zeroGradient;
defaultFaces
type empty;
U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
INLET
type fixedValue;
value uniform (0 -0.01 0);
OUTLET
type zeroGradient;
FACES
type zeroGradient;
OBSTACLES
type fixedValue;
value uniform (0 0 0);
p_rgh:
FoamFile
version 2.0;
format ascii;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
INLET
type zeroGradient;
OUTLET
type fixedValue;
value uniform 0;
FACES
type fixedValue;
value uniform 0;
OBSTACLES
type fixedFluxPressure;
value uniform 0;
dhineshcecfd is offline   Reply With Quote
Old   January 14, 2017, 23:45
Pete Bachant
pbachant is on a distinguished road
Try turning off the automatic time step adjustment in the controlDict first. This may cause your simulation to crash however. Are you running setFields before interFoam to get the initial alpha distribution setup?
Home | Twitter | GitHub
pbachant is offline   Reply With Quote
Old   January 15, 2017, 05:57
Dhinesh_Bala
Thanks for the reply pbachant.. I have tried turning off "adjustable run time" but my courent no became too large and simulation stopped with core dumped error (pls refer screen shot).. is there any other option to try it out?
I am not using setFields Instead I have mentioned water fields in the alpha.water file
Sent from my Nexus 4 using CFD Online Forum mobile app
File Type: png Screenshot from 2017-01-15 12:44:12.png (173.8 KB, 158 views)
Old   January 15, 2017, 08:54
Dhinesh_Bala
Hi All,
I found the solution of the above problem. The problem was with deltaT in controlDict and it was very large when compared to my smallest element in the grid.
Thanks for your answer.
Old   January 15, 2017, 12:11
Pete Bachant
What are you trying to simulate? It looks like the way you have it setup, you'll have an infinitesimally thin layer of water at the inlet, and that's it.
Old   January 15, 2017, 13:07
Dhinesh_Bala
I am just trying to find the permeability of this geometry.. so the water is continuously flowing from inlet to outlet..I will measure pressure drop once the flow reaches steady state
Old   August 6, 2018, 16:29
Charles
charlescfd is on a distinguished road
Originally Posted by dhineshcecfd View Post
Hi All,
I am also facing the same problem. Does the smallest element mean the minimum face area or the minimum volume? Was the solution to your problem was to make the magnitude of delta T equal to minimum face area or the minimum volume?
charlescfd is offline   Reply With Quote
Old   August 18, 2018, 19:11
UchihaMadara is on a distinguished road
Am also looking at a similar problem, could you explain a little bit please!!!
UchihaMadara is offline   Reply With Quote
Old   August 19, 2018, 13:27
Vivek
vivek05 is on a distinguished road
Minimum deltaT (time_step) is based on your smallest size of grid in you mesh..if you know your minimum size of your cell you can approximately predict the deltaT based on courant no
vivek05 is offline   Reply With Quote
Old   August 9, 2022, 08:53
wangjikang
sciFoam is on a distinguished road
Originally Posted by vivek05 View Post
do you leave alone the U magnitude?
sciFoam is offline   Reply With Quote
Old   September 4, 2022, 03:33
Anthony Moris Danve
Anthony Danv is on a distinguished road
May you explain to me in details. I face the same problem. I run in olaFlow solver with solitary wave propagation. the smallest mesh size: 0.1 m in Z direction, Delta T = 0.1 s. Co= 0.5.
Anthony Danv is offline   Reply With Quote
interfoam, openfoam 2.3.x
interFoam solver - Vacuum saba_saeb OpenFOAM Running, Solving & CFD 3 October 13, 2014 11:41
can rho2 be varied in interfoam solver shash OpenFOAM Programming & Development 0 July 24, 2012 13:53
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
interFoam solver needs pdRefCell? openTom OpenFOAM Running, Solving & CFD 2 May 10, 2009 11:20
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 22:58
