January 13, 2017, 03:26 |
How to use parallel running to the most?
Bill Wang
Rep Power: 12 |
Dear All,
I am trying to run cases in OpenFOAM, here is the configuration of the server I am using. Code:
ywang@srv-calmipo01 ~/OpenFOAM/ywang-3.0.1/run/UCUCUC/Re17500 $ lscpu Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 40 On-line CPU(s) list: 0-39 Thread(s) per core: 2 Core(s) per socket: 10 Socket(s): 2 NUMA node(s): 2 Vendor ID: GenuineIntel CPU family: 6 Model: 79 Stepping: 1 CPU MHz: 2399.976 BogoMIPS: 4396.31 Virtualization: VT-x L1d cache: 32K L1i cache: 32K L2 cache: 256K L3 cache: 25600K NUMA node0 CPU(s): 0,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34,36,38 NUMA node1 CPU(s): 1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31,33,35,37,39 Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: [IMG]file:///C:\Users\wyb\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.png[/IMG]www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; note "mesh decomposition control dictionary"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 12; method scotch; multiLevelCoeffs { level0 { numberOfSubdomains 64; method scotch; } level1 { numberOfSubdomains 4; method scotch; } } simpleCoeffs { n (2 1 1); delta 0.001; } hierarchicalCoeffs { n (1 2 1); delta 0.001; order xyz; } metisCoeffs { /* processorWeights ( 1 1 1 1 ); */ } scotchCoeffs { } manualCoeffs { dataFile "decompositionData"; } structuredCoeffs { patches (movingWall); method scotch; } // ************************************************************************* // mpirun -np 12 icoFoam -parallel > log Q2: This running process will be saved in the log file, but I also want to see them running on the screen. What should I add to the command? I want to store the solution according to the controlDict file below Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application myIcoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 4000; deltaT 0.0125; writeControl timeStep; writeInterval 20000; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Q3: But if I run in parallel, the files will be saved automatically in separate folders, named Processor0, processor1, ...What is the difference between these separate files and those files obtained without parallel? Q4: How can I continue the simulations based on these files, if I do not use parallel running? Thank you in advance. Best Regards, Bill |
January 13, 2017, 04:22 |
#2 | |
Gerhard Holzinger
Rep Power: 28 |
Q2: Having the solver output permanently on the screen seems to slow the simulation down. Redirect the solver output to a file, and display the solver output only on demand, e.g. by the tail command or by pyFoamPlotWatcher.py Q3: A parallel simulation is a large task done is smaller chunks. This is why you do domain decomposition. The sum of the content of the processor* directories is your original case. After you finished, you can run reconstructPar to recombine the small chunks into your large simulation again. Q4: What is the point of continuing a simulation you did in parallel before, in serial (one process)? How you do it? Run reconstructPar, make sure startTime in controlDict is set to latestTime, check the settings for ending the simulation (stopAt and stopTime), and run the solver. What makes more sense is to change the number of parallel processes, e.g. because you initially used to little or too much. Recombine, decompose with the new number of subdomains, and continue the parallel run with the new number of parallel processes. |
January 13, 2017, 05:19 |
Bill Wang
Rep Power: 12 |
Dear Dr. Holzinger,
Thanks for the quick reply. Q1: I will test to see what is the best for my cases. Q2: Thank you for the suggestions. Q3: That's correct!!! I looked through the forum and found reconstructPar function. I know what to do after parallel running. Q4: Based on the answer for Q3, I understand my problem now and thanks for the instructions. Thanks for the detailed instructions. If I understand your point and the computer configuration correctly, I may start from Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: [IMG]file:///C:\Users\wyb\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.png[/IMG]www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; note "mesh decomposition control dictionary"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 20; method scotch; multiLevelCoeffs { level0 { numberOfSubdomains 10; //changed from 64 to 10 method scotch; } level1 { numberOfSubdomains 8; //changed from 4 to 8 method scotch; } } simpleCoeffs { n (2 1 1); delta 0.001; } hierarchicalCoeffs { n (1 2 1); delta 0.001; order xyz; } metisCoeffs { /* processorWeights ( 1 1 1 1 ); */ } scotchCoeffs { } manualCoeffs { dataFile "decompositionData"; } structuredCoeffs { patches (movingWall); method scotch; } // ************************************************************************* // Thank you. Best Regards, Bill |
January 13, 2017, 05:35 |
#4 | |
Gerhard Holzinger
Rep Power: 28 |
Since you use the scotch method for decomposition, you can delete all other entries in the decomposeParDict. When you use a method X, then the XCoeffs are relevant. Using scotch and changing the multiLevelCoeffs makes no sense and will change nothing. First, you may want to stick to the scotch method, as it handles decomposition for you. Try different numbers of processes to see where the sweetspot lies. If the case is large enough, conducting parallel simulation will speed-up your calculations. As you increase the number of parallel processes the speed-up will increase up to the point, when the additional work (communication between the processes) will become dominant. |
January 13, 2017, 09:25 |
Bill Wang
Rep Power: 12 |
Dear Dr. Holzinger,,
Thank you for your clear explanations, they are really very helpful to me!!! I start from Code:
numberofSubdomains 40; Since I used cyclic boundary, the decompose method is recommended here: https://github.com/OpenFOAM/OpenFOAM...composeParDict Thank you in advance. Best Regards, Bill Last edited by 6863523; January 19, 2017 at 03:39. |
January 19, 2017, 02:22 |
still rather long time needed in parallel
Bill Wang
Rep Power: 12 |
Dear,
I have tested the numberofSubdomains(n) with several numbers. Here are some results I have got. Code:
n=8, for t=3.7s ClockTime=863s; ClockTime/t ≈ 233; n=12, for t=5s, ClockTime=916s; for t=7.538s, ClockTime=1363s; for t=10s, ClockTime=1803s; for t=10.425s, ClockTime=1898s; ClockTime/t ≈ 180; n=15, for t=5s, ClockTime=909s; for t=7.5s, ClockTime=1375s; for t=10s, ClockTime=1802s; ClockTime/t ≈ 182 n=20, for t=2.325s, ClockTime=349s; ClockTime/t ≈ 150 for t=321.09s, ClockTime=21574s; ClockTime/t ≈ 67.2 In addition, I would like to recommend the parallel tests mentioned here: Optimising the Parallelisation of OpenFOAM Simulations And also the basic knowledge about parallel strategy here: http://quantumwise.com/documents/tut...rategy.systems Thank you in advance. Best Regards, Bill Last edited by 6863523; February 1, 2017 at 13:28. Reason: wrong info |
parallel calculation, parallel code |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Running mapFields with Parallel Source and Parallel Target | RDanks | OpenFOAM Pre-Processing | 4 | August 2, 2016 05:24 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 08:53 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
