buoyantSimpleFoam - not plotting residuals
Like Tree4Likes
  • 3 Post By floquation
  • 1 Post By floquation
Old   December 24, 2016, 21:18
Default buoyantSimpleFoam - not plotting residuals
M. C.
student666 is on a distinguished road
after including residual function into control dict, according to this tutorial
https://www.youtube.com/watch?v=LY4jUg3lOoE
functions
//	#includeFunc PecletNo
	#includeFunc residuals
I can't plot residuals for U T h, but only ofr p and p_rgh-
looking at residuals.dat only coloumns for pressures are written, does someone know the reason why?
this is the residualDict:
#includeEtc "caseDicts/postProcessing/numerical/residuals.cfg"
fields (alphat  p  p_rgh  T  U h);
# Residuals
# Time         	p              	p_rgh          	T              	Ux             	Uy             	h
1              	7.66141540e-01	1.00000000e+00
2              	7.98974970e-01	1.83442730e-01
3              	6.27299870e-01	7.98917170e-02
4              	7.00095750e-01	3.86347270e-02
5              	5.92908140e-01	3.04990920e-02
6              	4.58467380e-01	2.39679380e-02
7              	4.45960730e-01	2.03891940e-02
8              	4.34298940e-01	1.80788340e-02
9              	3.52051730e-01	1.59621540e-02
10             	3.76240910e-01	1.44632730e-02
Thanks a lot
regards
student666 is offline   Reply With Quote
Old   January 5, 2017, 01:47
M. C.
I also tried the old way:
libs            ("libutilityFunctionObjects.so");
functions
{residuals
    type            residuals;
    writeControl   timeStep;
    writeInterval  $deltaT;
    fields
    (  U  );
but this is the output on residuals.dat
# Residuals
# Time         	Ux             	Uy             	Uz
1
2
3
4
5
6
7
8
any help?
Old   January 6, 2017, 12:38
floquation's Avatar
Kevin van As
floquation will become famous soon enough
If you have a look at the solver output (log file), do you see any velocity residuals?
If not, it is because "momentumPredictor" (or something like that) in "system/fvSolution" is off/false:
There are no velocity residuals if the velocity is not predicted (iterated separately) - then the velocity is fully determined by the pressure correction as to ensure continuity exactly.
I suspect this is why your residual-utility fails.
Elham, thiagopl and mn17jyf like this.
floquation is offline   Reply With Quote
Old   January 6, 2017, 18:48
M. C.
Hi, thanks you're right, but in any case, even if I set to "yes" the moment-predictor, not all variables are plotted.
residualsDict:
fields (alphat  p  p_rgh  T  U h k omega phi);
residual.dat
# Residuals
# Time         	alphat         	p              	p_rgh          	T              	Ux             	Uy             	h              	k              	omega
1              	8.49454040e-01	1.00000000e+00	1.00000000e+00	9.99999860e-01	1.00000000e+00	9.39029660e-02
2              	9.60117560e-03	9.93457280e-01	4.13896110e-01	2.29865230e-01	6.02265870e-01	1.66618400e-02
3              	3.29224330e-02	7.58574770e-01	8.83426870e-01	1.25890060e-01	4.81928730e-01	1.03306770e-02
log file:
Time = 9
DILUPBiCG:  Solving for Ux, Initial residual = 0.021375153, Final residual = 0.00021156612, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.07626579, Final residual = 0.0012698228, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.029377071, Final residual = 0.0014589073, No Iterations 1
GAMG:  Solving for p_rgh, Initial residual = 0.42919448, Final residual = 0.0039295721, No Iterations 4
time step continuity errors : sum local = 0.0043774316, global = 0.0012861574, cumulative = 0.0072015916
rho max/min : 1.1888231 1.1317888
DILUPBiCG:  Solving for omega, Initial residual = 0.011685404, Final residual = 0.00053581443, No Iterations 1
bounding omega, min: -23.944772 max: 617.83442 average: 20.391699
DILUPBiCG:  Solving for k, Initial residual = 0.019885726, Final residual = 0.00063162881, No Iterations 1
ExecutionTime = 7.55 s  ClockTime = 7 s
Any other suggestion?
Can you please give me more details about what does this means?
It's making me confusion.
Do you mean that velocity has no iteration (if "no" is set) and actual values for U, at current time step, are used inside pressure inner-loop of SIMPLE alghorithm?
Thanks
Old   January 9, 2017, 05:27
floquation's Avatar
Kevin van As
residualsDict:
residual.dat
# Residuals
log file:
Time = 9
So if I understand you correctly, turning on the momentumPredictor results in the velocity residual being plotted, whereas it does not get plotted when it's off?
I don't know about the other fields - I never used the utility you are using. Therefore, the only "other" suggestions I can give you are:
pyFoamPlotWatcher.py <-- I'm using this one.
The "old" way <-- This will work, but is more elaborate.
Thanks
If momentumPredictor is true, then the velocity is predicted before calculating the pressure.
In this case, there is a residual calculated for the velocity field.
If momentumPredictor is false, then the velocity from the previous timestep is taken instead.
In this case, there is no residual calculated for the velocity field. Evidently, one could still define a residual based on the new velocity and the old velocity - but it is simply not calculated afaik.
saidc. likes this.
Old   January 9, 2017, 16:07
M. C.
thanks for your reply.
About pyFoam, I already use it, but as new OF release has postProcess utility, I was digging into it to understand its capabilities.
Maybe a bug, maybe not....I'm thinking of make a bug report...
About momentum-predictor, thanks, I'm having a closer look to background theory.
Best regards.
Michele
plotting residuals SUBHANKAR OpenFOAM Post-Processing 30 May 21, 2024 04:54
Plotting Residuals in Tecplot mkewley FLUENT 2 September 18, 2018 13:35
[PyFoam] Plotting values (e.g. residuals) from all iterations with pyFoam chriss85 OpenFOAM Community Contributions 5 November 11, 2014 12:13
Plotting residuals krembil OpenFOAM Running, Solving & CFD 2 August 16, 2014 04:38
Plotting Residuals ata OpenFOAM 12 July 8, 2011 03:50
