December 16, 2016, 07:38 |
Segmentation fault (core dumped)
zhoubiao
Rep Power: 10 |
who can help me think the error source ? I have spent several days on it. Please help. Thanks in advance!
Best regards Zhou HTML Code:
[#48#zhou@zhou-All-Series ~/OpenFOAM/zhou-2.2.x/run/f/20161215/20161209]$checkMesh -allTopology -allGeometry /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-1f35a0ff2a58 Exec : checkMesh -allTopology -allGeometry Date : Dec 16 2016 Time : 21:40:24 Host : "zhou-All-Series" PID : 18490 Case : /home/zhou/OpenFOAM/zhou-2.2.x/run/f/20161215/20161209 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1179 dlopen error : /home/zhou/OpenFOAM/zhou-2.2.x/platforms/linux64GccDPOpt/lib/libfvPatchFieldsPyrolysis.so: undefined symbol: _ZTIN4Foam11basicThermoE --> FOAM Warning : From function dlLibraryTable::open(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99 could not load "libfvPatchFieldsPyrolysis.so" Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 544563 faces: 1599538 internal faces: 1549262 cells: 524800 faces per cell: 6 boundary patches: 10 point zones: 0 face zones: 7 cell zones: 0 Overall number of cells of each type: hexahedra: 524800 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Number of identical duplicate faces (baffle faces): 5618 Face-face connectivity OK. <<Writing 11236 faces with non-standard edge connectivity to set edgeFaces Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box wall 6560 6723 ok (non-closed singly connected) (-2 -2 0) (-2 2 4.1) side 19680 20003 ok (non-closed singly connected) (-2 -2 0) (2 2 4.1) outlet 6400 6561 ok (non-closed singly connected) (-2 -2 4.1) (2 2 4.1) ground 5616 5832 ok (non-closed singly connected) (-2 -2 0) (2 2 0) burner 144 169 ok (non-closed singly connected) (-1.9 -0.3 0) (-1.3 0.3 0) floor 640 709 ok (non-closed singly connected) (-1.9 -0.7 0) (-0.5 0.7 0) baffle1DWall_master 2990 3107 ok (non-closed singly connected) (-1.9 -0.7 0) (-0.5 0.7 1.4) baffle1DWall_slave 2990 3107 ok (non-closed singly connected) (-1.9 -0.7 0) (-0.5 0.7 1.4) baffle1DWall_slave1 2628 2782 ok (non-closed singly connected) (-0.5 -0.9 0) (-0.5 0.9 4.1) region0_to_panelRegion_panel2628 2782 ok (non-closed singly connected) (-0.5 -0.9 0) (-0.5 0.9 4.1) Checking geometry... Overall domain bounding box (-2 -2 0) (2 2 4.1) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (2.91283e-17 -8.9876e-17 4.44964e-17) OK. Max cell openness = 1.73472e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 0.0025. Maximum face area = 0.0025. Face area magnitudes OK. Min volume = 0.000125. Max volume = 0.000125. Total volume = 65.6. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.00012e-11 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.05 0.05 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : average = 1 min = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 1 average: 7.62223 Cell determinant check OK. Concave cell check OK. Mesh OK. End HTML Code:
[#21#zhou@zhou-All-Series ~/OpenFOAM/zhou-2.2.x/run/f/20161215/20161209]$fireFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.x-1f35a0ff2a58 Exec : fireFoam Date : Dec 16 2016 Time : 21:19:58 Host : "zhou-All-Series" PID : 17763 Case : /home/zhou/OpenFOAM/zhou-2.2.x/run/f/20161215/20161209 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // FireFOAM Build Version: 9f8ab38ff7dce6108bc5b4c155b18de7c8a3c4ba FireFOAM Build Time Stamp: Fri Dec 16 20:33:03 JST 2016 **************************************************** Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model eddyDissipationModel<psiThermoCombustion,gasHThermoPhysics> Selecting thermodynamics package { type hePsiThermo; mixture singleStepReactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader --> FOAM Warning : From function entry::getKeyword(keyType&, Istream&) in file db/dictionary/entry/entryIO.C at line 80 Reading /home/zhou/OpenFOAM/zhou-2.2.x/run/f/20161215/20161209/0/N2 found on line 102 the punctuation token '*' expected either } or EOF --> FOAM Warning : From function entry::getKeyword(keyType&, Istream&) in file db/dictionary/entry/entryIO.C at line 80 Reading /home/zhou/OpenFOAM/zhou-2.2.x/run/f/20161215/20161209/0/N2 found on line 102 the punctuation token '/' expected either } or EOF Fuel heat of combustion :4.63572e+07 stoichiometric air-fuel ratio :15.5715 stoichiometric oxygen-fuel ratio :3.62829 Maximum products mass concentrations: H2O: 0.0986136 CO2: 0.180679 N2: 0.720707 Combustion mode: explicit Reading thermophysical properties Creating component thermo properties: multi-component carrier - 5 species no liquid components no solid components Creating field rho Reading field p_rgh Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting turbulence model type LESModel Selecting LES turbulence model oneEqEddy Selecting LES delta type cubeRootVol oneEqEddyCoeffs { Prt 1; ce 1.048; ck 0.094; } stoichiometric mixture fraction is = 0.0603444 Creating field DpDt Calculating field g.h Creating pyrolysis model collection Selecting pyrolysisModel reactingOneDim21 Selecting region model functions none Selecting chemistry type { chemistrySolver ode; chemistryThermo pyrolysisChemistryModel; } chemistryTypeName ode<pyrolysisChemistryModel<basicSolidChemistryModel,constIso<hConst<rhoConst<specie>>,sensibleEnthalpy>,sutherland<janaf<perfectGas<specie>>,sensibleEnthalpy>>> Selecting thermodynamics package { type heSolidThermo; mixture reactingMixture; transport constIso; thermo hConst; energy sensibleEnthalpy; equationOfState rhoConst; specie specie; } Selecting chemistryReader foamChemistryReader pyrolysisChemistryModel: Number of solids = 2 Number of gases = 1 "v^4.86 = char + gas"; Selecting ODE solver SIBS Selecting radiationModel opaqueSolid Selecting absorptionEmissionModel greyMeanSolidAbsorptionEmission Selecting scatterModel none Selecting radiationModel fvDOM Selecting absorptionEmissionModel constRadFractionEmission Selecting scatterModel constantScatter fvDOM : Allocated 16 rays with average orientation: I0 : omega : 0.785398 I1 : omega : 0.785398 I2 : omega : 0.785398 I3 : omega : 0.785398 I4 : omega : 0.785398 I5 : omega : 0.785398 I6 : omega : 0.785398 I7 : omega : 0.785398 I8 : omega : 0.785398 I9 : omega : 0.785398 I10 : omega : 0.785398 I11 : omega : 0.785398 I12 : omega : 0.785398 I13 : omega : 0.785398 I14 : omega : 0.785398 I15 : omega : 0.785398 Constructing reacting cloud Constructing particle injection models Selecting injection model none Constructing surface film model Selecting surfaceFilmModel none Selecting region model functions none Courant Number mean: 0 max: 0 Starting time loop cellSource HRR:all(c0): total cells = 524800 total volume = 65.6 faceSource patchBurner: total faces = 144 total area = 0.36 faceSource patchPanel: total faces = 2628 total area = 6.57 faceSource patchOutlet: total faces = 6400 total area = 16 faceSource patchPanelSolidRegion: total faces = 2628 total area = 6.57 faceSource patchPanelQr: total faces = 2628 total area = 6.57 faceSource patchWallQr: total faces = 6560 total area = 16.4 faceSource patchSideQr: total faces = 19680 total area = 49.2 faceSource patchBurnerQr: total faces = 144 total area = 0.36 faceSource patchOutletQr: total faces = 6400 total area = 16 faceSource patchGroundQr: total faces = 5616 total area = 14.04 faceSource patchPanelQin: total faces = 2628 total area = 6.57 faceSource patchPanelConvectiveHeatFlux: total faces = 2628 total area = 6.57 surfaces patchSamplingGas: Reading surface description: pyrolysisPatch Courant Number mean: 0 max: 0 deltaT = 0.00952381 Time = 0.00952381 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 2.91856e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 3.02462e-08, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 3.28988e-08, No Iterations 1 DILUPBiCG: Solving for O2, Initial residual = 0.999447, Final residual = 1.89125e-15, No Iterations 2 DILUPBiCG: Solving for H2O, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for C3H8, Initial residual = 1, Final residual = 2.17871e-15, No Iterations 2 DILUPBiCG: Solving for CO2, Initial residual = 0, Final residual = 0, No Iterations 0 O2 min/ave/max = 0.23301 0.23301 0.23301 H2O min/ave/max = 0 0 0 C3H8 min/ave/max = -6.9622e-127 3.3546e-16 6.3517e-14 CO2 min/ave/max = 0 0 0 N2 min/ave/max = 0.76699 0.76699 0.76699 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::mapDistribute::mapDistribute(Foam::List<int> const&, Foam::List<int> const&) at ??:? #4 Foam::mappedPatchBase::calcMapping() const at ??:? #5 Foam::compressible::thermalBaffle1DFvPatchScalarField<Foam::constIsoSolidTransport<Foam::species::thermo<Foam::hConstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy> > >::updateCoeffs() at ??:? #6 Foam::mixedFvPatchField<double>::evaluate(Foam::UPstream::commsTypes) at ??:? #7 Foam::mixedEnergyFvPatchScalarField::updateCoeffs() at ??:? #8 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::GeometricBoundaryField::updateCoeffs() at ??:? #9 Foam::fvMatrix<double>::fvMatrix(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensionSet const&) at ??:? #10 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::Sp<double>(Foam::DimensionedField<double, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #11 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::Sp<double>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #12 Foam::radiation::radiationModel::Sh(Foam::fluidThermo&) const at ??:? #13 at ??:? #14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #15 at ??:? Segmentation fault (core dumped) |
March 7, 2017, 05:49 |
Hello Zhou,
You may have more luck if you post a test case to this thread: Adding New phaseCompressible Turbulence Model Regards, -Louis |
March 7, 2017, 10:53 |
Mahdi Hosseinali
Rep Power: 18 |
The first log says it cannot find your library named "libfvPatchFieldsPyrolysis.so", and there's an error in the second one. I'm not quiet acquainted with the models you are using, but it seems the second part is complaining about a bad dictionary. |
March 13, 2017, 20:05 |
#4 | |
zhoubiao
Rep Power: 10 |
March 13, 2017, 20:06 |
zhoubiao
Rep Power: 10 |
Thanks very much. I will try it again.
[OpenFOAM] paraview parafoam segmentation fault (core dumped) | RicardoLB | ParaView | 3 | April 28, 2020 20:07 |
Segmentation fault (core dumped) | NH1994 | OpenFOAM Pre-Processing | 0 | January 9, 2015 03:20 |
Segmentation fault (core dumped) | NH1994 | OpenFOAM Programming & Development | 0 | January 9, 2015 01:24 |
createPatch Segmentation Fault (CORE DUMPED) | sam.ho | OpenFOAM Pre-Processing | 2 | April 21, 2014 02:01 |
Segmentation fault (core dumped) when changing pressure BC | jptorol | OpenFOAM Running, Solving & CFD | 0 | September 25, 2013 18:05 |
