interFoam problems with stability
Like Tree2Likes
  • 2 Post By vatavuk
Old   November 18, 2016, 14:38
Default interFoam problems with stability
Federico Zabaleta
fedez91 is on a distinguished road
Dear Foamers,
I'm giving my first steps with 3D interFoam simulations, and I have some problems with the stability a model:
I'm trying to simulate a 3D channel with a derivation, which has a small step in it. The inlet consist of a constant volumetric flow (200 m3/s), and the two outlets consist of a spillway (to control the water level) and a gate (Check the images for a clearer explanation)
The problem is that I cant reach to a stable solution, because the simulations breaks before getting to a stationary state (Usually breaks between 40s and 110s).
More info:
OF version: 3.0.0
RAS Model: k-epsilon
U Inlet: VolumetricFlowRate (Advancing from 0 to 200)
U Outlet: zeroGradient
Mesh: From ICEM
Other parameters: From dambreak
I've been like two weeks trying to make it work, I've tried to change a lot of parameters, but still can't make it.
With this thread I attach the case and some pictures.
I would really appreciate any advice or recommendation from interFoam experienced users.
Please ask me if you need more information.
FoamCase:
https://drive.google.com/open?id=0B4...GNNNmNHcGZVMTA
fedez91 is offline   Reply With Quote
Old   November 23, 2016, 09:37
Federico Zabaleta
Any advice? At the beginning I was having problems with k-epsilon initial conditions. I was using very low values of k-epsilon (around 1E-4). Then I changed them to 0.1 (like in dambreak). Maybe the problem is there.
What are the usual values for initial conditions?
Old   November 25, 2016, 04:48
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Frederico,
For p_rhg, in the inlet, you should use the fixedFluxPressure boundary condition. The zeroGradient condition in the inlet makes interfoam unstable. See the discussion in http://bugs.openfoam.org/view.php?id=2013
Best Regards,
Paulo
imano and fedez91 like this.
vatavuk is offline   Reply With Quote
Old   November 30, 2016, 09:36
Federico Zabaleta
Dear Paulo,
Thank you very much for your answer.
I tried it and it worked ok!
Best Regards,
intefoam
interFoam stability issue, free surface ship hull jojosaxo OpenFOAM Running, Solving & CFD 5 July 7, 2016 18:29
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
interFoam Stability Issues Dazzler OpenFOAM Running, Solving & CFD 3 March 12, 2015 03:04
Stability problems with kepsilon in external aero edreed OpenFOAM Running, Solving & CFD 21 July 16, 2008 16:00
Problems involving interFoam and GCC 410 gschaider OpenFOAM Installation 1 July 30, 2006 20:58
