HELP! OF running on 1 processor despite decomposePar |
November 18, 2016, 13:21 |
Max Marschall
Rep Power: 10 |
Dear OF users,
I am new to CFD and OpenFOAM. I have managed to run some smaller simulations, but now I desperately need to run a larger one in parallel and it is not working. I have 10 cores (20 logical processors) and 64GB RAM, and am using the Windows version. I set the numberOfSubdomains to 8 (scotch method), and yet while the snappyHexMesh is calculated, my task manager shows me that only one of the processors is busy. This means the simulation is only running on 1 core, right?? I am quite clueless when it comes to PC hardware. A colleague from the IT department at our office told me that VT-x (which had to be enabled in the BIOS prior to Docker installation) PREVENTS the PC from running in parallel...this cannot be true, right? Any help or explanations "for dummies" would be HIGHLY appreciated! Regards, Max |
November 18, 2016, 16:19 |
Arsalan
Rep Power: 12 |
Hi Max,
What commands did you use for running snappyHexMesh in parallel mode? provide full steps please. Regards, Arsalan. |
November 21, 2016, 05:05 |
Max Marschall
Rep Power: 10 |
Solved...VirtualBox was deactivated!
cpu, decomposepar, openfoam, parallel, snappyhexmesh |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 14:30 |
running OpenFoam in parallel | vishwa | OpenFOAM Running, Solving & CFD | 22 | August 2, 2015 09:53 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 08:02 |
how to specify parallel running? (core i7 but with 6 cores running) | vitorspadeto | OpenFOAM Running, Solving & CFD | 2 | April 16, 2014 11:25 |
how to make parallel running? decomposePar. | panda60 | OpenFOAM | 1 | October 29, 2009 03:43 |
