Add new particle force with input parameters
Like Tree1Likes
  • 1 Post By ycui
Old   November 17, 2016, 12:33
Default Add new particle force with input parameters
ycui is on a distinguished road
Dear All,
I'm implementing a new particle force with two input parameters. And I want these two parameters can be read from input file (/constant), then I do not need to compile for every runs. The way I did as following:
IOdictionary environmentalProperties
IOobject
"environmentalProperties",
runTime.constant(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
scalar a(readScalar(environmentalProperties.lookup("a"))) ;
scalar b(readScalar(environmentalProperties.lookup("b"))) ;
However, during compiling, errors occurs:
error: ‘runTime’ was not declared in this scope
error: ‘mesh’ was not declared in this scope
I need your help!
Greetings,
ycui
ycui is offline   Reply With Quote
Old   November 17, 2016, 12:41
floquation's Avatar
Kevin van As
floquation will become famous soon enough
(Please use code-tags, not quote-tags for code.)
The error is quite clear: the variables 'runTime' and 'mesh' do not exist at the position where you inserted your code.
So where exactly did you insert this piece of code?
floquation is offline   Reply With Quote
Old   November 17, 2016, 12:44
In: /home/ycui/OpenFOAM/ycui-2.3.1/src/lagrangian/intermediate/submodels/Kinematic/ParticleForces/
I try to use this->mesh().time() and this->mesh(), but doesn't works.
Old   November 17, 2016, 13:21
floquation's Avatar
Kevin van As
The mesh and runTime variables are part of the solver. The thing you are changing is a library used by the solver - but it has no knowledge of what is going on inside your solver. It is just doing its own thing.
To find out how to do this, use search commands:
cd ${FOAM_SRC}/lagrangian/intermediate/submodels/Kinematic/ParticleForces/
grep -rn "IOobject" .
This will teach you that OpenFoam has no example for you specifically related to ParticleForces. Going up one directory:
Will give you (amongst other examples) the file:
vi ./PatchInteractionModel/LocalInteraction/LocalInteraction.C +122
where the following may be seen:
template<class CloudType>
Foam::volScalarField& Foam::LocalInteraction<CloudType>::massEscape()
    if (!massEscapePtr_.valid())
        const fvMesh& mesh = this->owner().mesh();
        massEscapePtr_.reset
            new volScalarField
                IOobject
                    this->owner().name() + ":massEscape",
                    mesh.time().timeName(),
                    mesh,
                    IOobject::READ_IF_PRESENT,
                    IOobject::AUTO_WRITE
                mesh,
                dimensionedScalar("zero", dimMass, 0.0)
    return massEscapePtr_();
Can you try and see if that compiles for a ParticleForce?
Old   November 24, 2016, 05:18
Dear floquation,
Thank you very much for the answer.
I found a simple way to do this, just add
myParameter_(readScalar(this->coeffs().lookup("myParameter")))
in the constructor. Then the code can read from the input file.
However, your method would be very helpful when one reads a time dependent parameter.
Thank you again,
Best regards,
ycui
floquation likes this.
Old   March 22, 2017, 12:46
Shuai Yuan
sy2516 is on a distinguished road
Hey,
Can you help me to implement a new force to OpenFOAM? I really appreciate it. Thank you in advance.
sy2516 is offline   Reply With Quote
[PyFoam] and paraview eelcovv OpenFOAM Community Contributions 28 May 30, 2016 10:23
particles leave domain Steffen595 CFX 9 March 7, 2016 17:19
About the dimension of Saffman-Mei particle lift force model haakon OpenFOAM Programming & Development 1 April 22, 2013 13:27
model particle movement under magnetic force phsieh2005 Main CFD Forum 8 March 28, 2007 08:12
Setting particle parameters Mark FLUENT 0 April 22, 2004 13:13
