CompressibleInterFoam crashing with negative temperature values
Like Tree1Likes
  • 1 Post By student666
Old   November 12, 2016, 21:12
Default CompressibleInterFoam crashing with negative temperature values
Rizwan Zahoor
rzahoor is on a distinguished road
Hello Dear Foamers,
I have been trying for quite a time to solve the compressible flow of helium and water.
my boundry conditipons are as follows,
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
outlet-top
type zeroGradient;
outlet-front
type zeroGradient;
inlet-gas
type flowRateInletVelocity;
massFlowRate constant 1.1e-09;
rhoInlet 1.63;
value uniform (0 0 0);
inlet-liquid
volumetricFlowRate constant 4.1e-12;
front
type wedge;
back
type wedge;
fixedWalls
type fixedValue;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
inlet-gas
type fixedValue;
value uniform 300;
inlet-liquid
type fixedValue;
value uniform 300;
fixedWalls
type zeroGradient;
outlet-top
type zeroGradient;
outlet-front
type zeroGradient;
front
type wedge;
back
type wedge;
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 1e5;
boundaryField
inlet-liquid
type zeroGradient;
inlet-gas
type zeroGradient;
fixedWalls
type fixedFluxPressure;
outlet-top
type uniformFixedValue;
uniformValue tableFile;
uniformValueCoeffs
fileName "pout";
outOfBounds clamp;
interpolationScheme linear;
value $internalField;
outlet-front
uniformValueCoeffs
fileName "pout";
outOfBounds clamp;
back
type wedge;
front
type wedge;
object p;
boundaryField
inlet-liquid
type calculated;
inlet-gas
type calculated;
fixedWalls
type calculated;
outlet-top
type calculated;
outlet-front
type calculated;
front
type wedge;
back
type wedge;
I get to have the problem of case crashing with
MAXIMUM NUMBER OF ITERATIONS EXCEEDS when temperature goes to negative.
I have tried to change the pMin value and find out that it is very sensitive to the solution.
I am very much stuck.
I have opened a new tread as I have seen there are only few already exists and are quite old.
rzahoor is offline   Reply With Quote
Old   November 14, 2016, 13:07
Hesam
rapierrz is on a distinguished road
Hi Rizwan,
Two suggestion:
1.Use the buoyantPressure boundary condition for pressure at walls.
2.Use the upwind scheme for div(Phi,T)
rapierrz is offline   Reply With Quote
Old   November 14, 2016, 19:14
Rizwan Zahoor
Originally Posted by rapierrz View Post
Hi Rizwan,
Two suggestion:
Hello rapierrz
I am using of3.01 which has this alternative of pressure boundary condition to buoyantPressure you suggested as "fixedFluxPressure" which I am using. and Currently I have tried with the Upwind scheme for Temperature as well.
I have tried to use the CompressiblemultiphaseInterFoam for 2 fluids to see that it effect or no.
It currently solved the temperature problem but now When I alpha.* sums increase to something 34 which is very strange even with limited schemes as well like vanLeer01.
It has been few weeks And I have used whatever possible known to me in schemes boundary conditions.
One thing that struck to me is setting the pMin in thermoPhysical properties as chaniging these values effect the run time before crashing.
I would really appreciate if you or some one can guide me through this problem.
Thanks in advance
Old   May 9, 2017, 14:55
M. C.
student666 is on a distinguished road
I'm facing same problem too, my case is a cht.
Have you found a solution?
student666 is offline   Reply With Quote
Old   May 9, 2017, 16:17
Rizwan Zahoor
Yes i have found the solution it was just some tweeking the problem settings.
If you can explain in more detail the problem might be able to suggest something because the solution i found is problem dependent.
Regards
Rizwan
Old   May 9, 2017, 17:52
M. C.
Thx for the answer, well let's begin.
My case is a conjugate heat transfer with 3 regions: two fluids and one solid.
chtMultiRegionSimpleFoam
You can see the attached picture:
  • White region is air, inlet blue arrow is inlet, outlet blue arrow is outlet.
  • Green region is air, inlet red arrow is inlet, outlet red arrow is outlet.
  • at the inlet side of the green region a scalarSemiImplicitSourceCoeffs has been applied with 5000W (absolute).
  • case is symmetryc, from the picture the front surfaces are the symmetric Patches
Here follows BC for the green region, that's where the solver blows up.
U
    airCombInlet
        massFlowRate    0.00261;
        extrapolateProfile yes;
        rho             rho;
        rhoInlet        1.296;
        value           uniform ( 0 0 0 );
    airCombOutlet
        type            zeroGradient;
    simmetryComb
        type            symmetry;
    interCombSolido
        type            noSlip;
    wallComb
        type            noSlip;
    brac
        type            noSlip;
    verm
        type            noSlip;
    glass
        type            noSlip;
p_rgh
dimensions      [ 1 -1 -2 0 0 0 0 ];
internalField   uniform 100000;
boundaryField
        type            calculated;
        value           uniform 100000;
    interCombSolido
    wallComb
    brac    {
    verm    {
    glass
    simmetryComb
        type            symmetry;
    airCombInlet
        type            zeroGradient;
    airCombOutlet
        type            fixedValue;
T
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0/domain2";
    object      T;
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 333;
boundaryField
        type            calculated;
        value           uniform 0;
    airCombInlet
        type            fixedValue;
        value           uniform 333;
    airCombOutlet
        type            inletOutlet;
        inletValue      $internalField;
        value           uniform 333;
    simmetryComb
        type            symmetry;
    interCombSolido
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        Tnbr            T;
        kappaMethod     fluidThermo;
        value           uniform 333;
    wallComb
        type            fixedValue;
        value           uniform 333;
    glass
        type            fixedValue;
        value           uniform 333;
    brac    {
        type            zeroGradient;
    verm    {
        type            zeroGradient;
fvSchemes
gradSchemes
    default         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss upwind;
    div(phi,h)      bounded Gauss upwind;
    div(phi,e)      bounded Gauss upwind;
    div(phi,K)      bounded Gauss upwind;
    div(phi,k)      bounded Gauss upwind;
    div(phi,epsilon) bounded Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear limited corrected 0.33;
interpolationSchemes
    default         linear;
snGradSchemes
    default         limited corrected 0.33;
fvSolution
solvers
    rho
        solver          PCG
        preconditioner  DIC;
        tolerance       1e-7;
        relTol          0;
    p_rgh
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.01;
        smoother         GaussSeidel;
    "(U|h|k|epsilon|G|Ii)"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-6;
        relTol          0.1;
	    G
        $p_rgh;
        tolerance       1e-05;
        relTol          0.1;
SIMPLE
    momentumPredictor yes;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       100000;
    rhoMin          0.2;
    rhoMax          2;
relaxationFactors
    fields
        rho             1;
        p_rgh           0.7;
    equations
        U               0.3;
        "(h|e)"         0.3;
        k               0.3;
        epsilon         0.3;
 Time = 111
Solving for fluid region domain0
DILUPBiCG:  Solving for Ux, Initial residual = 0.003425795, Final residual = 6.650713e-005, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0008796441, Final residual = 1.250549e-005, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.00116966, Final residual = 1.796399e-005, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.003933221, Final residual = 0.0001691852, No Iterations 1
Min/max T:332.9558 472.7794
GAMG:  Solving for p_rgh, Initial residual = 0.003936741, Final residual = 3.912273e-005, No Iterations 4
time step continuity errors : sum local = 0.000285284, global = 3.655421e-005, cumulative = -0.1107264
Min/max rho:0.7353847 1.044312
DILUPBiCG:  Solving for epsilon, Initial residual = 0.000611032, Final residual = 1.05125e-005, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.003584877, Final residual = 4.231466e-005, No Iterations 1
Solving for fluid region domain2
DILUPBiCG:  Solving for Ux, Initial residual = 0.4614772, Final residual = 0.002864163, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.3183428, Final residual = 0.003177646, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.4175119, Final residual = 0.00325495, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.07116597, Final residual = 0.0005984709, No Iterations 1
Min/max T:-2593.727 4103.124
GAMG:  Solving for p_rgh, Initial residual = 0.09838701, Final residual = 0.0005937548, No Iterations 9
time step continuity errors : sum local = 1.725629, global = 0.06717613, cumulative = -0.04355032
Min/max rho:0.2 2
DILUPBiCG:  Solving for epsilon, Initial residual = 0.435361, Final residual = 0.006099735, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.2897566, Final residual = 0.003803847, No Iterations 1
Solving for solid region domain1
DICPCG:  Solving for h, Initial residual = 0.004453149, Final residual = 3.241994e-005, No Iterations 2
Min/max T:332.9824 847.455
ExecutionTime = 1175.907 s  ClockTime = 1176 s
fieldMinMax minMax write:
    min(T) = -2593.727 at location (0.04641332 0.3257848 0.06150029) on processor 1
    max(T) = 4103.124 at location (0.04349118 0.3399352 0.05850034) on processor 1
    min(mag(U)) = 0 at location (0.1318433 0.3246574 0.002) on processor 0
    max(mag(U)) = 3975.962 at location (0.04641332 0.3257848 0.06150029) on processor 1
    min(p) = -1.280926e+007 at location (0.04640306 0.3248925 0.0615002) on processor 1
    max(p) = 7.515909e+007 at location (0.04641018 0.3235 0.06149999) on processor 1
Time = 112
DILUPBiCG:  Solving for Ux, Initial residual = 0.003406134, Final residual = 6.638096e-005, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.0008713277, Final residual = 1.24063e-005, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.001160099, Final residual = 1.77978e-005, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.003906486, Final residual = 0.0001744858, No Iterations 1
Min/max T:332.9557 474.4734
GAMG:  Solving for p_rgh, Initial residual = 0.003913791, Final residual = 1.661483e-005, No Iterations 5
time step continuity errors : sum local = 0.0001209883, global = -1.862121e-005, cumulative = -0.04356895
Min/max rho:0.7327582 1.04431
DILUPBiCG:  Solving for epsilon, Initial residual = 0.0006029822, Final residual = 1.036041e-005, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 0.00358458, Final residual = 4.245114e-005, No Iterations 1
DILUPBiCG:  Solving for Ux, Initial residual = 0.1411693, Final residual = 0.001359373, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.1396355, Final residual = 0.001802189, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.1626392, Final residual = 0.001579086, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.03968777, Final residual = 0.000348543, No Iterations 1
job aborted:
[ranks] message
From a rough calculation, air at the green region should reach 2400K, but it gose over 5550K!!!
Then when it cools down pressure start to oscillate and when T becomes negative, it blows up...
Old   May 9, 2017, 17:56
M. C.
this is the output from checkMesh for green region
Create time
Create polyMesh domain2 for time = 0
Time = 0
Mesh stats
    faces:            5593869
    internal faces:   5280363
    cells:            1773483
    faces per cell:   6.131568
    boundary patches: 8
    point zones:      0
    face zones:       0
    cell zones:       4
Overall number of cells of each type:
    hexahedra:     1665623
    prisms:        3496
    wedges:        0
    pyramids:      2823
    tet wedges:    0
    tetrahedra:    1329
    polyhedra:     100212
    Breakdown of polyhedra by number of faces:
        faces   number of cells
            6   15990
            7   27867
            8   1345
            9   41192
           12   12183
           13   2
           15   1514
           18   115
           21   4
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
                   Patch    Faces   Points                  Surface topology
            airCombInlet     1930     2064  ok (non-closed singly connected)
           airCombOutlet     4526     4811  ok (non-closed singly connected)
                braciere     7452     7819  ok (non-closed singly connected)
                   glass    20480    21290  ok (non-closed singly connected)
         interCombSolido   193991   197764  ok (non-closed singly connected)
            simmetryComb    41465    42776  ok (non-closed singly connected)
             vermiculite    16810    17264  ok (non-closed singly connected)
                wallComb    26852    28166  ok (non-closed singly connected)
Checking geometry...
    Overall domain bounding box (-1.28892e-011 0.3235 0.00199986) (0.163 0.896 0.183019)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (4.390286e-014 2.73226e-016 -5.239765e-017) OK.
    Max cell openness = 3.663e-016 OK.
    Max aspect ratio = 14.34331 OK.
    Minimum face area = 1.858168e-009. Maximum face area = 1.639574e-005.  Face area magnitudes OK.
    Min volume = 2.982008e-013. Max volume = 7.268819e-008.  Total volume = 0.01381664.  Cell volumes OK.
    Mesh non-orthogonality Max: 75.72828 average: 8.746606
   *Number of severely non-orthogonal (> 70 degrees) faces: 303.
    Non-orthogonality check OK.
  <<Writing 303 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
    Max skewness = 2.409808 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
End
What is strange is that I already ran the same domain over a coarse mesh, even with more errors in the mesh, but it ran and I "succefully" (ok let's take with care) 2600K and the solution ran with no problem at all...
Old   May 9, 2017, 19:24
M. C.
Just adding some plots about min & max for p T and U
Old   May 10, 2017, 11:10
M. C.
I think I solved my problem by setting:
    airCombInlet
        extrapolateProfile no;
        rho             rho;
        rhoInlet        1.296;
I saw it, by checking direction of the flow at the inlet side with paraview.
If it is set to yes, U vectors (magnitude) are not perpendicular to the inlet patch and, as my heat source is at the inlet side, combination of the 2 factors raises this problem...I don't think that this is the solution, but 'till now it worked for me.
Maybe this setting is useful when you have a long pipe before entering the domain and you don't know the profile....I supposed
Regards
lth likes this.
Old   November 4, 2017, 15:19
Genji is on a distinguished road
Hello Foamers
I too have run across the problem described here. After a small time (0.2 seconds) my simulation breaks down and i get negative T. Also the max courant numbers, both interface and normal become bigger than one, while the mean is 100 to 1000 times smaller. I use compressibleInterFoam to simulate a hot gas (700K) entering from the ground, in an one block mesh, and the outlet is at one of the corners at top. It is an adaptation from a case I was using with interFoam that worked. Here are my files:
blockMesh
convertToMeters 1;
vertices
	(0 0 0)
	(10 0 0)
	(10 10 0)
	(0 10 0)
	(0 0 15)
	(10 0 15)
	(10 10 15)
	(0 10 15)
blocks
    hex (0 1 2 3 4 5 6 7) (40 40 60) simpleGrading (1 1 1)
edges
boundary
    floor
        type wall;
        faces
			(0 3 2 1)
    ceiling
        type wall;
        faces
			(4 5 6 7)
    fixedWalls
        type wall;
        faces
            (0 4 7 3)
            (2 6 5 1)
            (1 5 4 0)
            (3 7 6 2)
mergePatchPairs
topoSet (for inlet and outlet)
[CODE]
actions
name jetCells;
type cellSet;
action new;
source cylinderToCell;
sourceInfo
p1 (5 5 -0.01);
p2 (5 5 0.26);
radius 1;
name f2;
type faceSet;
action new;
source cellToFace;
sourceInfo
set jetCells;
option all;
name f2;
type faceSet;
action subset;
source boxToFace;
sourceInfo
box (4 4 -0.1) (6 6 0.1);
name f1;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (7.9 7.9 14.9) (10 10 15.1);
//boxes ((0 0 0) (1 1 1) (10 10 10)(11 11 11));
U
dimensions      [0 1 -1 0 0 0 0];//kg m s K mol A cd
internalField   uniform (0 0 0);//Initially the velocity is (0 0 0) m/s
boundaryField
    inlet
    type             turbulentInlet;
	referenceField		uniform (0 0 10.5);
	fluctuationScale  		(0.1 0.1 0.5);
	value		uniform (0 0 10.5); //fixed inlet velocity
    outlet
        type            pressureInletOutletVelocity;
    floor
        type            noSlip;
    fixedWalls
        type            noSlip;
	ceiling
        type            noSlip;
T
boundaryField
    inlet
        type            fixedValue;
        value           uniform 700;
    outlet
		type            zeroGradient;
		//type            inletOutlet;
        phi             rhoPhi;
        //inletValue      $internalField;
    floor
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
	ceiling
        type            zeroGradient;
p_rgh
boundaryField
    inlet
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
    outlet
        type            totalPressure;
		phi             rhoPhi;
        rho             rho;
        p0              uniform 1e5;
    floor
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
    fixedWalls
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
	ceiling
		phi             rhoPhi;
        rho             rho;
        value           uniform 1e5;
p
boundaryField
    inlet
        type               calculated;
    outlet
        type               calculated;
    floor
        type               calculated;
    fixedWalls
        type               calculated;
	ceiling
        type               calculated;
        value              $internalField;;
alpha.gas (we have gas and air)
dimensions      [0 0 0 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet
        type            fixedValue;
	value	 	uniform 1;
    outlet
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    floor
        type            zeroGradient;
    fixedWalls
        type            zeroGradient;
	ceiling
        type            zeroGradient;
thermophysicalProperties
phases (gas air);
pMin            pMin [1 -1 -2 0 0 0 0] 10000;
sigma           sigma [1 0 -2 0 0 0 0] 0.07;
thermophysicalProperties.air
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
    specie
        molWeight   28.9;
    thermodynamics
        Cp          1.005;
        Hf          0;
    transport
        mu          1.48e-05;
        Pr          0.7;
thermophysicalProperties.gas
thermoType
	type            heRhoThermo;
    transport       const;
    thermo          hConst;
    specie          specie;
mixture
    specie
        molWeight   44.0;
    equationOfState
        rho         1;
    thermodynamics
        Cp          1.116;
        Hf          0;
    transport
        mu          1e-6;
        Pr          0.713;
transportProperties
phases (gas air);
gas
    transportModel  Newtonian;//Newtonian fluid assumed
    nu              [0 2 -1 0 0 0 0] 1e-06;
    rho             [1 -3 0 0 0 0 0] 0.6;
air
    nu              [0 2 -1 0 0 0 0] 1.48e-05;
    rho             [1 -3 0 0 0 0 0] 1;
sigma           [1 0 -2 0 0 0 0] 0;//surface tension of gas/air
and I am calculating this as a laminar flow.
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
	"alpha.gas.*"
		nAlphaCorr      2;
		nAlphaSubCycles 1;
		cAlpha          1.5;
		MULESCorr       yes;
		nLimiterIter    3;
		solver          smoothSolver;
		smoother        symGaussSeidel;
		tolerance       1e-8;
		relTol          0;
     cellDisplacement
        solver          GAMG;
        tolerance       1e-5;
        relTol          0;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    "rho.*|pcorr.*"
        solver          PCG;
        preconditioner  DIC;
        tolerance       1e-8;
        relTol          0;
    p_rgh
        solver           GAMG;
        tolerance        1e-8;
        relTol           0.05;
        smoother         DICGaussSeidel;
        nPreSweeps       0;
        nPostSweeps      2;
        cacheAgglomeration on;
        mergeLevels      1;
    p_rghFinal
        $p_rgh;
        tolerance       1e-08;
        relTol          0;
    "(U|k|epsilon|T)"
        tolerance       1e-08;
        relTol          0.1;
    "(U|k|epsilon|T)Final"
        $U;
        tolerance       1e-08;
        relTol          0;
PIMPLE
    momentumPredictor no;
    nOuterCorrectors 2;
    nCorrectors      4;
    nNonOrthogonalCorrectors 1;
    correctPhi              yes;
    checkMeshCourantNo      no;
    moveMeshOuterCorrectors no;
    transonic   false;
relaxationFactors
    fields
    equations
        ".*"    1;
fvSchemes
ddtSchemes
    default         Euler;
gradSchemes
divSchemes
    default         none;
    div(rhoPhi,U)       Gauss linearUpwind grad(U);
    div(phi,alpha)      Gauss vanLeer;
    div(phirb,alpha)    Gauss linear;
    div(rhoPhi,K)       Gauss linear;
    div(rhoPhi,T)       Gauss linear;
    div(phi,thermo:rho.gas) Gauss linear;
    div(phi,thermo:rho.air) Gauss linear;
    div((phi+meshPhi),p)    Gauss linear;
    div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    default         linear;
snGradSchemes
    default         corrected;
controlDict
application     compressibleInterFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime        	15;
deltaT          0.005;
writeControl    adjustableRunTime;
writeInterval   0.05;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression uncompressed;
timeFormat      general;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo           1;
maxAlphaCo      1;
maxDeltaT       1;
So, where am I going wrong with this? Any help would be greatly appreciated.
Best Regards.
Genji is offline   Reply With Quote
[blockMesh] blockMesh error - Negative Volume Block adoledin OpenFOAM Meshing & Mesh Conversion 2 June 22, 2016 11:44
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Problem of negative temperature hnemati Main CFD Forum 0 April 1, 2014 06:25
temperature going negative behind a bluff body Sourabh Phoenics 6 December 1, 2007 19:50
