simpleFoam/potentialFoam crash during fvc::reconstruct(phi); |
November 10, 2016, 06:02 |
benoit paillard
Rep Power: 16 |
Hi all,
I'm getting a very strange potentialFoam crash, with very limited information : #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 ? at tensorField.C:? #4 ? at ??:? #5 ? at ??:? #6 ? at ??:? #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #8 ? at ??:? I could identify that this occur during fvc::reconstruct(phi); One case would work, and suddenly it would occur with a very slight change to the input CAD : adding one point discretization to the CAD, or something similar. You can find two cases below, generated by the exact same script, with this kind of very slight geometry change. If your run potentialFoam, one works, the other does not. checkMesh logs are very similar, and give no bad checks. https://dl.dropboxusercontent.com/u/...geCrash.tar.gz I've tried changing boundary condition, schemes, solvers... And I'm stuck now. Any idea is welcome ! Thanks a lot. |
November 10, 2016, 11:15 |
Here's more detailed printStack: Code:
#0 "Foam::error::printStack(Foam::Ostream&)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #1 "Foam::sigFpe::sigHandler(int)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #2 "_sigtramp" in /usr/lib/system/libsystem_platform.dylib #3 ? in /usr/lib/system/libsystem_platform.dylib #4 "void Foam::inv<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> const&)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/bin/potentialFoam #5 "Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > Foam::inv<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/bin/potentialFoam #6 "Foam::tmp<Foam::GeometricField<Foam::outerProduct<Foam::Vector<double>, double>::type, Foam::fvPatchField, Foam::volMesh> > Foam::fvc::reconstruct<double>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/bin/potentialFoam #7 "main" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/bin/potentialFoam #8 "start" in /usr/lib/system/libdyld.dylib #9 ? in /usr/lib/system/libdyld.dylib Code:
inv(surfaceSum(SfHat*mesh.Sf())) And finally if we try to find the reason for error in this inv call with something like: Code:
... surfaceVectorField SfHat(mesh.Sf()/mesh.magSf()); volTensorField l(fvc::surfaceSum(SfHat*mesh.Sf())); forAll(l.boundaryField(), i) { const auto& t = l.boundaryField()[i]; Info << t.patch().name() << endl; forAll(t, j) { Info << " " << j << ' ' << inv(t[j]) << endl; } } ... Code:
... cyclic2 ... 1889 #0 "Foam::error::printStack(Foam::Ostream&)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #1 "Foam::sigFpe::sigHandler(int)" in ~/OpenFOAM/OpenFOAM-4.x/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #2 "_sigtramp" in /usr/lib/system/libsystem_platform.dylib #3 ? in /usr/lib/system/libsystem_platform.dylib #4 "start" in /usr/lib/system/libdyld.dylib Floating point exception: 8 ... Last edited by alexeym; November 10, 2016 at 11:18. Reason: Index names (though does not cause real problems yet allows avoid questions) |
November 13, 2016, 06:10 |
benoit paillard
Rep Power: 16 |
Right on spot, thanks for that ! So yes when I use another BC than cyclicAMI it solves the problem. I guess the issue is that the cyclicAMI boundaries are not perfectly planar, don't you think ?
I've had this kind of problem before with cfMesh when using symmetryPlane, and cfMesh comes with a little tool called improveSymmetryPlane, just for that. However it does not solve the issue there... I'll keep investigating. On a side note, could you explain how you got all the detailed information in your log file ? Is it by compiling with the debug switch ? Thanks a lot. |
November 14, 2016, 04:29 |
If we try to estimate planarity of the boundary as
and collect the value over patches then in crash we'll get: Code:
inlet -> (mean/min/max) 0/0/0 outlet -> (mean/min/max) 0/0/0 top -> (mean/min/max) 0.899109983859/0.00240276244157/1.6782288672 cyclic1 -> (mean/min/max) 1.43440756948e-06/6.88859781417e-10/1.5537488795e-05 cyclic2 -> (mean/min/max) 1.31060120671e-06/5.00398454048e-09/2.02451551045e-05 blade -> (mean/min/max) 1.13754771335/0.000879164564671/1.99999999318 Code:
inlet -> (mean/min/max) 0/0/0 outlet -> (mean/min/max) 0/0/0 top -> (mean/min/max) 0.899109979388/0.00240276246383/1.6782288672 cyclic1 -> (mean/min/max) 1.45851551374e-06/6.29867927562e-10/1.88279589695e-05 cyclic2 -> (mean/min/max) 1.50303790729e-06/6.38616663096e-09/1.83836433187e-05 blade -> (mean/min/max) 1.13989044808/0.00175623855917/1.99999991869 Concerning printStack output, guess clang/lldb do better job in generating source code map/address resolution than gcc/addr2line pair. On Linux you get similar output with WM_COMPILE_OPTION set to Debug. |
November 16, 2016, 08:11 |
benoit paillard
Rep Power: 16 |
All right I got it ! I could solve some of this non-planarity issue in the CAD software, by better stl discretization around specific features.
Thanks a lot for your help, it is very much appreciated. |
[swak4Foam] swak4foam-0.3.0 make parallel run crash on foam-extend-3.0 | Aleksey_R | OpenFOAM Community Contributions | 12 | March 22, 2019 08:57 |
Simulation crash with dynamicRefineFvMesh and kOmegaSST - OF 2.3.x | nathanael | OpenFOAM Running, Solving & CFD | 4 | June 29, 2014 18:02 |
Crash when using DPMfoam for LPT of objects contacting a vibrating wall | ansubru | OpenFOAM Running, Solving & CFD | 0 | May 1, 2014 04:24 |
Paraview crash | Nixlax | OpenFOAM Installation | 4 | February 15, 2014 18:21 |
Dragging Slice File = Crash | cbritan | OpenFOAM Bugs | 3 | January 6, 2011 04:58 |
