segmentatio fault using cyclic boundary conditions in FOAM extend 3.2
Like Tree1Likes
  • 1 Post By GFarello
Old   October 28, 2016, 07:40
Default segmentatio fault using cyclic boundary conditions in FOAM extend 3.2
GFarello is on a distinguished road
Hi everybody,
I have a very simple hexahedral fluid domain formed by an inlet, an outlet and four side walls. An object is included in this domain and my intention is to study the flow through this object using the Immersed Boundary Method.
Up to now everything works fine but, instead of having four solid side walls, I would like to set the patch type to cyclic (for the side walls) in order to simulate a periodic boundary.
I set the blockMeshDict as follows
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     3.2                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 1;
vertices
    (-112 0 0)
    (336 0 0)
    (336 56 0)
    (-112 56 0)
    (-112 0 28)
    (336 0 28)
    (336 56 28)
    (-112 56 28)
blocks
  hex (0 1 2 3 4 5 6 7) (448 56 28) simpleGrading (1 1 1)
boundary
    in
      type patch;
      faces ((0 4 7 3));
    out
      type patch;
      faces ((2 6 5 1));
    lato1
      type cyclic;
      neighbourPatch lato2;
      faces ((0 1 2 3));
      matchTolerance 0.01;
    lato2
      type cyclic;
      neighbourPatch lato1;
      faces ((4 5 6 7));
    lato3
      type cyclic;
      neighbourPatch lato4;
      faces ((0 4 5 1));
    lato4
      type cyclic;
      neighbourPatch lato3;
      faces ((3 7 6 2));
If I run blockMesh i get this message:
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 3.2-5ab3390aef43
Exec     : blockMesh
Date     : Oct 28 2016
Time     : 12:19:16
Host     : JM's_NB
PID      : 4946
CtrlDict : "/home/amedeo/Scrivania/Documenti/ibNew/system/controlDict"
Case     : /home/amedeo/Scrivania/Documenti/ibNew
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Creating block mesh from
    "/home/amedeo/Scrivania/Documenti/ibNew/constant/polyMesh/blockMeshDict"
No non-linear edges defined
Creating topology blocks
Creating topology patches
Creating block mesh topology
Segmentation fault (core dumped)
I also tried to set the blockMeshDict with only patches without any specification on the nature of the boundaries and then setting the cyclic patches in the boundary file;
in this case blockMesh works (obviously...) but i get the same message error (segmentation fault) in the solver log (i.e. potentialIBFoam).
I really don't understand what's wrong because the error message is too generic but maybe I'm doing some trivial mistake.
GFarello is offline   Reply With Quote
Old   January 16, 2017, 08:05
Milad Setareh
milad653279 is on a distinguished road
Hi
I have the same problem, any response????
milad653279 is offline   Reply With Quote
Old   January 18, 2017, 06:27
this should work:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
convertToMeters 1;
vertices
    (-112 0 0)
    (336 0 0)
    (336 56 0)
    (-112 56 0)
    (-112 0 28)
    (336 0 28)
    (336 56 28)
    (-112 56 28)
blocks
boundary
    in
      type patch;
      faces ((0 4 7 3));
    out
      type patch;
      faces ((2 6 5 1));
    sxdx
      type cyclic;
      faces ((0 3 2 1) (4 5 6 7));
    topbottom
      type cyclic;
      faces ((1 5 4 0) (3 7 6 2));
olegrog likes this.
cyclic boundaries, foam extend 3.2, immersed boundary method
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
