October 6, 2016, 03:32 |
Maximum number of iterations exceeded
Sheng,Qiming
Rep Power: 10 |
Hi all,
I want to solve a heat transfer Project using chtMultiRegionSimpleFoam. All the pre-processing is ok. But when i run the case, this Error happens and I dont know how to deal with it: --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/saeed/OpenFOAM/OpenFOAM-2.4.0/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam:olynomialTransport<Foam:: species::thermo<Foam::hPolynomialThermo<Foam::icoP olynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > >::calculate() at ??:? #3 Foam::heRhoThermo<Foam::rhoThermo, Foam:ureMixture<Foam:olynomialTransport<Foam:: species::thermo<Foam::hPolynomialThermo<Foam::icoP olynomial<Foam::specie, 8>, 8>, Foam::sensibleEnthalpy>, 8> > >::correct() at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Aborted (core dumped) I use the Mesh from ICEM and I have changed the solver by myself. I wait for your help. Yours Qiming |
October 7, 2016, 11:35 |
Taher Chegini
Rep Power: 13 |
There are many reasons that can cause this problem. It could be because of inappropriate schemes and solutions or even boundary conditions. Unless you prove more details, you will not get an answer.
October 10, 2016, 09:22 |
#3 | |
Sheng,Qiming
Rep Power: 10 |
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother DIC; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 100; } "(U|h|e|k|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-6; relTol 0.001; } } SIMPLE { nNonOrthogonalCorrectors 2; rhoMax rhoMax [ 1 -3 0 0 0 ] 1100; rhoMin rhoMin [ 1 -3 0 0 0 ] 700; } relaxationFactors { fields { rho 1; p_rgh 0.7; } equations { U 0.3; "(h|e)" 0.1; k 0.3; epsilon 0.3; } } // ************************************************** *********************** // // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default none;//Gauss linear; grad(U) Gauss linear; grad(p_rgh) Gauss linear; grad(rho) Gauss linear; grad(h) cellLimited Gauss linear 1.0; } divSchemes { default none; div(phi,U) bounded Gauss upwind; div(phi,h) bounded Gauss upwind; div(phi,e) bounded Gauss upwind; div(phi,K) bounded Gauss upwind; div(phi,k) bounded Gauss upwind; div(phi,epsilon) bounded Gauss upwind; div((muEff*dev2(T(grad(U))))) Gauss linear; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear limited 1.0; } interpolationSchemes { default linear; } snGradSchemes { default limited 1.0; } fluxRequired { default no; p_rgh; } // ************************************************** *********************** // I used ICEM to create the geometry and mesh and some boundaries are symmetries. Looking forward to your help. |
October 10, 2016, 11:00 |
Rep Power: 21 |
I have answered this question quite often. Check some of those responses. Your crash can occur for a multitude of reasons.
Use checkMesh -allGeometry -allTopology to check if there are reasons to suspect the mesh. I will assume boundary condition and mesh are alright. The next thing one should do is changing to upwind schemes. Since you have done that: chtMultiRegion is a solver that needs to be handled carefully. Most crashes with regards to thermo are related to bad initialization. Since pressure / temperature influence each other this can go wrong quickly if you have wrong values within the first iterations. This usually leads to temperatures falling below inlet temperature and a crash afterwards. The easiest way to combat this (next to the obvious ones like using a good mesh) is to initialize with an already solved velocity and pressure field from a calculation without temperature. Since you are solving a steady state case this shouldn't be a problem. If you are using a new openfoam version you can also use the fvOptions to limit or fix temperature and velocity on start up. There are other things to consider, but this is the main difficulty. Most often this occurs in combination with turbulence models (whose initial values are chosen poorly). |
October 10, 2016, 11:17 |
#5 | |
Sheng,Qiming
Rep Power: 10 |
thanks for your quick reply. When i use the checkMesh command u mentioned above, it shows like the following: // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Enabling all (cell, face, edge, point) topology checks. Enabling all geometry checks. Time = 0 Mesh stats points: 385174 internal points: 0 edges: 961483 internal edges: 191139 internal edges using one boundary point: 0 internal edges using two boundary points: 191139 faces: 768172 internal faces: 383000 cells: 191862 faces per cell: 6 boundary patches: 16 point zones: 0 face zones: 5 cell zones: 5 Overall number of cells of each type: hexahedra: 191862 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. <<Writing 4 cells with two non-boundary faces to set twoInternalFacesCells Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box fluid.side:008 1 4 ok (non-closed singly connected) (750 0 -100) (750.01 0.0647212 -100) barriere.side:002 9 20 ok (non-closed singly connected) (845 0 465) (851 0.07882202 465) mantel.base 11240 12386 ok (non-closed singly connected) (740 0 -100) (861 0 465) fluid.base 106277 109489 ok (non-closed singly connected) (750 0 -100) (851 0 465) isolation.base 13672 15423 ok (non-closed singly connected) (756 0 3) (845 0 465) leiter.base 60160 63120 ok (non-closed singly connected) (756 0 24) (845 0 438) barriere.base 513 620 ok (non-closed singly connected) (750 0 24) (851 0 465) isolation.side 104 210 ok (non-closed singly connected) (756 0 465) (845 0.07798427 465) isolation.top 13672 15423 ok (non-closed singly connected) (756 0.06555755 3) (845 0.07798427 465) leiter.top 60160 63120 ok (non-closed singly connected) (756 0.06555755 24) (845 0.07798427 438) mantel.side 1164 2332 ok (non-closed singly connected) (740 0 -100) (861 0.08021829 465) mantel.top 11240 12386 ok (non-closed singly connected) (740 0.06332354 -100) (861 0.08021829 465) barriere.top 513 620 ok (non-closed singly connected) (750 0.0647198 24) (851 0.07882202 465) fluid.top 106277 109489 ok (non-closed singly connected) (750 0.0647198 -100) (851 0.07882202 465) einlauf 141 284 ok (non-closed singly connected) (750.01 0 -100) (851 0.07882202 -100) auslauf 29 60 ok (non-closed singly connected) (750 0 465) (756 0.06555755 465) Checking geometry... Overall domain bounding box (740 0 -100) (861 0.08021829 465) Mesh (non-empty, non-wedge) directions (0 0 1) Mesh (non-empty) directions (0 0 1) ***Number of edges not aligned with or perpendicular to non-empty directions: 698707 <<Writing 376000 points on non-aligned edges to set nonAlignedEdges Boundary openness (1.042877e-18 1.49583e-14 3.058842e-18) OK. Max cell openness = 6.663393e-16 OK. Max aspect ratio = 1 OK. Minimum face area = 0.0001636679. Maximum face area = 4.573593. Face area magnitudes OK. Min volume = 1.059556e-05. Max volume = 0.3665665. Total volume = 4906.618. Cell volumes OK. Mesh non-orthogonality Max: 86.75979 average: 27.87333 *Number of severely non-orthogonal (> 70 degrees) faces: 18523. Non-orthogonality check OK. <<Writing 18523 non-orthogonal faces to set nonOrthoFaces Face pyramids OK. Max skewness = 2.675886 OK. Coupled point location match (average 0) OK. Face tets OK. Min/max edge length = 0.002543016 4.616543 OK. All angles in faces OK. Face flatness (1 = flat, 0 = butterfly) : min = 0.9999976 average = 1 All face flatness OK. Cell determinant (wellposedness) : minimum: 1 average: 1 Cell determinant check OK. Concave cell check OK. Face interpolation weight : minimum: 0.00934411 average: 0.4262096 ***Faces with small interpolation weight (< 0.05) found, number of faces: 1576 <<Writing 1576 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: 0.00551306 average: 0.7648417 ***Faces with small volume ratio (< 0.01) found, number of faces: 238 <<Writing 238 faces with low volume ratio cells to set lowVolRatioFaces Failed 3 mesh checks. End Do you know where is wrong with the mesh? I can't find it although it says there are 3 fails. |
October 10, 2016, 11:26 |
Rep Power: 21 |
Your mesh is unusable. Often these failure messages from -allTopology -allGeometry can be ignored and it will work nevertheless. In your case checkMesh fails without any of those. The problem is the non orthogonality.
While the average value is extremly good, your maximum value is highly questionable. Max: 86.75979 A value above 90 means that your mesh is physically wrong. Your cells are inside out at that point. You need to lower that one is particular. You need to remesh! I'd throw away everything above 60 usually. You can choose limiters and such to get a result nevertheless but I'd remesh since your results won't be accurate otherwise. |
October 10, 2016, 11:29 |
#7 | |
Sheng,Qiming
Rep Power: 10 |
thanks a lot for your information ! I will remesh and try again. |
October 10, 2016, 12:10 |
#8 | |
Sheng,Qiming
Rep Power: 10 |
I use the Mesh from ICEM and this mesh is ok and can run good in ansys-cfx. To compare the results from both softwares, the mesh need to be the same. Can i solve this problem without change the mesh? Or i must do it. Thanks for your help. Qiming |
April 6, 2019, 15:01 |
#9 |
Kamgaing Rouxel
Rep Power: 7 |
Dear Qiming,
Have you finally solve your problem? i'm runing a simulation with the same solver but i got the same errors you've got in the past. Could you please help me? Yours, Rouxel. |
July 24, 2019, 10:56 |
#10 | |
Raza Javed
Rep Power: 7 |
Hi, Does making the cell size smaller helps in lowering the non-orthogonality? I am also having non-orthogonality of around 86 degree. |
September 26, 2019, 13:18 |
Boundary Conditions
#11 |
Arthur
Rep Power: 12 |
In my case it was boundary conditions.
I solved the problem (no transitory) starting with lower difference of temperature between BCs and increasing it sofetly once the previous solution converged! |
iteration error |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
