kEpsilon turbulence model and twoPhaseEulerFoam |
September 20, 2016, 16:01 |
Rémi Demol
Rep Power: 10 |
Hi everyone,
I've run several times my case (a bubble column) using twoPhaseEulerFoam and mixtureKEpsilon turbulent model for both phases. I want to change the turbulence model to the standard kEpsilon model. So I changed the turbulentProperties files. But it crashed at the first iteration. Maybe the answer is in the forum but I didn't find it yet. Does anyone have a clue to fix it ? Edit : I have to had that I consider the free surface in my simulation, that's maybe the raison why it crashed. Thanks in advance for your answer. My version of OF is 3.0.1 Here is what I got in my terminal Code:
Starting time loop Courant Number mean: 0.000104375 max: 0.00166667 Max Ur Courant Number = 0.00166667 deltaT = 0.00119617 Time = 0.00119617 PIMPLE: iteration 1 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.0624943 Min(alpha.air) = 0 Max(alpha.air) = 1 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 1, Final residual = 4.30053e-09, No Iterations 2 smoothSolver: Solving for e.water, Initial residual = 0.998714, Final residual = 1.41482e-07, No Iterations 1000 min T.air 349.868 min T.water 350 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 3.19227e-09, No Iterations 9 PIMPLE: iteration 2 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.0625092 Min(alpha.air) = 0 Max(alpha.air) = 1 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.951929, Final residual = 8.62357e-10, No Iterations 2 smoothSolver: Solving for e.water, Initial residual = 0.00241502, Final residual = 3.63505e-10, No Iterations 1 min T.air 350 min T.water 350 GAMG: Solving for p_rgh, Initial residual = 0.000249446, Final residual = 3.19735e-09, No Iterations 5 PIMPLE: iteration 3 MULES: Solving for alpha.air MULES: Solving for alpha.air alpha.air volume fraction = 0.0625042 Min(alpha.air) = 0 Max(alpha.air) = 1 Constructing momentum equations smoothSolver: Solving for e.air, Initial residual = 0.998442, Final residual = 3.91661e-11, No Iterations 2 smoothSolver: Solving for e.water, Initial residual = 0.00105975, Final residual = 2.61401e-10, No Iterations 1 min T.air 348.551 min T.water 350 GAMG: Solving for p_rgh, Initial residual = 0.000489843, Final residual = 8.84302e-10, No Iterations 5 #0 "Foam::error::printStack(Foam::Ostream&)" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #1 "Foam::sigFpe::sigHandler(int)" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #2 "_sigtramp" in /usr/lib/system/libsystem_platform.dylib #3 ? in /usr/lib/system/libsystem_platform.dylib #4 "Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #5 "Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libOpenFOAM.dylib #6 "Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&)" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libfiniteVolume.dylib #7 "Foam::fvMatrix<double>::solve(Foam::dictionary const&)" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libphaseCompressibleTurbulenceModels.dylib #8 "Foam::fvMatrix<double>::solve()" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libphaseCompressibleTurbulenceModels.dylib #9 "Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&)" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libphaseCompressibleTurbulenceModels.dylib #10 "Foam::RASModels::kEpsilon<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::PhaseCompressibleTurbulenceModel<Foam::phaseModel> > > >::correct()" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libphaseCompressibleTurbulenceModels.dylib #11 "Foam::twoPhaseSystem::correctTurbulence()" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/lib/libcompressibleTwoPhaseSystem.dylib #12 "main" in /Volumes/OpenFOAM/OpenFOAM-3.0.1/platforms/darwin64ClangDPInt32Opt/bin/twoPhaseEulerFoam #13 "start" in /usr/lib/system/libdyld.dylib #14 ? in /usr/lib/system/libdyld.dylib Floating point exception: 8 Last edited by remidemol; September 20, 2016 at 16:47. Reason: More information |
October 31, 2016, 14:48 |
Rep Power: 15 |
Hi Rémi!
Did you find how to solve this problem? Best, Antonio |
November 1, 2016, 10:33 |
Rémi Demol
Rep Power: 10 |
Hi Maalan,
I didn't solve that problem with the twoPhaseEulerFoam solver but it works with multiphaseEulerFoam. I suggest you to move on this solver in which you can define 2 phases or more than 2. Best regards. |
November 3, 2016, 05:02 |
Rep Power: 15 |
Great! I'm using OpenFOAM 2.3.x and I had to modify multiphaseEulerFoam to have RAS models also included.
Thanks Rémi! Regards |
June 18, 2017, 07:14 |
farzad khallaghi
Rep Power: 10 |
hi remi and malaan
i have same problem with twoPhaseEulerFoam. so do you solve your problem by changing solver? i really have limitation in my time so do you think multiPhaseEulerFoam solve problem about modeling air bubble plume and using different turbulence model or i have to do something else? thanks a lot farzad |
July 14, 2017, 07:24 |
Atul Walia
Rep Power: 9 |
Hi, how do i define the proper values of drag and lift force in bubble column, is there any formula for that or i just have to choose a random value, please help me out,
July 14, 2017, 11:58 |
Rémi Demol
Rep Power: 10 |
Hi Atul,
You can define drag, lift, turbulent dispersion, added-mass or wall lubrication models from file constant/phaseProperties Few models have been already implemented, you can put a question mark after keyword "type" and then run twoPhaseEulerFoam (or other solver) to see the different models. You can also implement an other. |
RAS turbulence model in multiphase Euler solver for dilute particle laden flows | openfoammaofnepo | OpenFOAM | 0 | July 4, 2016 18:29 |
Turbulence modelling for bubble column in twoPhaseEulerFoam | hester | OpenFOAM Running, Solving & CFD | 2 | February 10, 2015 12:42 |
Buggy twoPhaseEulerFoam turbulence Model | Kenna | OpenFOAM Pre-Processing | 2 | December 2, 2013 08:43 |
twoPhaseEulerFoam: turbulence on produces instability of drag phase | florian_krause | OpenFOAM | 1 | October 11, 2013 10:02 |
twoPhaseEulerFoam turbulence model | GerhardHolzinger | OpenFOAM Running, Solving & CFD | 6 | October 16, 2012 05:28 |
