September 12, 2016, 10:55 |
Energy Equation - Adding source term
Rep Power: 13 |
My Problem:
My question: Hello everyone. I am working on convective heat transfer problem. I want to solve temperature both for fluid and solid regions. As I know, I can model this using multiRegionSolver of OpenFOAM. I want to generate heat inside solid block and analyze effect of solid thermal conductivity on heat transfer. I think I can do this by adding source term to energy equation for solid region. I am beginner at OpenFOAM and I could not find a way to add heat generation as a source term into my solid region energy equation. Is it possible to do this with using OpenFOAM default solvers or do I need to write my own solver? Thank you very much. |
September 12, 2016, 11:18 |
Rep Power: 21 |
This is implemented inside the fvOptions. You can simply add that to your chtmultiregion calculation without modifying the solver.
September 12, 2016, 11:25 |
#3 | |
Aaron
Rep Power: 10 |
Hi,cfdsolver1
just use swak4foam to add source term, the source term expression like this Quote:
I also do a research in mixed convection using openfoam and fluent, I use openfoam for one year and new to fluent, maybe we can communicate with each other. best wishes, Aaron |
September 12, 2016, 11:53 |
#4 | ||
Rep Power: 13 |
Also, Vice versa here, I have 6 years experience in modeling mixed convection using Fluent and I am totally new in OpenFOAM. Any help is really appreciated. You can also find me whenever you need help in Fluent. |
September 12, 2016, 23:57 |
#5 | |||
Aaron
Rep Power: 10 |
hi,cfdsolver1, swak4foam can easily help you deal with nonuniform source term field, As far as I know, use fvOptions can only deal with it uniform field/region/patch.
firstly, you can define a source term field Q Quote:
September 13, 2016, 03:43 |
Anton Kidess
Rep Power: 30 |
Pretty sure this is false. The cellZones can be arbitrary.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
September 13, 2016, 03:56 |
cht solver
Rep Power: 11 |
Hi Dear foamers
Do you have any experience in implementing mixed derivative term ddt{d2dx2} in chtMultiRegionFoam solver? Regards, Jam |
September 13, 2016, 12:07 |
#8 | |
Rep Power: 13 |
Thank you for your comment akidess. I have no idea about swak4foam yet, so I think fvOptions might be more easier for me, I guess.
May 22, 2017, 01:18 |
Query
#9 |
jeanpinto24@hotmail.com
Rep Power: 9 |
Dear all, by adding a new source term to the energy equation, which in my case is the energy delivered by people in a classroom. I must suppose that by adding this term to the energy equation, I must regard it as a positive heat that is gained by the fluid. Now I have the question of how to create Q internalFiel and boundaryFiel
multiregion, source energy term |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 18:34 |
Energy Source Term for Sub-Region | Solmyr89 | Fluent UDF and Scheme Programming | 4 | January 16, 2016 05:31 |
Adding an energy source term to a phase with reactions | lxlxlxt | Fluent Multiphase | 0 | February 10, 2014 21:42 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 02:41 |
Source term energy equation for reactive flows | DaIN | Main CFD Forum | 0 | October 6, 2011 16:11 |
