August 31, 2016, 00:11 |
MRFSource no more available in OpenFOAM 4?
in the past, when launching simpleFoam simulations with MRF, I used to write in the fvOptions file : Code:
MRF1 { type MRFSource; active true; selectionMode cellZone; cellZone cylinder_inner; MRFSourceCoeffs { origin (0 0 0); axis (-1 0 0); omega 90; } } src/fvOptions/sources/derived/MRFSource/MRFSource.C but in OpenFOAM 4 is no more there. I would like to know what do you currently use to set an MRF source in OpenFOAM 4? |
August 31, 2016, 03:37 |
Anton Kidess
Rep Power: 30 |
Have a look at the tutorials. The relevant file is constant/MRFProperties.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
August 31, 2016, 04:39 |
Thank you very much Anton.
for future readers, I copy here an example from the tutorial: incompressible/simpleFoam/mixerVessel2D/constant/MRFProperties Origin, axis and omega of the MRF zone are now set in the constant/MRFProperties file: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: plus | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // MRF1 { cellZone rotor; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches (); origin (0 0 0); axis (0 0 1); omega 104.72; } // ************************************************************************* // |
July 26, 2017, 12:23 |
Jason G.
Rep Power: 17 |
I recently upgrade from OF 2.4, and now I am also having issues running a past model on OF 3.0. I am attempted to model a fluid region that has an impeller to increase the static pressure.
The model has two zones: c0 = impeller domain, c1 = everything else. The previous fvOptions file looked like: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "../0/initialConditions" MRF1 { type MRFSource; active true; selectionMode cellZone; cellZone c0; MRFSourceCoeffs { // Fixed patches (by default they 'move' with the MRF zone) active true; nonRotatingPatches ( inlet_1 outlet_1 boundary diffuser ); //patches need to be ones not rotating in actual frame origin (0 0 0); axis (0 0 1); // omega constant 638.7905062; omega table ( (0 0) (100 0) (200 $omega) (10000 $omega) ); } } // ************************************************************************* // Per the above, I attempted to run the following: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: dev | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object MRFProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "../0/initialConditions" MRF1 { // selectionMode cellZone; cellZone c0; active yes; // Fixed patches (by default they 'move' with the MRF zone) nonRotatingPatches ( inlet_1 outlet_1 boundary diffuser ); //patches need to be ones not rotating in actual frame origin (0 0 0); axis (0 0 1); // omega constant 638.7905062; omega table ( (0 0) (100 0) (200 $omega) (10000 $omega) ); } // ************************************************************************* // When I examine my two different log files, I notice the following: OF 3.0: Code:
Creating MRF zone list from MRFProperties creating MRF zone: MRF1 No finite volume options present Code:
Creating finite volume options from "system/fvOptions" Selecting finite volume options model type MRFSource Source: MRF1 - applying source for all time - selecting cells using cellZone c0 - selected 690499 cell(s) with volume 1.49875838 The model begins looking normal, but then suddenly crashes during the Omega ramping. I reviewed results just after the ramping, and the rotational velocity appears to correctly apply to only the impeller fluid domain. Just as the solution crashed, it appeared it was applying velocities to the entire domain. Any help is greatly appreciated! EDIT: Honing in on my results just as the solution crashes, I am able to see that a few elements where the pressure field goes unbounded (outside of the MRF zone). I assume this is likely an issue with internal solver controls slightly changing b/t the two OF versions, as I am utilizing the same mesh file for both runs. |
February 20, 2019, 21:31 |
Chenguang Zhang
Rep Power: 14 |
I am puzzled as to why the openfoam developers keep shoveling things around. To me this change adds no new functionality, only creates annoying compatibility issues that cost researchers precious time to fix.
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 12:58 |
OpenFOAM Foundation releases OpenFOAMŪ 3.0.0 | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 1 | November 7, 2015 16:16 |
OpenFOAM Foundation Releases OpenFOAM v2.3.0 | opencfd | OpenFOAM Announcements from OpenFOAM Foundation | 3 | December 23, 2014 04:43 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
