OpenFOAM 4.0 sample utility
Like Tree1Likes
  • 1 Post By Bazinga
Old   August 30, 2016, 11:36
Default OpenFOAM 4.0 sample utility
Bazinga is on a distinguished road
Dear Foamers,
I just tried to run a couple of simulations in OpenFOAM 4.0 and saw that there is a change (last version I used is 2.4) regarding the sample utility.
I understand that I can still read the system/sampleDict file with the command "postProcess -func sampleDict" when adding the lines "type sets;" and "libs ("libsampling.so");" to the sampleDict.
However, with this procedure I am not able to use the keyword "surfaces" to get for example the pressure at my structure. I need to create a new sampleDict file using "type surfaces" instead of "type sets" and then run the command again.
Anyone know a solution for this where I only have to run the utility once?
Inquisitor101 likes this.
Bazinga is offline   Reply With Quote
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 06:29
[OpenFOAM.org] Installing OpenFOAM 4.0 on OpenSuse 13.2 m_ridzon OpenFOAM Installation 11 July 24, 2016 11:31
'sample' utility for 'U' yields different results for simple-scotch-etc. HakikiCanakkaleli OpenFOAM Post-Processing 3 January 5, 2014 13:08
ParaView or Sample Utility ternik OpenFOAM 0 April 5, 2010 16:15
Understanding the coordinates of sample utility vishwa OpenFOAM Post-Processing 4 March 25, 2010 13:51
