HRR in fireFoam
Like Tree2Likes
  • 1 Post By nadezhda
  • 1 Post By Roman1
Old   August 25, 2016, 05:11
Default HRR in fireFoam
nadezhda is on a distinguished road
Hello!
I want to calculate HRR during FireFoam simulation.
I try this code in controlDict (found in tutorials):
functions
    HRR
        type            cellSource;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   outputTime;  //outputTime;
        outputInterval  1;
        log             false;
        valueOutput     false;
        source          all;       //cellZone;
        sourceName      c0;
        operation       volIntegrate;
        fields
            dQ
But it doesn't work. Then I run postProcess I get:
--> FOAM Warning :
    From function bool Foam::functionObjectList::read()
    in file db/functionObjects/functionObjectList/functionObjectList.C at line 644
    Caught FatalError
--> FOAM FATAL ERROR:
Unknown function type cellSource
What's wrong with it and how can I calc HRR?
Also I can't find where heat of combustion is specified in fireFoam. Please help me.
Hasnain_1 likes this.
nadezhda is offline   Reply With Quote
Old   September 1, 2016, 10:46
Roman
Roman1 is on a distinguished road
Hello. Next code works fine with my cases. It differs a little from yours. One thing, the result, i.e. HRR depends on the cell size. Try the same case with different cell size and you will see. At my mind this is not a great deal problem.
As for HRR, please find here the tutorial for reactingFoam solver. FireFoam works similar.
functions
volInts
type cellSource;
enabled true;
outputControl timeStep; //outputTime;
outputInterval 1;
log true; //true;
valueOutput false;
sourceName c0;
fields
dQ
Roman1 is offline   Reply With Quote
Old   September 2, 2016, 05:39
Thank you Roman1, I'll try your code!
Old   May 17, 2017, 05:52
Jean bon
FlyingCat is on a distinguished road
I am interested in having HRR because I realize that fireFoam is very dependent of mesh size.
With your code Roman, I have the same problem: Unknown function type cellSource
I am not sure you can use it. If someone has a solution.
Thanks.
FlyingCat is offline   Reply With Quote
Old   May 23, 2017, 11:45
Jean bon
To have the HRR function of time, you can add:
    HRR
        type            volRegion;
        enabled         true;
	writeControl    timeStep;
	writeInterval   1;
	writeFields     false;
	log             true;
	regionType      all;
        fields
            dQ
in your controlDict file.
Old   July 7, 2017, 10:34
Jean bon
With a sum is better:
    HRR
        type            volRegion;
        enabled         true;
	writeInterval   1;
	writeFields     false;
	log             true;
	regionType      all;
        operation       sum;
        fields
            dQ
Old   August 14, 2017, 09:10
Default fireFoam
luca1992 is on a distinguished road
Hello, i am looking for answers in a lot of places for a long time, can i ask you some things about fireFoam? I'm trying to simulate a fire in a closed place, but I have doubts.
Thank you, greetings, Luca.
luca1992 is offline   Reply With Quote
Old   August 14, 2017, 09:53
Roman
I could help if I can
Old   August 14, 2017, 12:09
Hi, thanks very much for the reply, I also asked for help in another forum discussion (both in "fireFOAM: reactions file setup" and in "HRR in fireFoam") and now I do not know what to do. I did not know if anyone answered me since July 30 I had created a post but no one answered me and so I was not very optimistic and so I had written on both posts that had the latest message in 2017, now I could write my question on both of the discussions, but maybe it would be better to unify them, do you know how to do it? Maybe it's better if I publicize my question in my previous post "Simulating fire in a tunnel" so if you can answer me there. Thank you both (Roman1 and ashish.vinayak) let me know if it is all right for you.
firefoam, heat of combustion, heat realise rate, hrr
fireFoam installation Roman1 OpenFOAM Installation 2 September 27, 2013 04:05
Install/compile fireFoam 1.6-1.0 in Openfoam 2.1.1 hz283 OpenFOAM Programming & Development 19 April 1, 2013 09:35
How to setup a proper "heatFlux" boundary for fireFoam? Jumping OpenFOAM Pre-Processing 0 March 27, 2013 10:27
pyrolysis in fireFoam windwin OpenFOAM 1 September 26, 2011 09:11
FireFoam what is HRR ? fgal OpenFOAM Post-Processing 1 April 16, 2010 11:37
