k-epsilon implementation? (including volScalarField G)
Like Tree11Likes
  • 3 Post By sheaker
  • 1 Post By dradenkovic
  • 1 Post By sheaker
  • 2 Post By dradenkovic
  • 1 Post By sheaker
  • 1 Post By mechkween
Old   August 21, 2016, 12:24
Default k-epsilon implementation? (including volScalarField G)
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Dear All.
I'm using: engineFoam (xiFoam), openfoam 2.2.1.
I'm trying to understand k-epsilon turbulence model in openFoam but I can't get through those k and epsilon equations.
Let's focus on k equation:
    tmp<fvScalarMatrix> kEqn
        fvm::ddt(rho_, k_)
      + fvm::div(phi_, k_)
      - fvm::laplacian(DkEff(), k_)
        G
      - fvm::SuSp((2.0/3.0)*rho_*divU, k_)
      - fvm::Sp(rho_*epsilon_/k_, k_)
I'm not sure if kEpsilon implements this equation but it looks similar:
\frac{\partial\rho k}{\partial t}+\frac{\partial}{\partial x_i}(\rho V_i k) = \frac{\partial}{\partial x_j}[(\mu+\frac{\mu_{turb}}{\sigma_k})\frac{\partial k}{\partial x_j}]+\mu_{turb} (\sqrt{2S_{ij}S_{ij}})^2-\rho\epsilon
If that's true, then:
fvm::ddt(rho_, k_) = \frac{\partial\rho k}{\partial t}
fvm::div(phi_, k_) = \frac{\partial}{\partial x_i}(\rho V_i k)
fvm::laplacian(DkEff(), k_) = \frac{\partial}{\partial x_j}[(\mu+\frac{\mu_{turb}}{\sigma_k})\frac{\partial k}{\partial x_j}]
fvm::Sp(rho_*epsilon_/k_, k_) = \rho\epsilon
Probably:
- fvm::SuSp((2.0/3.0)*rho_*divU, k_) = -\frac{2}{3}*\rho*k*\frac{\partial V_i}{\partial x_i}
and maybe this term is to remove trace but as long as I cant understand G, I can't go any further.
Definition of G is
 volScalarField G(GName(), mut_*(tgradU() && dev(twoSymm(tgradU()))));
and I don't know how to understand this.
I can't figure out how:
G - fvm::SuSp((2.0/3.0)*rho_*divU, k_) is equal to \mu_{turb} (\sqrt{2S_{ij}S_{ij}})^2
If someone can correct me or lead me to correct answer it would be great.
Greetings to all.
sheaker is offline   Reply With Quote
Old   August 23, 2016, 15:42
Darko Radenkovic
dradenkovic is on a distinguished road
Have a look here (page 123, at the top)
http://www.tfd.chalmers.se/~lada/pos...-modelling.pdf
About G: You need volScalarField to enter k equation.
Regards,
Darko
sheaker likes this.
dradenkovic is offline   Reply With Quote
Old   August 24, 2016, 16:17
sheaker's Avatar
Oskar
Hello. Thank You for this pdf but I can't find full solution (exact implementation formula).
According to my further research k-epsilon turbulent model is based on this report:
"k-epsilon equation for compressible reciprocating engine flows", Journal of Energy, Vol. 7, No. 4 (1983), pp. 345-353.
Unfortunately it is not free.
Old   August 25, 2016, 05:34
Darko Radenkovic
Hello.
Here is your paper.
https://www.dropbox.com/s/iwnvw5om0b...48086.pdf?dl=0
About your first post, in exact k equation (have look here)
https://en.wikipedia.org/wiki/Turbulence_kinetic_energy
find production term. Insert Bussinesk assumption
\overline{u_i^{\prime}u_j^{\prime}} = \frac{2}{3}\,k\delta_{ij} + ...
in that production term and you will get terms that you need. In the case of incompressible flow,
-\frac{2}{3}\,\rho\, k\,\frac{\partial V_i}{\partial x_i}
is equal to zero.
Best regards,
Darko
sheaker likes this.
Old   August 25, 2016, 14:21
sheaker's Avatar
Oskar
Thank You once again, dear Darko. That 2nd report is very useful for me (eg. C_3 constant).
I'm really sorry but it still isn't clear for me.
I have done what you said.
The production term:
P = -\rho \overline{u'_i u'_j}\frac{\partial \overline{u_i}}{\partial x_j}
After applying Boussinesq Eddy Viscosity:
P = - \frac{2}{3} \rho k \delta_{i,j}\frac{\partial \overline{u_i}}{\partial x_j}+\mu_{turb}(\frac{\partial \overline{u_i}}{\partial x_j}+\frac{\partial \overline{u_j}}{\partial x_i})
Removing delta Kronecker
P = - \frac{2}{3} \rho k \frac{\partial  \overline{u_i}}{\partial x_i}+\mu_{turb}(\frac{\partial  \overline{u_i}}{\partial x_j}+\frac{\partial \overline{u_j}}{\partial  x_i})
First term in openfoam:
- fvm::SuSp((2.0/3.0)*rho_*divU, k_) = - \frac{2}{3} \rho k \frac{\partial  \overline{u_i}}{\partial x_i}
But I still don't understand how
G = mut_*(tgradU() && dev(twoSymm(tgradU()))) = \mu_{turb}(\frac{\partial  \overline{u_i}}{\partial  x_j}+\frac{\partial \overline{u_j}}{\partial  x_i})
tgradU is temporary field of gradient U
tgradU = \frac{\partial \overline{u_i}}{\partial x_j}
twoSymm(tgradU) returns 2*symmetric part of a tensor so:
twoSymm(tgradU) = 2* \frac{1}{2}(tgradU+tgradU^T) =
\frac{\partial  \overline{u_i}}{\partial  x_j}+\frac{\partial \overline{u_j}}{\partial  x_i} (Am I right here? Im pretty sure but...)
dev(twoSymm(tgradU())) - this one returns only deviatoric component of tensor tgradU
dev(twoSymm(tgradU())) = \frac{\partial  \overline{u_i}}{\partial  x_j}+\frac{\partial \overline{u_j}}{\partial  x_i} - \frac{1}{3}(\frac{\partial  \overline{u_k}}{\partial  x_k}+\frac{\partial \overline{u_k}}{\partial  x_k})\delta_{i,j} \mathbb{I}
dev(twoSymm(tgradU())) = \frac{\partial   \overline{u_i}}{\partial  x_j}+\frac{\partial \overline{u_j}}{\partial   x_i} - \frac{2}{3}\frac{\partial \overline{u_k}}{\partial  x_k}\delta_{i,j}  \mathbb{I} Is that right?
And at last:
tgradU() && dev(twoSymm(tgradU())) means "double inner product" and it hard to understand.
Definition of double inner product for two 2nd rank tensors:
A:B = A_{i,j}B_{k,l}\delta_{j,k} \delta_{i,l} = A_{i,j}B_{j,i}
tgradU() && dev(twoSymm(tgradU())) = [\frac{\partial \overline{u_i}}{\partial x_j}] : [\frac{\partial    \overline{u_l}}{\partial  x_k}+\frac{\partial \overline{u_k}}{\partial    x_l} - \frac{2}{3}\frac{\partial \overline{u_m}}{\partial   x_m}\delta_{k,l}  \mathbb{I}]
And I have no idea what to do now.
randolph likes this.
Old   August 26, 2016, 09:12
Darko Radenkovic
Book at this link has very good introduction part about tensors
https://www.dropbox.com/s/72rz5760b3...ou%29.pdf?dl=0
Sooner or later, you will have to learn it, so it is better to start now.
Pay attention to eq. 1.76, it will make things easier for you many times.
If we use (1.148) from above book, it follows:
\mu_t\,{\left({\mathbf{D} + \mathbf{\Omega}}\right)}:\left[2\mathbf{D} - \frac{2}{3}(tr \mathbf{D})\mathbf{I})\right] = \mu_t\left(2\mathbf{D}:\mathbf{D} - \frac{2}{3} (tr{\mathbf{D})^2}\right]
Last term is equal to zero when flow is incompressible. It has been utilized that product of symmetric and asymmetric tensor is zero.
Regards,
Darko
randolph and sheaker like this.
Old   August 26, 2016, 18:26
sheaker's Avatar
Oskar
Dear Darko. Thank You for a lot of patience to me.
I forgot about splitting gradU into symmetric and antisymmetric parts. I understand that:
(tgradU() && dev(twoSymm(tgradU())) ={\left({\mathbf{D} + \mathbf{\Omega}}\right)}:\left[2\mathbf{D} - \frac{2}{3}(tr \mathbf{D})\mathbf{I}\right] = \left[2\mathbf{D}:\mathbf{D} - \frac{2}{3} (tr{\mathbf{D})^2}\right]
According to previous hints:
\left[{2\mathbf{D}:\mathbf{D} - \frac{2}{3} \left({tr{\mathbf{D}}}\right)^2}\right] should be equal to \left(\frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i}\right)\frac{\partial u_i}{\partial x_j}
And I'm not sure about that.
The first one is a scalar and it looks correct but I can't transform it to that second form.
Darko, wish You best!
Old   August 27, 2016, 06:25
Darko Radenkovic
I wasn't clear enough.
\mathbf{D} is rate of strain tensor and from the above mentioned link from Chalmers, page 123, you can see that
{2\mathbf{D}}:\mathbf{D} =2 D_{ij}D_{ij} =
Term - \frac{2}{3} \left(tr{\mathbf{D}}\right)^2 is not in your starting equation.
When I think better from the very beginning we used assumption of incompressible flow through Bussinesq assumption - in the case of compressible flow, Bussinesq assumption is
\mathbf{T} = 2\mu_t\left(\mathbf{D} - \frac{1}{3}(tr{\mathbf{D}}) \mathbf{I}\right) - \frac{2}{3} \rho k \mathbf{I}
If you again insert Bussinesq assumption into production term of TKE, this forgotten term explains existence of - \frac{2}{3} \left(tr{\mathbf{D}}\right)^2 in Openfoam implementation of k-epsilon.
This agrees well with k equation of
http://turbmodels.larc.nasa.gov/ke-chien.html
Of course, in incompressible flow trace of rate of strain tensor is zero.
Regards,
Darko
Old   August 27, 2016, 10:07
sheaker's Avatar
Oskar
Thank You for Your help. I think I get it now. So the therm - \frac{2}{3} \left(tr{\mathbf{D}}\right)^2 = - \frac{2}{3} \left(\frac{\partial u_i}{\partial x_i}\right)^2 SHOULD exist in my TKE equation?
\frac{\partial\rho k}{\partial t}+\frac{\partial}{\partial x_i}(\rho u_i k) = \frac{\partial}{\partial x_j}\left[ \left( \mu+\frac{\mu_{turb}}{\sigma_k} \right) \frac{\partial k}{\partial x_j} \right]+\mu_{turb} \left[ \left( \frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i} \right) \frac{\partial u_i}{\partial x_j} - \frac{2}{3} \left(\frac{\partial u_i}{\partial x_i}\right)^2 \right] - \frac{2}{3}\rho k\frac{\partial u_i}{\partial x_i}-\rho\epsilon
And G(openFoam) =
Production P = \mu_{turb} \left[ \left(  \frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i}  \right) \frac{\partial u_i}{\partial x_j} - \frac{2}{3}  \left(\frac{\partial u_i}{\partial x_i}\right)^2 \right] -  \frac{2}{3}\rho k\frac{\partial u_i}{\partial x_i}
I think that is correct now.
Kindest regards,
Oskar
Old   August 27, 2016, 12:46
Darko Radenkovic
Couple hours ago I verified this on link in my above post (but now, at the moment of this writing, above link doesn't work).
If you check eq. (24) and eq. (37) from paper "k-e Equation for Compressible Reciprocating Engine Flows", 1983, I believe you will see that is it.
Regards,
Darko
sheaker likes this.
Old   May 22, 2018, 10:51
Sami
Mehrez is on a distinguished road
Hello all,
Thank you for this very useful discussion.
I'm using multiphaseEulerFoam (OFv4) to perform simulation of two-phase (gas dispersed in liquid) dispersed flow. To model turbulence, I used the k-epsilon model.
The code has a little bit changed in version 4 (https://github.com/OpenFOAM/OpenFOAM...lon/kEpsilon.C) compared to what you shared in last posts.
In OFv4, we have source terms "kSource()" and "epsilonSource()". My understanding is that they are used for bubble induced turbulence in the case of two-phase dispersed flow.
Do you know how they are implemented and what is their exact definition?
Thank you.
mhrz
Mehrez is offline   Reply With Quote
Old   March 22, 2019, 08:02
Jianrui Zeng
calf.Z is on a distinguished road
I am also interested in kSource()and epsilonSource(). What is its function and meaning?
calf.Z is offline   Reply With Quote
Old   July 1, 2019, 19:29
Joachim Herb
jherb is on a distinguished road
They are used to modify the turbulence model, e.g. for buoyancy effects. See https://github.com/OpenFOAM/OpenFOAM...uoyantKEpsilon
This turbulence model inherits from the basic compressible k-epsilon turbulence model and overwrites those methods to implement the effect of buoyancy on turbulence.
jherb is offline   Reply With Quote
Old   May 20, 2021, 10:51
Sourav Hossain
sourav8016 is on a distinguished road
Originally Posted by dradenkovic View Post
Hello.
Here is your paper.
is equal to zero.
Best regards,
Darko
Dear Sir, could you please upload the paper again? The link is showing that the paper is deleted.
sourav8016 is offline   Reply With Quote
Old   May 20, 2021, 11:03
Sourav Hossain
And G(openFoam) =
Kindest regards,
Oskar
Dear sir, Could you please share the paper and the book shared by Darko Radenkovi? The link is broken.
Old   April 6, 2022, 06:54
kooki_13 is on a distinguished road
Dear Sheaker
Do you have any Idea about G?
Here we have
fvm::ddt(alpha, rho, k_)
+ fvm::div(alphaRhoPhi, k_)
- fvm::laplacian(alpha*rho*DkEff(), k_)
alpha*rho*G
- fvm::SuSp((2.0/3.0)*alpha*rho*divU, k_)
- fvm::Sp(Ce(D, KK)*alpha*rho*sqrt(k_)/this->delta(), k_)
+ kSource()
+ fvModels.source(alpha, rho, k_)
I have understood the term - fvm::SuSp((2.0/3.0)*alpha*rho*divU, k_)
but still this one is unclear:
alpha*rho*G
kooki_13 is offline   Reply With Quote
Old   April 6, 2022, 06:56
And G(openFoam) =
Kindest regards,
Oskar
Dear Sheaker
Here we have
alpha*rho*G
+ kSource()
alpha*rho*G
Old   May 31, 2022, 11:27
mechkween is on a distinguished road
G refers to the production of the TKE. This is written out as:
nut*(tgradU() && dev(twoSymm(tgradU())))
which is essentially a double inner over gradU(j,i) and 2*S(i,j) - 2/3 S(k,k) \delta(i,j). The first term is the velocity gradient and the second term represents the model for the Reynolds stress less the nut, which is pre-multiplied.
reverseila likes this.
mechkween is offline   Reply With Quote
Old   June 6, 2023, 20:41
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
Dear Sourav Hossain
The book is "Papanastasiou, T., Georgiou, G., & Alexandrou, A. N. (2021). Viscous fluid flow. CRC press."
alainislas is offline   Reply With Quote
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Creating a new field from terms of the turbulence model HaZe OpenFOAM Programming & Development 15 November 24, 2014 14:51
writing execFlowFunctionObjects immortality OpenFOAM Post-Processing 30 September 15, 2013 07:16
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
