Fynn
Rep Power: 10 ![]() |
Hi together,
I was wondering why it is sometimes necessary to have the polyMesh folder in the /0 folder. It just seems to be a copy of the /constant/polyMesh folder. Anybody found an explanation on this? cheers, Fynn |
Rep Power: 20 ![]() |
This is necessary, if you are working with mesh motion. This can change the position of your points. Some might even be deleted. Hence the mesh is not saved in the constant folder, but ends up in your time directories. Other examples are snappyHexMesh, extrudeMesh, mirrorMesh, splitMeshRegions etc. Those also modify your mesh by removing or adding cells. Hence your current mesh is not touched but a new version saved into your time steps.
mesging, polymesh |
Writing IOdictionary to user-defined folder | Arnoldinho | OpenFOAM Programming & Development | 3 | June 16, 2021 04:04 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
[OpenFOAM.org] one folder for external utilities | student666 | OpenFOAM Installation | 1 | May 24, 2015 09:40 |
I want to arrange all source file into Single Folder :Debate Urgent Help | hhh | OpenFOAM | 3 | July 27, 2013 05:15 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
