Plot residuals over Iterations instead of time steps |
July 29, 2016, 03:56 |
Charles K.
Rep Power: 10 |
Hello everyone,
I would like to plot the residuals over the Pimple Iterations instead of every completed time step in order to see the PIMPLE-Loops. Usually i use pyFoamPlotWatcher.py to plot the residuals. Is there a special extension to use with pyFoamPlotWatcher or do i have to change any setting? Cheers, Charles |
July 29, 2016, 04:46 |
Have you gone through this
eu sou cfd
Rep Power: 14 |
Hey McCharles, I am not sure if pyFoamPlots have that option while running a transient case.
http://www.cfd-online.com/Forums/ope...residuals.html But if you haven't gone through the above link I suggest going through it thougroughly. Of course it isnt as straight forward as the pyFoamPlots but this gets the job done and you have a much better control on the graphs I think Last edited by vikramaditya91; July 29, 2016 at 05:34. Reason: incomplete |
July 29, 2016, 08:10 |
#3 | |
Bruno
Rep Power: 10 |
Greetings, Bruno |
July 29, 2016, 08:35 |
Convergence plot
eu sou cfd
Rep Power: 14 |
Hey Bruno, the post I referred to actually makes that distinction. But anyway, here is the code
set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' plot "< cat log_parallel.txt | grep 'Solving for Urelx' | cut -d' ' -f9 | tr -d ','" title 'Urelx' with lines,\ "< cat log_parallel.txt | grep 'Solving for Urely' | cut -d' ' -f9 | tr -d ','" title 'Urely' with lines,\ "< cat log_parallel.txt | grep 'Solving for Urelz' | cut -d' ' -f9 | tr -d ','" title 'Urelz' with lines,\ "< cat log_parallel.txt | grep 'Solving for p' | cut -d' ' -f9 | sed -n '0~6p'| tr -d ','" title 'p' with lines pause 1 reread |
July 29, 2016, 08:46 |
Charles K.
Rep Power: 10 |
Wow, thank you very much for your reply Vik !
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 09:07 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
