Distribution of root mean square of velocity fluctuation in channel
Like Tree5Likes
  • 5 Post By vkrastev
Old   July 18, 2016, 14:54
Default Distribution of root mean square of velocity fluctuation in channel
Darko Radenkovic
dradenkovic is on a distinguished road
Hello.
I want to show root mean square of velocity fluctuation in cross section of a channel. I have been searching this forum a while in order to solve this problem but without success.
I know that I should obtain distribution similar to this
Any tip?
Regards,
Darko
dradenkovic is offline   Reply With Quote
Old   July 19, 2016, 04:56
Vesselin Krastev
vkrastev is on a distinguished road
Hi Darko,
in OpenFOAM you can calculate the rms of a velocity component (velocity along x, y or z axis) trhrough the Prime2Mean statistical function. You have to include a fieldAverage function in your controlDict, then run the simulation until the Mean and Prime2Mean quantities get sufficiently stable, then from the UPrime2Mean field you can extract the rms quantities like follows:
urms,x=sqrt(UPrime2Meanxx)
and the same for y and z. Here it is an example of fieldAverage function applied to the velocity field (this works for OpenFOAM-3.0.x, but should be ok for other versions too):
functions
fieldAverage
        type            fieldAverage;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   outputTime;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
Note that the Mean and Prime2Mean fields are time-based statistical quantities, so at the end of the run you may want to add a space average operation to your Prime2Mean fields (e. g. tangential average in a cylindrical domain).
Regards
V.
vkrastev is offline   Reply With Quote
Old   July 19, 2016, 06:17
Darko Radenkovic
Thank you!
Regards,
Darko
Code for EARSM by Hellsten and RSM by Manceau, square duct, 2d turbulent channel Thomas Baumann OpenFOAM Running, Solving & CFD 14 October 16, 2020 05:11
Open channel flow boundary give different velocity values? mariam.sara Fluent Multiphase 1 April 9, 2015 11:11
Velocity distribution function sampling issue in DSMC flotus1 Main CFD Forum 6 December 13, 2014 07:18
Velocity fluctuation. In let. Main CFD Forum 1 October 21, 2003 15:37
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
