Foam::error::printStack(Foam::Ostream&) at ??:? |
July 11, 2016, 14:24 |
a_b
Rep Power: 10 |
Hi all!
I'm a Foamer beginner and I hope you can help me. I have been trying to solve a heat transfer case with chtMultiRegionSimpleFoam and kOmegaSST turbulence model but it doesn't work. The error message is : /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 3.0.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 3.0.1-d8a290b55d28 Exec : chtMultiRegionSimpleFoam Date : Jul 11 2016 Time : 18:14:06 Host : "debvbox" PID : 3085 Case : /home/pepito/OpenFOAM/pepito-3.0.1/run/scambiatore002 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region aria for time = 0 Create fluid mesh for region co2 for time = 0 Create solid mesh for region alluminio for time = 0 *** Reading fluid mesh thermophysical properties for region aria Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST Selecting patchDistMethod meshWave #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<F oam::ThermalDiffusivity<Foam::CompressibleTurbulen ceModel<Foam::fluidThermo> > > >::F2() const at ??:? #6 Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<F oam::ThermalDiffusivity<Foam::CompressibleTurbulen ceModel<Foam::fluidThermo> > > >::F23() const at ??:? #7 Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<F oam::ThermalDiffusivity<Foam::CompressibleTurbulen ceModel<Foam::fluidThermo> > > >::correctNut(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #8 Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<F oam::ThermalDiffusivity<Foam::CompressibleTurbulen ceModel<Foam::fluidThermo> > > >::correctNut() at ??:? #9 Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<F oam::ThermalDiffusivity<Foam::CompressibleTurbulen ceModel<Foam::fluidThermo> > > >::kOmegaSST(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:? #10 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::adddictionaryConstructorToTable<Foam::RASModels ::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDif fusivity<Foam::CompressibleTurbulenceModel<Foam::f luidThermo> > > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #11 Foam::RASModel<Foam::EddyDiffusivity<Foam::Thermal Diffusivity<Foam::CompressibleTurbulenceModel<Foam ::fluidThermo> > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #12 Foam::TurbulenceModel<Foam::geometricOneField, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>, Foam::compressibleTurbulenceModel, Foam::fluidThermo>::adddictionaryConstructorToTabl e<Foam::RASModel<Foam::EddyDiffusivity<Foam::Therm alDiffusivity<Foam::CompressibleTurbulenceModel<Fo am::fluidThermo> > > > >::NewTurbulenceModel(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:? #13 ? at ??:? #14 ? at ??:? #15 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #16 ? at ??:? Floating point exception I don't understand where the error is. Can you say me how I can solve this problem? Thank you for your help! |
July 12, 2016, 02:53 |
To trace the origin of the error, you need to look at line #3 and line #5. #3 Code:
Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #5 Code:
Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<F oam::ThermalDiffusivity<Foam::CompressibleTurbulen ceModel<Foam::fluidThermo> > > >::F2() const at ??:? F2 function could be found at https://github.com/OpenFOAM/OpenFOAM...OmegaSST.C#L68 Code:
template<class BasicTurbulenceModel> tmp<volScalarField> kOmegaSST<BasicTurbulenceModel>::kOmegaSST::F2() const { tmp<volScalarField> arg2 = min ( max ( (scalar(2)/betaStar_)*sqrt(k_)/(omega_*y_), scalar(500)*(this->mu()/this->rho_)/(sqr(y_)*omega_) ), scalar(100) ); return tanh(sqr(arg2)); } |
July 12, 2016, 06:17 |
#3 | |
a_b
Rep Power: 10 |
Now I have understood what the message means. Unfortunately I don't know the way to compile OpenFOAM in debug mode because I'm still learning to use OF but I will be grateful if you help me. I have already looked for some numerical error in omega files but i haven't found anything. I can upload the casefolder.zip if you prefer. I'm sorry for the trouble and thank you again and again! |
July 12, 2016, 10:22 |
#4 | |
Upload your case, otherwise it become rather "guess what is wrong" game.
July 12, 2016, 12:43 |
#5 | |
a_b
Rep Power: 10 |
https://www.dropbox.com/s/h2iqrnit2q...er.tar.gz?dl=0 |
July 13, 2016, 08:34 |
Unfortunately I do not have 3.0.1 installed and with 3.0.x I can not reproduce your error. After corrections to boundary conditions (since Feb. 24 value field is required for calculated BC, co2/k/contact_region_3-trg type should be kqRWallFunction not kqrWallFunction, co2/alphat/contact_region_3-trg type should be compressible::alphatJayatillekeWallFunction) I get the following output:
... Build : 3.0.x-1c517d6c8485 Exec : chtMultiRegionSimpleFoam ... Time = 1 Solving for fluid region aria DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.00979818, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.006705962, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.0005758433, No Iterations 1 --> FOAM FATAL ERROR: Supply either a patchName or a coupleGroup for patch contact_region-src in region aria |
July 13, 2016, 11:10 |
#7 | |
a_b
Rep Power: 10 |
July 13, 2016, 13:27 |
a_b
Rep Power: 10 |
ok, I think I've just found the solution to my problem...
thanks for your precious help Alexey!!! |
July 30, 2017, 08:39 |
#9 | |
Alice
Rep Power: 9 |
Courant Number mean: 3.40147e-05 max: 0.502766 Interface Courant Number mean: 1.48331e-05 max: 0.0517021 deltaT = 4.061e-68 Time = 4.71186 PIMPLE: iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 2.03688e-06, Final residual = 2.93968e-11, No Iterations 1 Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 2.03667e-06, Final residual = 2.93849e-11, No Iterations 1 Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 2.03639e-06, Final residual = 2.93744e-11, No Iterations 1 Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.956421 Min(alpha.water) = -2.21102e-28 Max(alpha.water) = 1 smoothSolver: Solving for alpha.water, Initial residual = 2.03613e-06, Final residual = 2.93615e-11, No Iterations 1 Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water Phase-1 volume fraction = 0.956421 Min(alpha.water) = 0 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 0.00709543, Final residual = 0.000345669, No Iterations 8 time step continuity errors : sum local = 5.43246e-10, global = 1.84738e-10, cumulative = 2.56315e-06 DICPCG: Solving for p_rgh, Initial residual = 0.00538723, Final residual = 6.52414e-08, No Iterations 224 time step continuity errors : sum local = 1.02756e-13, global = -6.67559e-16, cumulative = 2.56315e-06 [3] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libOpenFOAM.so" [3] #2 ? in "/lib64/libc.so.6" [3] #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libOpenFOAM.so" [3] #4 double Foam::gSumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&, int) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libOpenFOAM.so" [3] #5 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libOpenFOAM.so" [3] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libfiniteVolume.so" [3] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/bin/interFoam" [3] #8 Foam::fvMatrix<double>::solve() in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/bin/interFoam" [3] #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libincompressibleTurbulenceModels.so" [3] #10 Foam::RASModels::realizableKE<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/lib/libincompressibleTurbulenceModels.so" [3] #11 ? in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/bin/interFoam" [3] #12 __libc_start_main in "/lib64/libc.so.6" [3] #13 ? in "/opt/software/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64GccDPInt32Prof/bin/interFoam" |
November 9, 2018, 12:28 |
#10 | |
Alejandro Valeije
Rep Power: 12 |
I know it's been a long time since this happened, but do you remember how did you solve this problem? I'm having the same issue and I haven't found any solution yet. Regards, Alex |
November 12, 2022, 00:09 |
Hi Thread
#11 |
Ding Yan
Rep Power: 4 |
November 12, 2022, 00:10 |
Hi
#12 |
Ding Yan
Rep Power: 4 |
May 12, 2023, 03:31 |
#13 | |
Rep Power: 3 |
My solver compilation is OK, but I met similar errors and the computation was crushed finally. The problem was solved when I fixed UEqn where the pressure term shall be a minus term. So, maybe you shall check your equations carefully. May your computation converge! Ary |
chtmultiregionsimplefoam, error, komegasst model |
