June 16, 2016, 11:13 |
k-omega SST simpleFoam asks for nut
Kevin Cole
Rep Power: 10 |
I'm trying to run simulations using the k-omega SST model. When I execute simpleFoam, I receive the following error: Code:
FOAM FATAL IO ERROR: cannot find file file: /home/kodexys/OpenFOAM/kodexys-3.0.1/TEST/NACA0015/0degAoA/0/nut at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73 FOAM exiting I could make my own nut file, but I want to know what is going on. Any insight would be greatly appreciated! |
October 17, 2017, 07:05 |
james
Please could you inform as to whether you ever managed to resolve this issue
October 17, 2017, 09:17 |
Gerhard Holzinger
Rep Power: 28 |
In OpenFOAM-5.0 all turbulence models derived from Foam::eddyViscosity read the field nut. Even if nut can be calculated from other turbulent quantities, you need a nut field to select boundary conditions (i.e. wall functions). One could devise another mechanism to select BCs for nut, however, having the nut field is quite elegant.
k-omega sst model, nut, simplefoam |
overshooting of Omega in SST komega using simpleFoam | cm_jubayer | OpenFOAM | 2 | June 7, 2020 12:52 |
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? | JuPa | CFX | 0 | December 22, 2015 06:44 |
how to calculate the omega at inlet boundary in k omega sst | Scabbard | OpenFOAM Running, Solving & CFD | 2 | September 30, 2014 13:06 |
simplefoam omega convergence problem | simplefoam | OpenFOAM Running, Solving & CFD | 4 | August 13, 2013 05:31 |
Boundary Conditions for k omega SST | dancfd | OpenFOAM Pre-Processing | 0 | June 9, 2011 23:25 |
