Boundary conditions - same velocity boundary field in the inlet and outlet |
June 13, 2016, 13:02 |
Thomas Oliveira
Rep Power: 12 |
Dear all,
I would like to impose the following boundary conditions for the incompressible flow in a channel. The pressures are known at the inlet and at the outlet. The velocity boundary field in the inlet is equal to the velocity boundary field at the outlet. They can be non-uniform. For the pressure I am using ./0/p: inlet { type fixedValue; value uniform 1; } outlet { type fixedValue; value uniform 0; } For the velocity, I can't find the appropriate boundary condition. Could you please advise me on that? Best wishes, Thomas |
June 13, 2016, 17:04 |
Joachim Herb
Rep Power: 22 |
If you specify velocities (fixedValue) at both inlet and outlet as well as pressure on both, you will (very likely) run into numerical instabilities.
Normal advice is to use fixedValue for pressure at the outlet and zeroGradient at the inlet. For the velocity it is the other way around: fixedValue at inlet and zeroGradient (or inletOutlet) at the outlet. |
June 13, 2016, 17:08 |
Thomas Oliveira
Rep Power: 12 |
Dear jherb,
I don't want to specify fixedValue for velocities, but to impose that the velocity boundary field in the inlet be equal to the velocity boundary field at the outlet. Best wishes, Thomas |
June 13, 2016, 17:40 |
Joachim Herb
Rep Power: 22 |
Do you mean cyclic boundary conditions?
June 13, 2016, 18:07 |
Thomas Oliveira
Rep Power: 12 |
Yes, but just for the field U, not for every field.
June 13, 2016, 18:20 |
Joachim Herb
Rep Power: 22 |
boundary condition |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
