What is the meaning of pd in foam-extended 3.1 |
June 10, 2016, 15:02 |
Lee
Rep Power: 10 |
Hi all,
I am now running a tutorial case dambreak using the interfoam solver. The meaning of pd really confuses me as I firstly expect it to be dynamic pressure (1/2*rho*U^2) until I got negative values of pd. Could someone please explain to me what the physical meaning of pd is in dambreak case? Also, when I checked the file interfoam.C under the interfoam solver directory, I found this equation "p=pd+rho*gh". Here, is p the total pressure, if pd is the dynamic pressure, or the static pressure? Any help is greatly appreciated. Best, Lee |
June 15, 2016, 20:29 |
Lee
Rep Power: 10 |
No one knows the meaning of p and pd ?
Any suggestion is welcome! |
February 3, 2017, 12:54 |
rik houthuys
Rep Power: 9 |
Hi Lee,
Did you find answer to this question? In OpenFOAM p_rgh=p-rho*gh is coined as dynamic pressure which seems to be the same as pd in foam-extended. So, I am curious to know does it really mean 0.5*rho*U^2? If yes, this will bring many questions: 1- p=dynamic pressure (p_rgh) + hydrostatic pressure(rho*gh). So where is the static pressure? 2- if p_rgh=0.5*rho*U^2 why we need to consider it as additional unknown? why not writing it as function of velocity? I believe p_rgh is the static pressure (or static + dynamic at stagnation point) but I'm not sure. any help is appreciated. Edit: I've found the answer (I hope this time is the correct one) p_rgh or pd is simply the static pressure (p) - hydrostatic pressure (rho*gh). It has nothing to do with dynamic pressure (0.5*rho*U^2) If you want the static pressure use: p=pd+rho*gh if you are interested in the dynamic pressure reconstruct it from the velocity field For more information: rasInterFoam appears to give erroneous results for “pd”. Last edited by Houthuys; February 3, 2017 at 21:19. |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
