June 10, 2016, 05:34 |
pimpleFoam crashing with GAMG
Max Vorstadt
Rep Power: 10 |
Hi! I'm trying to solve a SA-DDES case but apparently the GAMG pressure solver is causing it to break... The velocities are computed giving low initial residuals but pressure makes it to crash. Here is the output from the log file:
Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 PIMPLE: Operating solver in PISO mode Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type LES Selecting LES turbulence model SpalartAllmarasDDES Selecting LES delta type maxDeltaxyz Selecting patchDistMethod meshWave SpalartAllmarasDDESCoeffs { alphaNut 1.5; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; CDES 0.75; ck 0.07; Ce 1.048; sigmaNut 0.66666; kappa 0.41; Cs 0.3; lowReCorrection true; Ct3 1.2; Ct4 0.5; fwStar 0.424; Cd1 8; Cd2 3; } No MRF models present No finite volume options present Starting time loop Reading surface description: xNormal yNormal zNormal Reading surface description: xNormal yNormal zNormal forceCoeffs forceCoeffs1: Not including porosity effects fieldAverage meanValues: Restarting averaging for fields: DESModelRegions: starting averaging at time 0 U: starting averaging at time 0 p: starting averaging at time 0 k: starting averaging at time 0 omega: starting averaging at time 0 nuTilda: starting averaging at time 0 Courant Number mean: 1.46754e-06 max: 0.00472643 deltaT = 1.2e-09 Time = 1.2e-09 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 1.32657e-08, Final residual = 1.32657e-08, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 8.1728e-08, Final residual = 8.1728e-08, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 6.64292e-08, Final residual = 6.64292e-08, No Iterations 0 [2] #0 Foam::error::printStack(Foam::Ostream&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigHandler(int) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [2] #2 ? in "/lib64/libc.so.6" [2] #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [2] #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [2] #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [2] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libfiniteVolume.so" [2] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/bin/pimpleFoam" [2] #8 ? in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/bin/pimpleFoam" [2] #9 __libc_start_main in "/lib64/libc.so.6" [2] #10 ? in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/bin/pimpleFoam" Code:
solvers { p { solver GAMG; tolerance 1e-6; relTol 1e-2; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 50; agglomerator faceAreaPair; mergeLevels 1; }; pFinal { $p; relTol 1e-2; }; "(U|k|B|nuTilda)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-7; relTol 1e-2; }; UFinal { $U; }; } PIMPLE { nCorrectors 3; nNonOrthogonalCorrectors 1; } relaxationFactors { "U.*" 1; "nuTilda.*" 1; } |
June 10, 2016, 05:45 |
Pedro
Rep Power: 12 |
to be sure, have you tried with another solver?
for example: Code:
p { solver PCG; preconditioner DIC; tolerance 1e-8; relTol 0.01; } |
June 11, 2016, 09:01 |
#3 | |
Max Vorstadt
Rep Power: 10 |
Courant Number mean: 0.000146768 max: 0.472643 deltaT = 4.23153e-08 Time = 4.23153e-08 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 3.9629e-07, Final residual = 3.9629e-07, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 2.74837e-06, Final residual = 2.74837e-06, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 2.31382e-06, Final residual = 2.31382e-06, No Iterations 0 DICPCG: Solving for p, Initial residual = 0.999302, Final residual = 0.0648168, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.0489989, Final residual = 0.0136731, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.0161421, Final residual = 0.000959671, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.00310824, Final residual = 7.1897e-05, No Iterations 1001 time step continuity errors : sum local = 2.98043e-11, global = -3.96895e-12, cumulative = -3.96895e-12 DICPCG: Solving for p, Initial residual = 0.00132401, Final residual = 9.58867e-05, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.00147142, Final residual = 8.5905e-06, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.00282163, Final residual = 9.60736e-06, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.00550311, Final residual = 7.14701e-06, No Iterations 1001 time step continuity errors : sum local = 3.11322e-12, global = -7.67741e-13, cumulative = -4.73669e-12 DICPCG: Solving for p, Initial residual = 0.0116716, Final residual = 3.52184e-05, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.0265098, Final residual = 6.91188e-05, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.0516905, Final residual = 0.000184776, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.0942045, Final residual = 0.000834361, No Iterations 307 time step continuity errors : sum local = 4.69897e-10, global = -2.36321e-11, cumulative = -2.83688e-11 [1] #0 Foam::error::printStack(Foam::Ostream&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [1] #2 ? in "/lib64/libc.so.6" [1] #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [1] #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [1] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libOpenFOAM.so" [1] #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libfiniteVolume.so" [1] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/bin/pimpleFoam" [1] #8 Foam::fvMatrix<double>::solve() in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libincompressibleTurbulenceModels.so" [1] #9 Foam::SolverPerformance<double> Foam::solve<double>(Foam::tmp<Foam::fvMatrix<double> > const&) in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libincompressibleTurbulenceModels.so" [1] #10 Foam::LESModels::SpalartAllmarasDES<Foam::IncompressibleTurbulenceModel<Foam::transportModel> >::correct() in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/lib/libincompressibleTurbulenceModels.so" [1] #11 ? in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/bin/pimpleFoam" [1] #12 __libc_start_main in "/lib64/libc.so.6" [1] #13 ? in "/group/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc49DPInt32Opt/bin/pimpleFoam" Anyone knows what can be causing the problem? |
June 11, 2016, 10:45 |
Vinícius da Costa Ávila
Rep Power: 11 |
Hi, post your checkMesh -allTopology -allGeometry results, please. If your mesh is big, try increase nCellsincoarsestlevel on GAMG to 500 or 1000
Vinícius dC.A. |
June 11, 2016, 11:10 |
#5 | |
Max Vorstadt
Rep Power: 10 |
Enabling all geometry checks. Time = 0 Mesh stats points: 26716253 faces: 73469248 internal faces: 70259631 cells: 23392159 faces per cell: 6.14432 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 21925085 prisms: 164543 wedges: 0 pyramids: 0 tet wedges: 769 tetrahedra: 0 polyhedra: 1301762 Breakdown of polyhedra by number of faces: faces number of cells 4 2466 5 2193 6 163374 7 141807 8 6875 9 857584 10 314 11 136 12 108408 14 87 15 18158 18 360 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Topological cell zip-up check OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology Bounding box inlet 22488 24182 ok (non-closed singly connected) (-0.225 -0.35 -0.125) (-0.225 0.35 0.84) outlet 11398 12527 ok (non-closed singly connected) (1.12 -0.35 -0.125) (1.12 0.35 0.84) lateralWall 255501 280238 ok (non-closed singly connected) (-0.225 -0.35 -0.125) (1.12 0.35 0.84) upperWall 288 325 ok (non-closed singly connected) (-0.225 -0.35 0.84) (1.12 0.35 0.84) lowerWall 1152 1225 ok (non-closed singly connected) (-0.225 -0.35 -0.125) (1.12 0.35 -0.125) Cylinder 280699 285958 ok (non-closed singly connected) (-0.0601417 -0.0599639 -3.35276e-10) (0.0600005 0.0599639 0.24) Plate_round 2638091 2665903 ok (non-closed singly connected) (-0.223998 -0.35 -0.015) (1.12 0.35 0.000998369) Checking geometry... Overall domain bounding box (-0.225 -0.35 -0.125) (1.12 0.35 0.84) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-5.87433e-16 6.97082e-17 -1.48306e-13) OK. ***High aspect ratio cells found, Max aspect ratio: 1.24904e+94, number of cells 35 <<Writing 35 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 5.21919e-10. Maximum face area = 0.00357495. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -6.5735e-10, Number of negative volume cells: 35 <<Writing 35 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 179.989 average: 7.91616 *Number of severely non-orthogonal (> 70 degrees) faces: 115. ***Number of non-orthogonality errors: 109. <<Writing 224 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 240 faces are incorrectly oriented. <<Writing 183 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 16.2622, 20 highly skew faces detected which may impair the quality of the results <<Writing 20 skew faces to set skewFaces Coupled point location match (average 0) OK. ***Error in face tets: 717 faces with low quality or negative volume decomposition tets. <<Writing 318 faces with low quality or negative volume decomposition tets to set lowQualityTetFaces Min/max edge length = 2.07766e-05 0.0607762 OK. *There are 66069 faces with concave angles between consecutive edges. Max concave angle = 89.3598 degrees. <<Writing 66069 faces with concave angles to set concaveFaces Face flatness (1 = flat, 0 = butterfly) : min = 0.0400623 average = 0.999966 *There are 86 faces with ratio between projected and actual area < 0.8 Minimum ratio (minimum flatness, maximum warpage) = 0.0400623 <<Writing 86 warped faces to set warpedFaces Cell determinant (wellposedness) : minimum: 9.01638e-05 average: 10.1297 ***Cells with small determinant (< 0.001) found, number of cells: 4 <<Writing 4 under-determined cells to set underdeterminedCells ***Concave cells (using face planes) found, number of cells: 590857 <<Writing 590857 concave cells to set concaveCells Face interpolation weight : minimum: 0.01328 average: 0.478489 ***Faces with small interpolation weight (< 0.05) found, number of faces: 11 <<Writing 11 faces with low interpolation weights to set lowWeightFaces Face volume ratio : minimum: -10.9825 average: 0.902224 ***Faces with small volume ratio (< 0.01) found, number of faces: 142 <<Writing 142 faces with low volume ratio cells to set lowVolRatioFaces Failed 10 mesh checks. End PS: The checkMesh command before sHm seems fine: Code:
Checking geometry... Overall domain bounding box (-0.225 -0.35 -0.125) (1.12 0.35 0.84) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.71949e-18 -6.24427e-17 1.8895e-17) OK. Max cell openness = 1.849e-16 OK. Max aspect ratio = 1.07621 OK. Minimum face area = 0.0032691. Maximum face area = 0.00351823. Face area magnitudes OK. Min volume = 0.000197167. Max volume = 0.000197167. Total volume = 0.908547. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.02586e-14 OK. Coupled point location match (average 0) OK. Mesh OK. End Last edited by jet_engine; June 11, 2016 at 11:40. Reason: Added checkMesh before sHm and sHmDict |
June 11, 2016, 11:35 |
Rep Power: 11 |
Hi, in my brief experience, bad mesh = divergence or, at least, bad results.
So, yes, I think those 10 failed mesh tests may be causing divergence. Unfortunatelly I dont have any experience with snappyhexmesh. I usually make my meshes with ICEM and then I import them with OpenFOAM. Take a look at your mesh with paraview (surfaces with edges on exibition mode), look the whole mesh and those faulty sets, that might help.
Vinícius dC.A. |
June 11, 2016, 11:55 |
Max Vorstadt
Rep Power: 10 |
No worries Thanks for your help anyway. I'll probably create a new topic since it is now related to snappyHexMesh instead of the fvSolutions/GAMG solver.
error, floatingpoint, fvsolution, pimplefoam |
Problem with complex eigenValues | Harak | OpenFOAM Running, Solving & CFD | 11 | January 26, 2016 02:48 |
Wrong fluctuation of pressure in transient simulation | caitao | OpenFOAM Running, Solving & CFD | 2 | March 5, 2015 22:33 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
Extremely slow simulation with interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 9 | April 23, 2013 11:14 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
