phi flux
Like Tree1Likes
  • 1 Post By Lorena2fdez
Old   June 7, 2016, 07:36
Default phi flux
Milad Setareh
milad653279 is on a distinguished road
Dear foamer
I am confused about phi in openfoam. as you know, convection term in incompressible Navier-Stokes is div(UU). in openfoam is writen by div (phi,U) which phi= interpolate (U) & mesh.sf(). why does phi product mesh.sf()???!!! I think that phi must be U (phi=U) NOT phi=U*sf(). please help me at it.
milad653279 is offline   Reply With Quote
Old   June 7, 2016, 10:22
Lorena Fernández Fernández
Lorena2fdez is on a distinguished road
Hi Milad,
In openFoam you use
div ( psi , phi )
where
psi is an explicit SurfaceScalarField
phi is an implicit Vol<type>Field
fvc::interpolate() or fvm:interpolate(): generates a face flux field (surfaceScalarField) from a cell based volumetric field (volScalarField).
mesh.Sf(): return the face area magnitude of a face flux field (surfaceScalarField).
For your case U is a volScalarField and phi is its respective surfaceScalarField.
Best regards,
Lorena.
lpz456 likes this.
Lorena2fdez is offline   Reply With Quote
Old   June 8, 2016, 06:44
Milad Setareh
Originally Posted by Lorena2fdez View Post
Hi Milad,
In openFoam you use
div ( psi , phi )
where
Best regards,
Lorena.
Dear Lorena
OF integrates momentum equation over a cell, I think if phi is (phi=interpolate (U) & mesh.sf()) is wrong because the value of surface area is product twice into equation. once in phi and other time when OF integrates from equation.
Old   June 8, 2016, 07:40
Originally Posted by milad653279 View Post
Dear Lorena
Probably the solver is thinking for don't make twice the product into equation. When the solver integrates the equation if it has a SurfaceScalarField, It won't make the product by value of surface area, again.
Maybe it help you, in a manual about OpenFOAM I saw a description of phi used for solve the Navier-Stokes equations:
In OpenFOAM, it's common that phi is the flux of velocity u . Other times, phi represents the flux of rho*u.
I saw the code of different solver in OpenFOAM and it's usual to do that product when it interpolate a field. For example (in KinematicSingleLayer.C):
... fvc::interpolate(rho_*gTan()) & regionMesh().Sf() ...
phiAdd += fvc::interpolate(pp) * fvc::snGrad(delta_) * regionMesh().magSf();
phi_ = fvc::interpolate(deltaRho_*U_) & regionMesh().Sf();
I don't know more about this subject but it's really strange a fail like that in the code.
Best regards,
Lorena
Old   January 11, 2021, 06:01
turbulo is on a distinguished road
I know this is long overdue, but since I just stumbled on it, I'll try to answer:
As you rightly pointed out, \phi = \mathbf{U} \cdot \mathbf{S}_f (or \phi = \rho \mathbf{U} \cdot \mathbf{S}_f depending on the solver), but, for instance, if you look at fvmDiv in gaussConvectionScheme.C you'll see that OpenFOAM doesn't compute the integral of the divergence itself, but constructs a coefficients matrix (an fvMatrix in OF parlance) from phi and the velocity simply by multiplying them, there is no extra \mathbf{S}_f involved. I'll let you see for yourself (gaussConvectionScheme.C):
    forAll(vf.boundaryField(), patchi)
        const fvPatchField<Type>& psf = vf.boundaryField()[patchi];
        const fvsPatchScalarField& patchFlux = faceFlux.boundaryField()[patchi];
        const fvsPatchScalarField& pw = weights.boundaryField()[patchi];
        fvm.internalCoeffs()[patchi] = patchFlux*psf.valueInternalCoeffs(pw);
        fvm.boundaryCoeffs()[patchi] = -patchFlux*psf.valueBoundaryCoeffs(pw);
turbulo is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
read scalar field phi, get flux through faces peterwy OpenFOAM Programming & Development 5 April 28, 2017 20:40
Udf for moving heat flux in 2D cylindrical geometry devia21 Fluent UDF and Scheme Programming 0 April 20, 2015 01:27
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
