rhoSimpleFoam unknown RASModel type laminar
Like Tree1Likes
  • 1 Post By cleoo
Old   June 6, 2016, 11:40
Default rhoSimpleFoam unknown RASModel type laminar
Thomas A
tdog is on a distinguished road
Hello
I'm trying to do a compressible simulation using rhoSimpleFoam for a laminar flow. The scripts I am using is based on an earlier OpenFOAM version (2.0 I think) as was working there, but I am running the newest version.
When I run my scripts I get the following error:
"--> FOAM FATAL ERROR:
Unknown RASModel type laminar
Valid RASModel types:
12
LRR
LaunderSharmaKE
RNGkEpsilon
SSG
SpalartAllmaras
buoyantKEpsilon
kEpsilon
kOmega
kOmegaSST
kOmegaSSTSAS
realizableKE
v2f
Where my turbulenceProperties is set to the following:
|  \\    /   O peration     | Version:  v3.0+                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      turbulenceProperties;
simulationType  RAS;
RAS
    RASModel        laminar;
    turbulence      off;
    printCoeffs     off;
As far as I can tell from the documentation (http://cfd.direct/openfoam/user-guide/turbulence/) I am doing it the right wa, what seems to be the problem?
tdog is offline   Reply With Quote
Old   June 7, 2016, 17:40
Thomas A
Has nobody tried something similar?
Old   June 8, 2016, 10:38
VA
vabishek is on a distinguished road
Originally Posted by tdog View Post
Hello
12
LRR
LaunderSharmaKE
RNGkEpsilon
SSG
SpalartAllmaras
buoyantKEpsilon
kEpsilon
kOmega
kOmegaSST
kOmegaSSTSAS
realizableKE
v2f
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
simulationType  RAS;
RAS
    RASModel        laminar;
    turbulence      off;
    printCoeffs     off;
Not sure if you have fixed it yet but the simulationType should be set to "laminar". If you read the above documentation carefully, it is mentioned at the very beginning.
vabishek is offline   Reply With Quote
Old   June 8, 2016, 11:20
Thomas A
@vabishek thank you for your help. I already tried that, but it still produces the same error:
Selecting RAS turbulence model laminar
12
LRR
LaunderSharmaKE
RNGkEpsilon
SSG
SpalartAllmaras
buoyantKEpsilon
kEpsilon
kOmega
kOmegaSST
kOmegaSSTSAS
realizableKE
v2f
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
simulationType  laminar;
RAS
    RASModel        laminar;
    turbulence      off;
    printCoeffs     off;
Old   June 8, 2016, 11:24
VA
12
LRR
LaunderSharmaKE
RNGkEpsilon
SSG
SpalartAllmaras
buoyantKEpsilon
kEpsilon
kOmega
kOmegaSST
kOmegaSSTSAS
realizableKE
v2f
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
RAS
    RASModel        laminar;
    turbulence      off;
    printCoeffs     off;
Well, it should look something like this
|  \\    /   O peration     | Version:  3.0.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
RAS
    RASModel        kOmega;
    turbulence      off;
    printCoeffs     on;
As the error message says, just pick one RASModel from the given list. As you can see, "laminar" is not listed there. If you set simulationType to laminar, it doesn't really mattter what you set RASModel to. Hope that helps!
Old   June 8, 2016, 11:54
Thomas A
Arg, thanks for the tip
Just tried, but still got an error message because I then need to supply files for the boundary conditions - because in theory it shouldn't need them because it's running the simulation as laminar, but those are turbulent models, right?
Old   June 9, 2016, 08:32
Pedro
pupo is on a distinguished road
This bug seems to have been fixed "recentely"
check the following Commit: https://github.com/OpenFOAM/OpenFOAM...2940548af3ebb3
If your createFields.H in BuyoantSimpleFoam looks like this:
autoPtr<compressible::RASModel> turbulence
     compressible::New<compressible::RASModel>
          rho,
          U,
          phi,
          thermo
change it to:
autoPtr<compressible::turbulenceModel> turbulence
     compressible::turbulenceModel::New
          rho,
          U,
          phi,
          thermo
cheers
pupo is offline   Reply With Quote
Old   June 11, 2016, 07:31
Peter F
peterf is on a distinguished road
I can't locate the applications folder in order to change createFields.H. How do I do this?
I am running OpenFOAM via Docker on a Mac. So I don't really see a path or folder for OpenFOAM. I have tried to show the hidden folders, but the OpenFOAM or applications folder still doesn't appear.
peterf is offline   Reply With Quote
Old   September 9, 2016, 05:58
annn
cleoo is on a distinguished road
RAS
    RASModel        kOmega;
    turbulence      off;
    printCoeffs     on;
does it actually read the entries in the RAS part if you specified the simulationType as being laminar?
whats the difference between this:
simulationType RAS;
RAS
    RASModel        kOmega;
    turbulence      off;
    printCoeffs     on;
and
because isn't turbulence off technically just laminar flow?
salomama likes this.
cleoo is offline   Reply With Quote
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 02:47
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
Divergent with rhoSimpleFoam and the boundary condition problems qjh888 OpenFOAM Running, Solving & CFD 0 May 17, 2016 21:31
Boundary Conditions MtnRunBeachBum OpenFOAM Pre-Processing 1 April 30, 2015 17:33
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
