Gauss DEShybrid usage
Like Tree3Likes
  • 3 Post By Nealcaffrey
Old   June 6, 2016, 06:18
Question Gauss DEShybrid usage
Max Vorstadt
jet_engine is on a distinguished road
Hi! I'm trying to achieve convergence in my kwSST simulation and one of the parameters that I want to change is the div(phi,U). I have checked on Openfoam's website and apparently the only thing that has to be added on fvSchemes is:
divSchemes
    div(phi,U)          Gauss DEShybrid
    linear                        // scheme 1
    linearUpwind grad(U)          // scheme 2
    0.65                          // DES coefficient, typically = 0.65
    30                            // Reference velocity scale
    2                             // Reference length scale
    0                             // Minimum sigma limit (0-1)
    1;                            // Maximum sigma limit (0-1)
But when I add this (I'm using 3.0+, of course), the error output is:
--> FOAM FATAL IO ERROR:
Unknown discretisation scheme DEShybrid
Valid schemes are:
Does anybody know where the problem could be? Both DEShybrid.C and DEShybrid.H are on the src folder...
Thanks in advance!
jet_engine is offline   Reply With Quote
Old   June 6, 2016, 07:45
JNSN's Avatar
Jan
JNSN is on a distinguished road
you have to include the library (where the Scheme is located in) in your controlDict.
Best regards,
Jan
JNSN is offline   Reply With Quote
Old   November 18, 2019, 19:09
Gang Wang
Gang Wang is on a distinguished road
divSchemes
    linear                        // scheme 1
Valid schemes are:
Thanks in advance!
Hi!
Have u solved your problem? Because I also encounter this....
Gang Wang is offline   Reply With Quote
Old   January 20, 2022, 08:00
Balaji
Nealcaffrey is on a distinguished road
Originally Posted by Gang Wang View Post
Hi!
Include this library at the start of your controlDict, it should work then
libs (turbulenceModelSchemes);
application pimpleFoam;
startFrom startTime;
startTime 0.;
stopAt endTime;
endTime 0.005;
deltaT 0.0001;
writeControl adjustableRunTime;
saeed jamshidi, Gang Wang and xCFD like this.
Nealcaffrey is offline   Reply With Quote
des, error, files, fvschemes, kwsstmodel
Steady-State and Transient Solvers 70m1 OpenFOAM Running, Solving & CFD 21 May 8, 2021 08:09
Free Surface Ship Flow timfranke OpenFOAM Running, Solving & CFD 322 March 3, 2021 10:04
2nd Order Convergence Problem for 3D Airfoil turkmengokce OpenFOAM Running, Solving & CFD 1 September 10, 2015 08:20
bounded Gauss upwind Scheme deepinheart OpenFOAM Running, Solving & CFD 1 February 23, 2015 06:57
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
