Running rhoCentralFoam in Parallel: Cannot find patchField entry for procBoundary
Like Tree5Likes
  • 5 Post By hbrist7
Old   June 3, 2016, 13:57
Default Running rhoCentralFoam in Parallel: Cannot find patchField entry for procBoundary
Henry
hbrist7 is on a distinguished road
I'm fairly new to OpenFOAM and am trying to run the rhoCentralFoam solver in parallel (with 8 processors). I keep getting the following error:
"--> FOAM FATAL IO ERROR:
Cannot find patchField entry for procBoundary0to3
file: home/mpiuser/OpenFOAM/mpiuser-3.0.1/run/henry/rhoCentralTest/processor0/0/p.boundaryField from line 25 to line 58.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh&, const dictionary&)
in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209
FOAM parallel run exiting"
I have tried creating placeholder procBoundary entries in the 0/p, 0/T and 0/U files inside the boundaryField dictionary in each of those files:
boundaryField
inlet
type fixedValue;
value uniform (100 0 0);
... there are other patch entries here
procBoundary0to1 // this is what I tried to add (for each processor to processor connection)
type processor;
The error I get when I do this, however, is even more complicated and unintelligible. I feel like I am missing something simple. Is there a file or dictionary entry missing somewhere that is required for a rhoCentralFoam parallel run?
Thanks,
Henry
hbrist7 is offline   Reply With Quote
Old   June 29, 2016, 11:10
Default Solved
Henry
Sometimes we miss stupid things: this is solved with a simple
"#include $WM_PROJECT_DIR/etc/caseDicts/setConstraintTypes"
statement in each of the 0/* files.
louisgag, saidc., zqbnu and 2 others like this.
Old   August 31, 2022, 06:14
Luckmore Kadzungura
Lucky is on a distinguished road
i like your last post. Thank you for that. It just helped me.
Lucky is offline   Reply With Quote
parallel compressible, patchfield, procboundary, processor boundary, rhocentralfoam
running rhoCentralFoam in parallel: cannot find patchField entry for procBoundary hbrist7 OpenFOAM 6 March 27, 2024 07:11
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 05:38
Fluent 14.0 file not running in parallel mode in cluster tejakalva FLUENT 0 February 4, 2015 08:02
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
