Calculate center position and velocity of two bubbles
Like Tree3Likes
  • 1 Post By Taataa
  • 1 Post By piu58
  • 1 Post By Taataa
Old   May 25, 2016, 10:32
Default Calculate center position and velocity of two bubbles
Arsalan
arsalan.dryi is on a distinguished road
Hi Foamers,
I'm doing a 3D simulation of two and three bubble rising using a modified interFoam solver and I need to center position, velocity and surface area of the bubbles.
For a single bubble rising I used swak4Foam expressions for example for center position in Y as follows :
    bubbleCentreY
        type swakExpression;
        valueType internalField;
        verbose true;
    variables (
    "Vol= sum (alpha1 < 0.5 ? vol() : 0);"
    "VolY= sum (alpha1 < 0.5 ? pos().y*vol() : 0);"
    expression "VolY/Vol";
        accumulations (
        min
Is there a way to compute these for two or three bubbles in this manner?
Thanks in advance,
Best Regards,
Arsalan.
arsalan.dryi is offline   Reply With Quote
Old   May 26, 2016, 12:01
Arsalan
Does anybody have an idea?
Any help and comment will be greatly appreciated.
Regards,
Arsalan.
Old   June 8, 2016, 12:06
Arsalan
I still didn't solve this problem, does anyone have an idea?!
Thanks in advance,
Regards.
Old   March 29, 2018, 17:32
Lionel GAMET
x86_64leon is on a distinguished road
Hi Arsalan
Did you solve this problem of tracking more than one bubble and computing the center of mass, velocity, surface, volume ... etc of each of the bubbles ?
Regards
x86_64leon is offline   Reply With Quote
Old   March 30, 2018, 00:02
Taher Chegini
Taataa is on a distinguished road
One way is to use a multiphase flow solver like multiphaseInterFoam and for each bubble use a different name but same physical parameters. This way you can track each phase using the method OP mentioned or use this function that I have written for a wedge mesh which works in parallel as well:
functions
  riseVelocity
    libs            ("libutilityFunctionObjects.so");
    type coded;
    name riseVelocity;
    codeExecute
        const volScalarField& alpha =
            mesh().lookupObject<volScalarField>("alpha.water");
        const volVectorField& U =
            mesh().lookupObject<volVectorField>("U");
        const volVectorField& centers = mesh().C();
        const scalarField& vols = mesh().V();
        const objectRegistry& db = mesh().thisDb();
        scalar ts = db.time().value();
        const dictionary& transportProperties =
            db.lookupObject<IOdictionary>
                "transportProperties"
        dictionary alpha2
            transportProperties.subDict("air")
        dimensionedScalar rhoBubble
            "rhoBubble",
            dimDensity,
            alpha2.lookup("rho")
        // threshold for interface
        scalar th = 0.5;
        // water level in the well
        scalar ht = 0.3;
        // sum of mass
        scalar sumMass = 0;
        // sum of volume
        scalar sumVol = 0;
        // sum of y by mass
        scalar sumX = 0;
        scalar sumY = 0;
        // sum of Uy by volume
        scalar sumUY = 0;
        //volume of liquid in well
        scalar vl = 0;
        forAll(centers, I)
            if ( alpha[I] < th && centers[I].y() < ht )
                //Mass center
                sumY    += (1 - alpha[I])*rhoBubble.value()*vols[I]*centers[I].y();
                sumX    += (1 - alpha[I])*rhoBubble.value()*vols[I]*centers[I].x();
                sumMass += (1 - alpha[I])*rhoBubble.value()*vols[I];
	        //Rising Velocity
                sumUY   += (1 - alpha[I])*vols[I]*U[I].y();
                sumVol  += (1 - alpha[I])*vols[I];
            } else if ( centers[I].y() < ht ) {
                vl += alpha[I]*vols[I];
        reduce(sumY, sumOp<scalar>());
        reduce(sumX, sumOp<scalar>());
        reduce(sumMass, sumOp<scalar>());
        reduce(sumUY, sumOp<scalar>());
        reduce(sumVol, sumOp<scalar>());
        reduce(vl, sumOp<scalar>());
        // center of gravity
        scalar cgX = sumX/max(sumMass, SMALL);
        scalar cgY = sumY/max(sumMass, SMALL);
        // rising velocity
        scalar vr = sumUY/max(sumVol, SMALL);
        const volScalarField& p =
            mesh().lookupObject<volScalarField>("p");
        const faceList& ff = mesh().faces();
        const pointField& pp = mesh().points();
        // Pressure inside the bubble
        scalar pBubble = 0;
        forAll(centers, I)
            const cell& cc = mesh().cells()[I];
            labelList pLabels(cc.labels(ff));
            pointField pLocal(pLabels.size(), vector::zero);
            forAll (pLabels, J)
                pLocal[J] = pp[pLabels[J]];
            if
              sign(Foam::max(pLocal& vector(1,0,0)) - cgX) == 1 &&
              sign(cgX - Foam::min(pLocal& vector(1,0,0))) == 1 &&
              sign(Foam::max(pLocal& vector(0,1,0)) - cgY) == 1 &&
              sign(cgY - Foam::min(pLocal& vector(0,1,0))) == 1
                pBubble = mag(p[I]);
                break;
        reduce(pBubble, sumOp<scalar>());
        if (Pstream::master())
            const fileName& outputFile = "plots/riseUCG";
            OFstream os
                outputFile,
                IOstream::ASCII,
                IOstream::currentVersion,
                IOstream::UNCOMPRESSED,
                true
            scalar tot = 360.0/5.0;
            Info<< "Writing rising velocity, CG, "
                << "volume of bubble, volume of liquid "
                << "and pressure inside the bubble for current time" << endl;
            os  << ts << "  " << vr << "  " << cgX  << "  " << cgY
                << "  " << sumVol*tot << "  " << vl*tot << "  " << pBubble << endl;
It can easily be extended to multiphase e.g. for each phase add a new lookup, say alpha1 for alpha.water, alpha2 for alpha.air1 etc..
Hama04 likes this.
Taataa is offline   Reply With Quote
Old   March 30, 2018, 02:41
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I solved this problem by a small external program which analyses the alpha value for each cell. It is very easy to calculate the values you need form that.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   April 4, 2018, 05:10
Arsalan
functions
  riseVelocity
    type coded;
    name riseVelocity;
    codeExecute
        dictionary alpha2
            "rhoBubble",
            dimDensity,
        scalar th = 0.5;
        scalar ht = 0.3;
        // sum of mass
        scalar sumMass = 0;
        // sum of volume
        scalar sumVol = 0;
        // sum of y by mass
        scalar sumX = 0;
        scalar sumY = 0;
        scalar sumUY = 0;
        scalar vl = 0;
        forAll(centers, I)
                //Mass center
	        //Rising Velocity
        // rising velocity
        scalar pBubble = 0;
        forAll(centers, I)
            forAll (pLabels, J)
            if
                break;
            OFstream os
                outputFile,
                IOstream::ASCII,
                true
Multiphase solvers need a surface tension between each two different phases and the results can be completely wrong especially when bubbles get close to each other, for example in bubbles coalescence.
Old   April 4, 2018, 05:13
Arsalan
Could you explain more about that, please? And also post your written code here if possible.
Thanks.
Old   April 4, 2018, 07:32
piu58's Avatar
Uwe Pilz
Thanks.
That is quite easy. You go row wise through the alpha field, calculate the x and y coordinates according the setting of your region. If the alpha value is below a limiting value ( I used 0.2 for discriminating air / water), you add the x and y coordinates to get finally the average of them. This average should be close to the center of mass.
I don't believe that my C program is of any use for you. It is tailored to my setting and comments are in German.
arsalan.dryi likes this.
Uwe Pilz
Old   April 5, 2018, 00:05
Taher Chegini
Oh, I didn't know interFoam is not a multiphase solver!
cdritselis78 likes this.
Old   March 28, 2022, 12:52
Default question
  #11
Farzad Faraji
farzadmech is on a distinguished road
Dear Arslan
Have you added these lines to controlDict? what other lines have you added? which library have you added in the libs section?
for exmample;
libs (
    "libgroovyBC.so"
Thanks,
Farzad
Hi Foamers,
    bubbleCentreY
        verbose true;
    variables (
        accumulations (
        min
Thanks in advance,
Best Regards,
Arsalan.
farzadmech is offline   Reply With Quote
bubble centre, bubble velocity, swak4foam, vof
Calculate Bubbles Centre position and Velocity arsalan.dryi OpenFOAM Post-Processing 2 May 21, 2016 06:28
DPM : Fluid velocity at particle position ? souria Fluent Multiphase 1 January 30, 2015 06:58
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Wall velocity changing with position Abbas FLUENT 1 May 26, 2003 08:23
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
