Error appears when using chtMultiRegionFoam |
May 23, 2016, 06:19 |
Raffael H.
Rep Power: 10 |
Hello Foam-Experts!
I'm really new to OpenFoam and the programming in it and so I'm not experienced with it. But for my studies I got the following task: I have to simulate a solid cylinder hanging in air. The cylinder radiates heat and convection is on hand. So I use "chtMultiRegionFoam" with the command Code:
mpirun -np 3 chtMultiRegionFoam -parallel Then I realized, that the error-messages for both cases are the same. This error-message appears after the thermophysical properties for region air were read and added and ends up like: Code:
mpirun noticed that process rank 2 with PID 477 on node boot2docker exited on signal 8 <Floating point exception> Because an error-message like that appears for my case as well as for the model-programm, I guess the error is not my fault. So I would like to ask you all, what the problem actually is. By the way I use the windows-version of OpenFoam. I really please you to help me and also if you need some more information about my problem, please answer me as soon as possible. Thanks in advance Raffael |
May 25, 2016, 04:35 |
Raffael H.
Rep Power: 10 |
I really need to be helped with this problem. I don't know what the error message means and what to do about that. It is really important for me.
I'm not experienced with OpenFOAM and maybe I did something wrong. But until now I found nothing... I really please you to help me! Thanks in advance Raffael |
May 25, 2016, 05:09 |
Rep Power: 16 |
The error message that you have is a Floating Point Exception. The most likely culprit for this is a division by zero somewhere. Look through the different boundary condition files and see if there is something that shouldn't be zero is zero. What does the log of your run say apart from the mpirun run abort? Cheers, Antimony |
May 25, 2016, 06:41 |
Raffael H.
Rep Power: 10 |
Hello Antimony,
At first I have to say, that I'm very thankful for you're reply! A division by zero? That's a good point to look for, thanks for that. I'll post about the results of my upcoming search later. The whole error-message looks like this: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : May 25 2016 Time : 09:27:07 Host : "boot2docker" PID : 255 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.256" "boot2docker.257" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 256 on node boot2docker exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- Again thank you! Raffael |
May 25, 2016, 22:38 |
Rep Power: 16 |
You can get the entire output to a log file by adding "2>&1" at the end of the function call. Since it seems to stop after loading your thermophysical properties, is your temperature 0 at any point? Do take care that the units of temperature are in K... Cheers, Antimony |
May 31, 2016, 04:58 |
Raffael H.
Rep Power: 10 |
Hello Antimony,
I checked for zeros in all initial fields, espacially for the temperatures. Thereby I realized, that after every execution of chtMultiRegionFoam all temperatures are set on default (293K), although I've set them before on whole other values. I corrected it, but still this error-message appears: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : May 31 2016 Time : 07:44:39 Host : "boot2docker" PID : 803 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.804" "boot2docker.805" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } [1] #0 [0] #0 [2] #0Foam::error::printStack(Foam::Ostream&) Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [0] #2 ? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [1] #2 ? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [2] #2 ? in "/lib64/libc.so.6" [0] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/lib64/libc.so.6" [1] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/lib64/libc.so.6" [2] #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [0] #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [2] #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [1] #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [0] in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [1] #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&)[2] #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&)#5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [2] #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&)[1] #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [0] #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [0] #7 [1] #7 in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so" [2] #7 ??? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [0] # in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [2] #8 __libc_start_main8 __libc_start_main[1] #8 __libc_start_main in "/lib64/libc.so.6" [0] #9 in "/lib64/libc.so.6" [1] #9 in "/lib64/libc.so.6" [2] #9 ??? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiR in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" in "/opt/OpeegionFoam" [boot2docker:00803] *** Process received signal *** [boot2docker:00803] Signal: Floating point exception (8) [boot2docker:00803] Signal code: (-6) [boot2docker:00803] Failing at address: 0x1f400000323 [boot2docker:00803] [ 0] /lib64/libc.so.6(+0x326a0)[0x7f7016c636a0] [boot2docker:00803] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x7f7016c63625] [boot2docker:00803] [ 2] /lib64/libc.so.6(+0x326a0)[0x7f7016c636a0] [boot2docker:00803] [ 3] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11heRhoThermoINS_9rhoThermoENS_11pureMixtureINS_14constTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE9calculateEv+0x646)[0x7f701cd2f3c6] [boot2docker:00803] [ 4] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam9rhoThermo27addfvMeshConstructorToTableINS_11heRhoThermoIS0_NS_11pureMixtureINS_14constTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEEEE3NewERKNS_6fvMeshERKNS_4wordE+0x5c)[0x7f701cd3b8dc] [boot2docker:00803] [ 5] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11basicThermo3NewINS_9rhoThermoEEENS_7autoPtrIT_EERKNS_6fvMeshERKNS_4wordE+0x1ac)[0x7f701ccd4d1c] [boot2docker:00803] [ 6] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam9rhoThermo3NewERKNS_6fvMeshERKNS_4wordE+0x9)[0x7f701ccd3429] [boot2docker:00803] [ 7] chtMultiRegionFoam[0x4a2024] [boot2docker:00803] [ 8] /lib64/libc.so.6(__libc_start_main+0xfd)[0x7f7016c4fd5d] [boot2docker:00803] [ 9] chtMultiRegionFoam[0x432619] [boot2docker:00803] *** End of error message *** [boot2docker:00805] *** Process received signal *** [boot2docker:00805] Signal: Floating point exception (8) [boot2docker:00805] Signal code: (-6) [boot2docker:00805] Failing at address: 0x1f400000325 [boot2docker:00805] [ 0] /lib64/libc.so.6(+0x326a0)[0x7efe48d2c6a0] [boot2docker:00805] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x7efe48d2c625] [boot2docker:00805] [ 2] /lib64/libc.so.6(+0x326a0)[0x7efe48d2c6a0] [boot2docker:00805] [ 3] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11heRhoThermoINS_9rhoThermoENS_11pureMixtureINS_14constTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE9calculateEv+0x646)[0x7efe4edf83c6] [boot2docker:00805] [ 4] nFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [boot2docker:00804] *** Process received signal *** [boot2docker:00804] Signal: Floating point exception (8) [boot2docker:00804] Signal code: (-6) [boot2docker:00804] Failing at address: 0x1f400000324 [boot2docker:00804] [ 0] /lib64/libc.so.6(+0x326a0)[0x7fc502d5f6a0] [boot2docker:00804] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x7fc502d5f625] [boot2docker:00804] [ 2] /lib64/libc.so.6(+0x326a0)[0x7fc502d5f6a0] [boot2docker:00804] [ 3] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11heRhoThermoINS_9rhoThermoENS_11pureMixtureINS_14constTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEE9calculateEv+0x646)[0x7fc508e2b3c6] [boot2docker:00804] [ 4] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam9rhoThermo27addfvMeshConstructorToTableINS_11heRhoThermoIS0_NS_11pureMixtureINS_14constTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEEEE3NewERKNS_6fvMeshERKNS_4wordE+0x5c)[0x7fc508e378dc] [boot2docker:00804] [ 5] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11basicThermo3NewINS_9rhoThermoEEENS_7autoPtrIT_EERKNS_6fvMeshERKNS_4wordE+0x1ac)[0x7fc508dd0d1c] [boot2docker:00804] [ 6] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam9rhoThermo3NewERKNS_6fvMeshERKNS_4wordE+0x9)[0x7fc508dcf429] [boot2docker:00804] [ 7] chtMultiRegionFoam[0x4a2024] [boot2docker:00804] [ 8] /lib64/libc.so.6(__libc_start_main+0xfd)[0x7fc502d4bd5d] [boot2docker:00804] [ 9] chtMultiRegionFoam[0x432619] [boot2docker:00804] *** End of error message *** /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam9rhoThermo27addfvMeshConstructorToTableINS_11heRhoThermoIS0_NS_11pureMixtureINS_14constTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_16sensibleEnthalpyEEEEEEEEEE3NewERKNS_6fvMeshERKNS_4wordE+0x5c)[0x7efe4ee048dc] [boot2docker:00805] [ 5] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11basicThermo3NewINS_9rhoThermoEEENS_7autoPtrIT_EERKNS_6fvMeshERKNS_4wordE+0x1ac)[0x7efe4ed9dd1c] [boot2docker:00805] [ 6] /opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam9rhoThermo3NewERKNS_6fvMeshERKNS_4wordE+0x9)[0x7efe4ed9c429] [boot2docker:00805] [ 7] chtMultiRegionFoam[0x4a2024] [boot2docker:00805] [ 8] /lib64/libc.so.6(__libc_start_main+0xfd)[0x7efe48d18d5d] [boot2docker:00805] [ 9] chtMultiRegionFoam[0x432619] [boot2docker:00805] *** End of error message *** -------------------------------------------------------------------------- mpirun noticed that process rank 1 with PID 804 on node boot2docker exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- I have regions with different temperatures, so that a heat transfer takes place. Do I need a transferProperties-file in the constant-dictionary for that? Thanks in advance Raffael P.S.: Thank you for the advice how to copy the whole error-message. |
June 2, 2016, 11:01 |
Raffael H.
Rep Power: 10 |
I used the command
unset FOAM_SIGFPE After this command, the error-message looks totally different: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam Date : Jun 02 2016 Time : 13:55:33 Host : "boot2docker" PID : 314 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam Date : Jun 02 2016 Time : 13:55:34 Host : "boot2docker" PID : 315 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam Date : Jun 02 2016 Time : 13:55:34 Host : "boot2docker" PID : 316 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create solid mesh for region cable for time = 0 Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } --> FOAM FATAL IO ERROR: inconsistent patch and patchField types for patch type empty and patchField type calculated file: /home/ofuser/workingDir/FoamCases/KabelInLuft/0/air/T.boundaryField.FrontAndBack from line 30 to line 31. From function static Foam::tmp<Foam::fvPatchField<Type> > Foam::fvPatchField<Type>::New(const Foam::fvPatch&, const Foam::DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = double] in file /opt/OpenFOAM/OpenFOAM-v3.0+/src/finiteVolume/lnInclude/fvPatchFieldNew.C at line 163. FOAM exiting ------------------------------------------------------- Primary job terminated normally, but 1 process returned a non-zero exit code.. Per user-direction, the job has been aborted. ------------------------------------------------------- -------------------------------------------------------------------------- mpirun detected that one or more processes exited with non-zero status, thus causing the job to be terminated. The first process to do so was: Process name: [[40566,1],0] Exit code: 1 -------------------------------------------------------------------------- Maybe you can help me to find out what is wrong now? Thanks in advance Raffael |
June 4, 2016, 19:52 |
Joćo Ferreira
Rep Power: 12 |
From the error it appears that you are using a "calculated" boundary condition in a boundary with the type empty.
If you need to use the calculated boundary, check if that boundary is defined as patch or wall on the "boundary" file (constant/<region>/polyMesh/boundary). I hope it helps you! |
June 6, 2016, 05:22 |
#9 |
Raffael H.
Rep Power: 10 |
Hello Joćo!
I thank you so much for your advice. This problem is solved, but now I'm standing in front of the next problem.... like I said, I'm very new to this and know almost nothing about OpenFOAM. Now appears the following error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : Jun 06 2016 Time : 08:07:39 Host : "boot2docker" PID : 250 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.251" "boot2docker.252" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type laminar Selecting radiationModel none Adding to KFluid Adding to dpdtFluid [2] [1] [1] [1] --> FOAM FATAL IO ERROR: [1] keyword PIMPLE is undefined in dictionary "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor1/system/air/fvSolution" [1] [1] file: /home/ofuser/workingDir/FoamCases/KabelInLuft/processor1/system/air/fvSolution from line 0 to line 0. [2] [2] --> FOAM FATAL IO ERROR: [2] keyword PIMPLE is undefined in dictionary "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor2/system/air/fvSolution" [2] [2] file: /home/ofuser/workingDir/FoamCases/KabelInLuft/processor2/system/air/fvSolution from line 0 to line 0. [2] [2] From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const [2] in file db/dictionary/dictionary.C at line 640. [2] FOAM parallel run exiting [2] [1] [1] From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const [1] in file db/dictionary/dictionary.C at line 640. [1] FOAM parallel run exiting [1] [0] [0] [0] --> FOAM FATAL IO ERROR: [0] keyword PIMPLE is undefined in dictionary "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor0/system/air/fvSolution" [0] [0] file: /home/ofuser/workingDir/FoamCases/KabelInLuft/processor0/system/air/fvSolution from line 22 to line 78. [0] [0] From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const [0] in file db/dictionary/dictionary.C at line 640. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [boot2docker:00248] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [boot2docker:00248] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages But there is no system-folder in one of the processor-folders, so there is no fvSolutions. So I looked after the ordinary fvSolution to search for PIMPLE... but there is only SIMPLE. Here you can see my fvSolution: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system/domain1"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { rho { solver PCG; preconditioner DIC; tolerance 1e-7; relTol 0; } p_rgh { solver GAMG; tolerance 1e-7; relTol 0.01; smoother GaussSeidel; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; maxIter 100; } "(U|h|k|epsilon)" { solver PBiCG; preconditioner DILU; tolerance 1e-7; relTol 0.1; } } SIMPLE { momentumPredictor on; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 100000; rhoMin rhoMin [1 -3 0 0 0] 0.2; rhoMax rhoMax [1 -3 0 0 0] 2; } relaxationFactors { fields { rho 1; p_rgh 0.7; } equations { U 0.3; h 0.7; nuTilda 0.7; k 0.7; epsilon 0.7; omega 0.7; "ILambda.*" 0.7; } } // ************************************************************************* // I try my best, but I don't have much time for my project anymore, so I need your help! Thanks in advance Raffael |
June 6, 2016, 05:36 |
#10 |
Joćo Ferreira
Rep Power: 12 |
Since the fvSolution file is the same for all the processors, the solvers reads it from the system folder.
In this fvSolution file you need to have the PIMPLE keywords with the inputs you need/want. Did you construct the fvSolution yourself or did you copied it from another location? It appears that you copied it from a tutorial of a steady-state solver. As you are using chtMultiRegionFoam look into the tutorials for this solver. For example: $FOAM_TUTORIALS/heatTransfer/chtMultiRegionFoam/multiRegionHeater Check the fvSolution of this tutorial and update your own with the required keywords. |
June 7, 2016, 08:39 |
#11 |
Raffael H.
Rep Power: 10 |
Hello Joćo!
At first thank you for your very quick reply! Your advice took me further and I have the feeling, that my problems with OpenFOAM are almost solved. But this time this Error appeared: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : Jun 07 2016 Time : 11:33:59 Host : "boot2docker" PID : 281 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.282" "boot2docker.283" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type laminar Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding MRF No MRF models present Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region cable Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel none Adding fvOptions No finite volume options present Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.801 max: 1.56 Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.801 max: 1.56 Time = 300 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 [2] [2] [2] --> FOAM FATAL ERROR: [2] cannot be called for a calculatedFvPatchField on patch Nature of field U in file "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor2/0/air/U" You are probably trying to solve for a field with a default boundary condition. [2] [2] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = Foam::Vector<double>] [2] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [2] FOAM parallel run exiting [2] [0] [0] [0] --> FOAM FATAL ERROR: [0] cannot be called for a calculatedFvPatchField on patch Nature of field U in file "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor0/0/air/U" You are probably trying to solve for a field with a default boundary condition. [0] [0] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = Foam::Vector<double>] [0] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [0] FOAM parallel run exiting [0] [1] [1] [1] --> FOAM FATAL ERROR: [1] cannot be called for a calculatedFvPatchField on patch Nature of field U in file "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor1/0/air/U" You are probably trying to solve for a field with a default boundary condition. [1] [1] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = Foam::Vector<double>] [1] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [1] FOAM parallel run exiting [1] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [boot2docker:00279] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [boot2docker:00279] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Thanks in advance Raffael |
June 7, 2016, 10:01 |
#12 |
Joćo Ferreira
Rep Power: 12 |
No problem
Let's see, from what i understand you are using a boundary condition named "calculated" in the U field (0/<region>/U). And the error says that you cannot use such type. I'm not into your project so i can't give you a more detailed advice on what boundary type you should use. However, fixedValue or zeroGradient is normally used on the U field. |
June 8, 2016, 10:19 |
#13 |
Raffael H.
Rep Power: 10 |
Hello Joćo and all the other Foamers out there,
again thanks for your help! I changed the boundary conditions for "U" for both regions and by the way I realized, that "k" and "epsilon" are both zero when "U" is zero (I have no moving fluid in my system). So I changed them too. But like always it doesn't work... This time the message looks like this: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : Jun 08 2016 Time : 13:07:44 Host : "boot2docker" PID : 320 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.321" "boot2docker.322" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type laminar Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding MRF No MRF models present Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region cable Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel none Adding fvOptions No finite volume options present Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.801 max: 1.56 Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.801 max: 1.56 Time = 300 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 [1] [1] [1] --> FOAM FATAL ERROR: [1] cannot be called for a calculatedFvPatchField on patch Nature of field h in file "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor1/0/air/h" You are probably trying to solve for a field with a default boundary condition. [1] [1] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double] [1] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [1] FOAM parallel run exiting [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] cannot be called for a calculatedFvPatchField on patch Nature of field h in file "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor2/0/air/h" You are probably trying to solve for a field with a default boundary condition. [2] [2] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double] [2] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [2] FOAM parallel run exiting [2] [0] [0] [0] --> FOAM FATAL ERROR: [0] cannot be called for a calculatedFvPatchField on patch Nature of field h in file "/home/ofuser/workingDir/FoamCases/KabelInLuft/processor0/0/air/h" You are probably trying to solve for a field with a default boundary condition. [0] [0] From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double] [0] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 2 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [boot2docker:00318] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [boot2docker:00318] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Where does it come from? What can I do now? I'm sorry for annoying with my stupid questions. Every little problem is a huge unexplainable obstacle to me... I'm really a noob in OpenFOAM. Thanks in advance Raffael |
June 9, 2016, 04:13 |
#14 |
Joćo Ferreira
Rep Power: 12 |
The error is the same so you already know how to solve it, if needed
Regarding the h field, that's weird.. Do you have any file named "h" in your 0/ or 0/<region>/ folder? The solver does not require such field although i recall having some problems for having "not needed" fields in the 0/ folder. Anyway, can you check that? |
June 9, 2016, 06:20 |
#15 |
Raffael H.
Rep Power: 10 |
Hello Joćo,
I know that the error-message is the same like before, but the problem is, that I have no h-file, neither in the 0-folder nor in the 0/<region>/ folder. I also checked for the processor-folders and there isn't h as well. I just have these: cellToRegion epsilon k p p_rgh T U Why does OpenFOAM ask for "h"? Like you said... the solver doesn't need h. Could it be, that the problem is in one of the other files? Maybe in p_rgh? By the way, can I ask what the difference between p and p_rgh is? p_rgh is the only file with an h in it, so maybe this is meant. Thanks in advance Raffael |
June 9, 2016, 06:50 |
#16 |
Rep Power: 16 |
"h" here should refer to enthalpy(?), basically it is associated with the temperature field, if my understanding is correct. Check your T boundary conditions... For your other question: http://www.cfd-online.com/Forums/ope...tml#post276743 Cheers, Antimony |
June 9, 2016, 10:27 |
#17 |
Raffael H.
Rep Power: 10 |
Hello Antimony and Joćo,
Thank you Antimony for the helpful advice. I checked my T-files and after I used chtMultiRegionFoam OpenFOAM complained about p_rgh with the same issue. So I checked all the files again and now a new error appeared. I looked through other threads, but there they didn't come to a solution to my problem now. The error-message looks like this: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : Jun 09 2016 Time : 12:25:12 Host : "boot2docker" PID : 295 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.296" "boot2docker.297" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type laminar Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding MRF No MRF models present Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region cable Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel none Adding fvOptions No finite volume options present Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.801 max: 1.56 Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.801 max: 1.56 Time = 300 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 5.33e-08, No Iterations 12 Min/max T:265 356 GAMG: Solving for p_rgh, Initial residual = 0.949, Final residual = 0.00943, No Iterations 10 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (air): sum local = 12.3, global = 1, cumulative = 1 GAMG: Solving for p_rgh, Initial residual = 0.0532, Final residual = 9.32e-08, No Iterations 56 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (air): sum local = 3.68, global = -0.278, cumulative = 0.722 Solving for solid region cable DICPCG: Solving for h, Initial residual = 1, Final residual = 7.55e-07, No Iterations 18 Min/max T:332 352 ExecutionTime = 0.28 s ClockTime = 0 s Region: air Courant Number mean: 9.73e+06 max: 1.01e+11 Region: cable Diffusion Number mean: 0.801 max: 1.56 Time = 600 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 3.03e-08, No Iterations 54 Min/max T:-2.85e+10 3.32e+09 GAMG: Solving for p_rgh, Initial residual = 0.963, Final residual = nan, No Iterations 1000 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (air): sum local = nan, global = -nan, cumulative = -nan GAMG: Solving for p_rgh, Initial residual = nan, Final residual = nan, No Iterations 1000 [0] [0] [0] --> FOAM FATAL IO ERROR: [0] wrong token type - expected Scalar, found on line 0 the word 'nan' [0] [0] file: /home/ofuser/workingDir/FoamCases/KabelInLuft/processor0/system/air/data.solverPerformance.p_rgh at line 0. [0] [0] From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [0] in file lnInclude/Scalar.C at line 93.[1] [1] [1] --> FOAM FATAL IO ERROR: [1] wrong token type - expected Scalar, found on line 0 the word 'nan' [1] [1] file: /home/ofuser/workingDir/FoamCases/KabelInLuft/processor1/system/air/data.solverPerformance.p_rgh at line 0. [1] [1] From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [1] in file lnInclude/Scalar.C at line 93. [1] FOAM parallel run exiting [1] [2] [2] [2] --> FOAM FATAL IO ERROR: [2] wrong token type - expected Scalar, found on line 0 the word 'nan' [2] [2] file: /home/ofuser/workingDir/FoamCases/KabelInLuft/processor2/system/air/data.solverPerformance.p_rgh at line 0. [2] [2] From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) [2] in file lnInclude/Scalar.C at line 93. [2] FOAM parallel run exiting [2] [0] FOAM parallel run exiting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [boot2docker:00293] 1 more process has sent help message help-mpi-api.txt / mpi-abort [boot2docker:00293] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Please check with me, where the mistake can be. Thanks in advance Raffael |
June 10, 2016, 03:36 |
#18 |
Joćo Ferreira
Rep Power: 12 |
First question, are you using a time-step of 300?
If so, you need to lower that value, otherwise you won't be able to obtain any results. Anyway, if changing that the same problem appears: Code:
Min/max T:-2.85e+10 3.32e+09 You can also try another schemes (fvSchemes). Are you using first or second order schemes? The mesh could be also the reason of your problem/divergence. What you can do is write the results on the previous time-step and check where are located the cells with such T values. Is it clear? |
June 10, 2016, 10:39 |
#19 | ||
Raffael H.
Rep Power: 10 |
Hello Joćo,
thank you for your help! But this time I realized, what a noob I am. To your first questeion: Yes, I wanted to create a kind of fast motion. But I followed your advice and took the tenth part of it - so it's 30 now. What do you mean by your code? I tried to use it after the first error but OpenFOAM didn't know what to do with that. Can you tell me more about the code and the purpose behind that? Your advice to play with the relaxation factors and tolerances I followed as good as I can. The matter is... I don't know how the change of a relaxation factor affects on the simulation or the output. What I also didn't understand was, what do you mean by first or second order scheme? Another scheme? I really don't know anything about the fvscheme-file... I just copied it from the tutorial "multiRegionHeater". Quote:
My mesh could be a problem? I put my system-folder and my blockMeshDict in the attachment, so you know better what this is all about. But not to miss, my current Error-message: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v3.0+ | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v3.0+-e941ee6c15e9 Exec : chtMultiRegionFoam -parallel Date : Jun 10 2016 Time : 13:14:04 Host : "boot2docker" PID : 479 Case : /home/ofuser/workingDir/FoamCases/KabelInLuft nProcs : 3 Slaves : 2 ( "boot2docker.480" "boot2docker.481" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create fluid mesh for region air for time = 0 Create solid mesh for region cable for time = 0 *** Reading fluid mesh thermophysical properties for region air Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Adding to rhoFluid Adding to UFluid Adding to phiFluid Adding to gFluid Adding to hRefFluid Adding to ghFluid Adding to ghfFluid Adding to turbulence Selecting turbulence model type laminar Selecting radiationModel none Adding to KFluid Adding to dpdtFluid Adding MRF No MRF models present Adding fvOptions No finite volume options present *** Reading solid mesh thermophysical properties for region cable Adding to thermos Selecting thermodynamics package { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Adding to radiations Selecting radiationModel none Adding fvOptions No finite volume options present Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.0801 max: 0.156 Region: air Courant Number mean: 0 max: 0 Region: cable Diffusion Number mean: 0.0801 max: 0.156 Time = 30 Solving for fluid region air diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for h, Initial residual = 1, Final residual = 9.65e-06, No Iterations 16 Min/max T:258 316 GAMG: Solving for p_rgh, Initial residual = 0.972, Final residual = 0.0936, No Iterations 3 [0] [0] [0] --> FOAM FATAL ERROR: [0] temporary of type N4Foam8fvMatrixIdEE deallocated [0] [0] From function const T& Foam::tmp<T>::operator()() const [with T = Foam::fvMatrix<double>] [0] in file /opt/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/tmpI.H at line [1] [1] [1] --> FOAM FATAL ERROR: [1] temporary of type N4Foam8fvMatrixIdEE deallocated [1] [1] From function const T& Foam::tmp<T>::operator()() const [with T = Foam::fvMatrix<double>] [1] in file /opt/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/tmpI.H at line 220. [1] [2] [2] [2] --> FOAM FATAL ERROR: [2] temporary of type N4Foam8fvMatrixIdEE deallocated [2] [2] From function const T& Foam::tmp<T>::operator()() const [with T = Foam::fvMatrix<double>] [2] in file /opt/OpenFOAM/OpenFOAM-v3.0+/src/OpenFOAM/lnInclude/tmpI.H at line 220. [0] FOAM parallel run aborting [0] FOAM parallel run aborting [1] 220. [2] FOAM parallel run aborting [2] [2] #0 [0] #0 Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [1] #1 Foam::error::abort()[2] #1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [0] #1 Foam::error::abort() in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [2] #2 in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [1] #2 in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/lib/libOpenFOAM.so" [0] #2 ??? at chtMultiRegionFoam.C:0 [0] #3 at chtMultiRegionFoam.C:0 [1] #3 at chtMultiRegionFoam.C:0 [2] #3 ??? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [0] #4 in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam"" [2] #4 [1] #4 ??? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [0] #5 __libc_start_main in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [2] #5 __libc_start_main in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [1] #5 __libc_start_main in "/lib64/libc.so.6" [0] #6 in "/lib64/libc.so.6" [2] #6 in "/lib64/libc.so.6" [1] #6 ??? in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" in "/opt/OpenFOAM/OpenFOAM-v3.0+/platforms/linux64Gcc48DPInt32Opt/bin/chtMultiRegionFoam" [boot2docker:00477] 2 more processes have sent help message help-mpi-api.txt / mpi-abort [boot2docker:00477] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Thanks in advance Raffael Last edited by ruffy19; June 13, 2016 at 03:24. |
June 13, 2016, 09:29 |
#20 |
Joćo Ferreira
Rep Power: 12 |
I advise you to study how simulations work which will help you a lot on how to stabilise your case. Check this link regarding the first/second order schemes. The mesh could obviously be a problem, it affects the way that the equations are solved. Again, you should look for more information regarding this subject.
To be honest I have no idea about the new error you have. Don't know if any user of the forum have experience with this. To write the results, you need to adjust the writeInterval variable (system/controlDict) to match with the time-step when the error occurs. Anyway the time-step still looks too high for me, however I don't know if it's part of your setup. Do you have any information about the error you have at the moment? |
chtmultiregionfoam, error, mpi error, mpirun, solve |
Error in thermophysical properties (chtMultiRegionFoam) | mukut | OpenFOAM Pre-Processing | 28 | November 23, 2021 07:34 |
Error in chtMultiRegionFoam | kirankarki | OpenFOAM | 6 | August 21, 2018 09:00 |
What does this error when use solver chtMultiRegionFoam mean | sajad6 | OpenFOAM Running, Solving & CFD | 7 | October 6, 2014 08:38 |
chtmultiregionFoam error | oilsok | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 12:19 |
chtmultiregionFoam | alvora | OpenFOAM | 9 | February 23, 2011 04:06 |
