Problem in case HronTurekFsi3 (fsiFoam)
Like Tree2Likes
  • 1 Post By lxwd
  • 1 Post By joukovsky
Old   May 12, 2016, 12:28
Post Problem in case HronTurekFsi3 (fsiFoam)
Lee
lxwd is on a distinguished road
Dear all,
I have installed foam-extended-3.2 on Ubuntu 14.04. I also followed the installing instruction for the FSI toolkits stated on the openfoamwiki website https://openfoamwiki.net/index.php/E...re_interaction
But I cannot run the fsiFoam tutorial case, HronTurekFsi3, which gives me an error in the terminal shown as below.
Running blockMesh on /FOAM/FluidStructureInteraction/run/fsiFoam/HronTurekFsi3-test/fluid
Running setSet on /FOAM/FluidStructureInteraction/run/fsiFoam/HronTurekFsi3-test/fluid
Running setsToZones on /FOAM/FluidStructureInteraction/run/fsiFoam/HronTurekFsi3-test/fluid
Making dependency list for source file hronTurekReport.C
SOURCE=hronTurekReport.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I../../../../src/fluidStructureInteraction/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/finiteVolume/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/finiteArea/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/meshTools/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/triSurface/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/lagrangian/basic/lnInclude     -I/FOAM/foam/foam-extend-3.2/src/solidModels/lnInclude -IlnInclude -I. -I/FOAM/foam/foam-extend-3.2/src/foam/lnInclude -I/FOAM/foam/foam-extend-3.2/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/hronTurekReport.o
/usr/bin/ld: cannot find -ltriSurface
collect2: error: ld returned 1 exit status
make: *** [/FOAM/foam/xul15103-3.2/lib/linux64GccDPOpt/libhronTurekReport.so] Error 1
Running fsiFoam on /FOAM/FluidStructureInteraction/run/fsiFoam/HronTurekFsi3-test/fluid
I also checked the log.fsiFoam file under the fluid folder and it gave me an error as follow.
Starting time loop
Creating pointHistory function object.
History point ID: 1165
History point coordinates: (0.6 0.2 0.015)
Reference point coordinates: (0.6 0.2 0.025334)
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libhronTurekReport.so: cannot open shared object file: No such file or directory
--> FOAM FATAL ERROR:
Unknown function type hronTurekReport
Valid functions are :
1
pointHistory
    From function functionObject::New(const word& name, const Time&, const dictionary&)
    in file db/functionObjects/functionObject/functionObject.C at line 94.
FOAM exiting
Segmentation fault (core dumped)
I am not quite sure how to fix this problem. Any help is greatly appreciated!
Best Regards,
Lee
joukovsky likes this.
lxwd is offline   Reply With Quote
Old   January 22, 2017, 12:18
ahmed bekhti
joukovsky is on a distinguished road
Hello Lee;
I have the same problem , did you fixed it?
regards
joukovsky is offline   Reply With Quote
Old   January 23, 2017, 08:02
ahmed bekhti
Hello;
Finally I reinstalled FSI packege by following step by step (compiling and running) :
https://openfoamwiki.net/index.php/E...oam-extend_3.0
and actually it works.
hu'hu likes this.
Pressure instabilities with interDyMFoam for the floatingObject case nbadano OpenFOAM Running, Solving & CFD 15 October 15, 2021 07:35
Problem running movingCylinders case in parallel with foam-extend-3.1 mhkenergy OpenFOAM Running, Solving & CFD 5 March 3, 2017 06:20
Error reading new case montag dp FLUENT 5 September 15, 2011 07:00
Problem in unstructured circular cylinder case Tarak OpenFOAM Running, Solving & CFD 3 January 5, 2011 04:13
case example for HVAC problem kevin FLUENT 0 April 3, 2004 13:09
