Scalar transport function object
Like Tree3Likes
  • 3 Post By tomf
Old   April 15, 2016, 02:36
Default Scalar transport function object
vel
vetri1689 is on a distinguished road
Has anybody used scalartransport object. if so briefly summarize here how to use it. and also explain how to monitor the concentration of tracer by scalartransport function. which file exactly gives the concentration of tracer at a particular location in domain?
vetri1689 is offline   Reply With Quote
Old   April 18, 2016, 06:36
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I think you should start working on the searching skills. For the scalarTransport, please have a look at this post:
http://www.cfd-online.com/Forums/ope...tml#post521181
For monitoring look for probes in the forum/tutorials.
Regards,
Tom
tomf is offline   Reply With Quote
Old   April 23, 2016, 04:11
Default for diff boundary condition
vel
Hi tom
i got it after spending so much time. and its working well with the previously defined mass flow inlet boundary condition. but i wanted to initiate from the free surface boundary as a tracer(dye).
looking forward your reply.
Old   April 24, 2016, 09:06
Tom Fahner
I copied this from the private message you sent hoping that more people may read this.
i am modelling a multiphase simulation with buoyancy dominated flow. both the phases(Argon gas and steel) are immiscible. i want to find out the dye concentracentration at one point for which i am using probe. but the problem i am facing is that the initialization of dye is not happening at the free surface(top surface of the reactor) where gas is blown from the bottom of the reactor.
From this I have no idea how to help you. Please explain your problem clearly. Maybe make a sketch of what you are seeing and what you want to see.
Regards,
Tom
Old   April 25, 2016, 03:20
Default Image attached
vel
Hi tom
have a look on uploaded image.
top layer is mentioned as free surface boundary condition. in the same plane i want to initiate a trace for some time. how to do it in openfoam and give some idea.
Old   April 25, 2016, 04:26
Tom Fahner
I see no image...
Regards,
Tom
Old   April 25, 2016, 04:37
vel
image attached
Old   April 25, 2016, 04:49
vel
Hi tom i hope you got it.
Old   April 25, 2016, 05:15
Tom Fahner
Ok in that case, something like this may work, where you have to modify the points for the location where you want to inject the dye and the rate of injection. I am not sure about the time part of your request. It may work to run the solver until time = 5 seconds, stop the simulation, make the fvOptions part below empty and continue the run.
functions
    Tracer
        type    scalarTransport;
        functionObjectLibs ("libutilityFunctionObjects.so");
        outputControl   outputTime;
        active          true;
        autoSchemes     false;
        nCorr           1; // number of non-orthogonal correctors
        resetOnStartUp  false;
        fvOptions
            Tracer
                type        scalarExplicitSetValue;
                active      true;
                scalarExplicitSetValueCoeffs
                    selectionMode       points;
                    points     (
                                   (1.3 0.628 1.145)
                                   (1.2 0.628 1.145)
                    injectionRate
                        Tracer         1;
guifon1000, BlnPhoenix and mrishi like this.
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
solving passive scalar by user function in AVLFIRE huyp Main CFD Forum 0 September 4, 2008 11:21
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
