interFoam & yPlusLES error
Like Tree1Likes
  • 1 Post By PratikChakraborty
Old   April 7, 2016, 08:47
Default interFoam & yPlusLES error
Zlatko's Avatar
Zlatko is on a distinguished road
I wanted to check y+ values in my interFoam LES simulation, but I've got FATAL IO ERROR. After that, I tried nozzleFlow2D tutorial case from OpenFOAM v2.4.0 and v3.0.1. Again, the FATAL IO ERROR message appeared. The utility yPlusLES works well with single-phase solver, such as $FOAM_RUN/tutorials/incompressible/pisoFoam/les/pitzDaily.
Does anyone know the solution to this problem?
$ yPlusLES
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.4.0-dcea1e13ff76
Exec   : yPlusLES
Date   : Apr 07 2016
Time   : 13:12:16
Host   : "lfdt3"
PID    : 21080
Case   : $FOAM_RUN/tutorials/multiphase/interFoam/les/nozzleFlow2D
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Time = 0
Calculating wall distance
Writing wall distance to field y
Reading field U
--> FOAM FATAL IO ERROR:
keyword transportModel is undefined in dictionary "$FOAM_RUN/tutorials/multiphase/interFoam/les/nozzleFlow2D/constant/transportProperties"
file: $FOAM_RUN/tutorials/multiphase/interFoam/les/nozzleFlow2D/constant/transportProperties from line 18 to line 64.
    From function dictionary::lookupEntry(const word&, bool, bool) const
    in file db/dictionary/dictionary.C at line 442.
FOAM exiting
Zlatko is offline   Reply With Quote
Old   February 15, 2023, 13:47
Pratik Chakraborty
PratikChakraborty is on a distinguished road
The error indicates that something is missing in your constant/transportProperties file:
Check that file and see if the keyword transportModel is defined properly in it.
Hr_kules likes this.
PratikChakraborty is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
